Drahcir495 Posted July 24, 2023 Share Posted July 24, 2023 I went to the pick n pull and picked up two of the wing window channel ?? pieces. The are in excellent shape -> My question is how do you secure the glass back into the channel? Could I use this? -> Link to comment Share on other sites More sharing options...
JeepSchmidt O'Guinness Posted July 24, 2023 Share Posted July 24, 2023 I thought the vent windows were all one piece? Link to comment Share on other sites More sharing options...
fiatslug87 Posted July 24, 2023 Share Posted July 24, 2023 There are two versions, the fixed and vent windows that pivot open as above. Link to comment Share on other sites More sharing options...
rokinn Posted July 24, 2023 Share Posted July 24, 2023 IIRC the glass is already a pretty snug fit without any thing else. Getting a well cleaned and precise fit on the rubber parts will be the key in having wing windows that don't leak. The only time mine will have some small leakage is if I spray directly at them with the high pressure wand at the car wash. Link to comment Share on other sites More sharing options...
Drahcir495 Posted July 24, 2023 Author Share Posted July 24, 2023 When I put the glass in it will slide a little front and to the rear. I will need to get them to stay put? Link to comment Share on other sites More sharing options...
coheed Posted July 24, 2023 Share Posted July 24, 2023 34 minutes ago, Drahcir495 said: When I put the glass in it will slide a little front and to the rear. I will need to get them to stay put? Both of mine do the same thing. Whatever the factory used to seal them to the bottom metal part has deteriorated over the years. I thought about cleaning out the channel and using windshield urethane to reattach them. Link to comment Share on other sites More sharing options...
Htchevyii Posted July 24, 2023 Share Posted July 24, 2023 The rubber below is commonly used on older vehicles where the door class presses into a steel channel. I'd think that a windshield urethane would be ideal, but a little spendy for the amount that you will need, (since most would be wasted). Black silicone? https://www.ebay.com/itm/115480801558 Link to comment Share on other sites More sharing options...
Drahcir495 Posted July 26, 2023 Author Share Posted July 26, 2023 Thank you. I will check that out Link to comment Share on other sites More sharing options...
Tex06 Posted August 11, 2023 Share Posted August 11, 2023 Black RTV will work. You can also use it and a Walmart bag/plastic sheeting to seal any air leaks in vent windows. Link to comment Share on other sites More sharing options...
Drahcir495 Posted August 11, 2023 Author Share Posted August 11, 2023 2 hours ago, Tex06 said: Black RTV will work. You can also use it and a Walmart bag/plastic sheeting to seal any air leaks in vent windows. Thank you Link to comment Share on other sites More sharing options...
AZJeff Posted August 12, 2023 Share Posted August 12, 2023 Black urethane glass adhesive (used to attach windshields to the body opening) is the ideal agent. Any glass shop should be able to do both windows for a few bucks, and it’s UV tolerant, more than RTV. Link to comment Share on other sites More sharing options...
Drahcir495 Posted August 12, 2023 Author Share Posted August 12, 2023 Never thought of that! I will call around and probably do it that way Link to comment Share on other sites More sharing options...
OldSch88L Posted August 14, 2023 Share Posted August 14, 2023 Like some people said, windshield adhesive (black urethane) is the proper thing to use. If you don't want to buy a whole caulk gun size tube and risk wasting the rest, you can do like I did, and buy the smaller sized Permatex tube: Link to comment Share on other sites More sharing options...
Drahcir495 Posted August 15, 2023 Author Share Posted August 15, 2023 On 8/14/2023 at 2:15 AM, OldSch88L said: Like some people said, windshield adhesive (black urethane) is the proper thing to use. If you don't want to buy a whole caulk gun size tube and risk wasting the rest, you can do like I did, and buy the smaller sized Permatex tube: Oh good. Thank you Link to comment Share on other sites More sharing options...
