jtdesigns Posted December 20, 2007 Posted December 20, 2007 So I guess I'll go ahead and log my progress on my 89 ................... . . . . day of sale for $250 :eek: !!! don't b HAtEIN !!! . . unexpected to say the least... The red column is KILLIN me !! Finally got a good idle : Because .......... New plugs, cap, and wires helped 85% AND>>> Before Was too excited to get clean parts back on forgot to thumb the cam.. Wildman is the man to ask for hard to find parts!! Wiring harness : Got me some alternators to swap.. one on left off a '93 S-10 4.3L Works fine... but you have to re-clock the housing.. it was pretty easy to do. Rebuilt the mj's alt. First thing to drop cash on was better tires, just happened these were attached to them :brows: seats get a band-aid until something else comes along.. Took some mothers metal polish and cleaned the cluster lens!! Brake work,,,, ummmm lots of it.... did the rears DAYMN these came out looking great!!! Used some high heat silver then some anodizing paint. I wish I could of mixed a lil yellow in the red to make it briter but looks fine. New foggers!! Well after two tries I think I got the VC the way I want it. It got a lil lint in the paint, but it'll rub out nicely.. Took out all the pre-air heater and covered the holes left from the parts.. Painted my air box to match the vc!!! . . Finally came up with a way to make my double booster work... I thought about this for a while now and this is what I came up with. I chucked a 3" piece of 3/4 round stock in the lath and bored a 3/8 hole through the whole length... Then swapped bits to 1/2 and went in 1.5 on one side. Cut my old single boosters rod a lil less then 9/16 starting from the round part and measured the new double boosters rod and cut it where it would butt up to the old rod and be the same original length... I had to press the old rod into the sleeve to make it butt up against the 3/8's hole and threw it in the vice on the drill press, center punched me three spots on the sleeve. One going thru the old rod and two going thru the new. Drilled one hole thru the sleeve and old rod... I had it set up in a way that I could then slide the new boosters rod, still in the booster, into the other side of the sleeve and drilled the other two holes. Those holes were 3/32 for a few roll pins that got pressed in holding everything together. Finished it all up by using a belt sander to take all the edges and any exposed roll pins off. . . My goal!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Will update as progress continues!
500 MJ Posted December 20, 2007 Posted December 20, 2007 Not a bad starter for $250. Keep up the good work!
beaterjeep Posted December 20, 2007 Posted December 20, 2007 don't b HAtEIN !!![/b] I think considering that your truck has a cargo lamp, there will be a lot of people here hating on you. Nice buy though, looks good. :cheers:
Hawk Posted December 20, 2007 Posted December 20, 2007 great looking truck! What're those switches for on the dash? I wondered that, my MJ has slots for 4 of them. The column may be obnoxious red, but at least it's tilt!
jtdesigns Posted December 21, 2007 Author Posted December 21, 2007 Not a bad starter for $250. Keep up the good work! Thanks! Yeah she was sitting in knee high grass and had all kinds of vines growing through the frame!!.. threw a batt in and she started up with a little tinkering.. bout burnt it up cause the rear tires were flat and the cat was sitting in the grass!! I think considering that your truck has a cargo lamp, there will be a lot of people here hating on you. Nice buy though, looks good. :cheers: Really, are they that hard to find?? COOL!! :D Thanks!! great looking truck! What're those switches for on the dash? I wondered that, my MJ has slots for 4 of them. The column may be obnoxious red, but at least it's tilt! Those my friend are for the driving lights and the cargo light for the bed. I have found a few gray tilts, but some deals seemed shady and some were when I was broke... well he!! I'm still broke... JEEP = Just Empty Every Pocket........ I did get a gray horn button off ebay for like 4 bucks a while back though!! Thanks for everyones help cause I wouldn't be able to figure alot of this truck out without ya'lls help!! :cheers: :cheers: :cheers:
Jeepinmanch Posted December 21, 2007 Posted December 21, 2007 I thought I got a good deal with an 86' for $400. Nice find, a can of plastic paint will help that red eyesore.
HOrnbrod Posted December 21, 2007 Posted December 21, 2007 I think you either have either the Eliminator or Laredo trim level on your rig. For an 89: If the 8th digit in your VIN is a T it's a Laredo. If the 8th digit in your VIN is a 5 it's an Eliminator
jtdesigns Posted December 21, 2007 Author Posted December 21, 2007 I think you either have either the Eliminator or Laredo trim level on your rig. For an 89: If the 8th digit in your VIN is a T it's a Laredo. If the 8th digit in your VIN is a 5 it's an Eliminator Yeah I have an Eliminator. It has decals on the other bed side. A carfax told me it was hit in the bed, so I guess the po just painted and didn't replace the decal on the left side.
HOrnbrod Posted December 21, 2007 Posted December 21, 2007 I think you either have either the Eliminator or Laredo trim level on your rig. For an 89: If the 8th digit in your VIN is a T it's a Laredo. If the 8th digit in your VIN is a 5 it's an Eliminator Yeah I have an Eliminator. It has decals on the other bed side. A carfax told me it was hit in the bed, so I guess the po just painted and didn't replace the decal on the left side. Does your VIN agree? There was a guy on FleaBay awhile back selling a Laredo MJ that was a dressed up base model. If the VIN says so, UB lucky. :cheers:
jtdesigns Posted December 21, 2007 Author Posted December 21, 2007 This is what the carfax said, but the 8th digit is a L :dunno: Report Run Date: 12/11/2007 The vehicle identification number you submitted has been analyzed and summary information on your car is shown below. VIN: 1J7FT66LXKLxxxxxx Year: 1989 Make: Jeep Model: Comanche Eliminator Style/Body: Regular Cab Class: Pickup - Full Sized Engine: 4.0L I6 MPI Country of Assembly: United States Vehicle Age: 18 year(s) Last Reported Odometer Reading: 156,723
SuperWade2 Posted December 21, 2007 Posted December 21, 2007 Per this link ftp://www.knwd.net/pub/jeep/86-88_MJ_VIN_decoder.rtf the 8th Digit for an 1989 of "L", just indicates the 4.0L 6 Cylinder. The 6th Digit of "6" indicates a Eliminator Trim Package This all matches up with what the CarFax Says... SW2
jtdesigns Posted December 21, 2007 Author Posted December 21, 2007 Per this link ftp://www.knwd.net/pub/jeep/86-88_MJ_VIN_decoder.rtf the 8th Digit for an 1989 of "L", just indicates the 4.0L 6 Cylinder. The 6th Digit of "6" indicates a Eliminator Trim Package This all matches up with what the CarFax Says... SW2 I wish it was 4wd...... in time maybe.... :brows:
HOrnbrod Posted December 21, 2007 Posted December 21, 2007 Per this link ftp://www.knwd.net/pub/jeep/86-88_MJ_VIN_decoder.rtf the 8th Digit for an 1989 of "L", just indicates the 4.0L 6 Cylinder. The 6th Digit of "6" indicates a Eliminator Trim Package This all matches up with what the CarFax Says... SW2 Per this link the 6th digit 6 is only for the 91+ models. AAAAAAARGH, who knows. But it sounds like it's a regulation Eliminator..........
SuperWade2 Posted December 21, 2007 Posted December 21, 2007 Per this link ftp://www.knwd.net/pub/jeep/86-88_MJ_VIN_decoder.rtf the 8th Digit for an 1989 of "L", just indicates the 4.0L 6 Cylinder. The 6th Digit of "6" indicates a Eliminator Trim Package This all matches up with what the CarFax Says... SW2 Per this link the 6th digit 6 is only for the 91+ models. AAAAAAARGH, who knows. But it sounds like it's a regulation Eliminator.......... ??? 6 - Trim Package (1989) 1 * "S" (E) 2 * Base (L) 3 * Pioneer/Islander (M) 4 * Sahara (H) 5 * Laredo/Grand (P) 6 * Eliminator (S) 7 * Limited (X)
jtdesigns Posted December 22, 2007 Author Posted December 22, 2007 Per this link ftp://www.knwd.net/pub/jeep/86-88_MJ_VIN_decoder.rtf the 8th Digit for an 1989 of "L", just indicates the 4.0L 6 Cylinder. The 6th Digit of "6" indicates a Eliminator Trim Package This all matches up with what the CarFax Says... SW2 Per this link the 6th digit 6 is only for the 91+ models. AAAAAAARGH, who knows. But it sounds like it's a regulation Eliminator.......... You sure you read that right Hornbrod?
HOrnbrod Posted December 22, 2007 Posted December 22, 2007 Per this link ftp://www.knwd.net/pub/jeep/86-88_MJ_VIN_decoder.rtf the 8th Digit for an 1989 of "L", just indicates the 4.0L 6 Cylinder. The 6th Digit of "6" indicates a Eliminator Trim Package This all matches up with what the CarFax Says...SW2 Per this link the 6th digit 6 is only for the 91+ models. AAAAAAARGH, who knows. But it sounds like it's a regulation Eliminator.......... You sure you read that right Hornbrod? Obviously not :eek: . I'm tired, cold, and it's Miller time. :cheers: Been working on and off today installing some side blinker repeaters like the Euro XJs have, and come inside to warm up a bit and check out the CClub forum. Got them in, will wire up tomorrow. Another semi useless mod, but it's fun.
jtdesigns Posted December 22, 2007 Author Posted December 22, 2007 Per this link ftp://www.knwd.net/pub/jeep/86-88_MJ_VIN_decoder.rtf the 8th Digit for an 1989 of "L", just indicates the 4.0L 6 Cylinder. The 6th Digit of "6" indicates a Eliminator Trim Package This all matches up with what the CarFax Says...SW2 Per this link the 6th digit 6 is only for the 91+ models. AAAAAAARGH, who knows. But it sounds like it's a regulation Eliminator.......... You sure you read that right Hornbrod? Obviously not :eek: . I'm tired, cold, and it's Miller time. :cheers: Been working on and off today installing some side blinker repeaters like the Euro XJs have, and come inside to warm up a bit and check out the CClub forum. Got them in, will wire up tomorrow. Another semi useless mod, but it's fun. Are you talking about the blinkers that fit in the fenders?
jtdesigns Posted December 22, 2007 Author Posted December 22, 2007 I don't know if I like them in that spot, unless you just want to be oem..I think they look better here. just my 2 cents.... Image Not Found
JeepcoMJ Posted December 22, 2007 Posted December 22, 2007 I don't know if I like them in that spot, unless you just want to be oem..I think they look better here. just my 2 cents.... Image Not Found I agree
HOrnbrod Posted December 22, 2007 Posted December 22, 2007 I don't know if I like them in that spot, unless you just want to be oem..I think they look better here. just my 2 cents.... Image Not Found Yeah, did think about that, but decided to put them in the OEM location.
HOrnbrod Posted December 22, 2007 Posted December 22, 2007 I just posted a thread in the MJ Projects forum detailing the installation of EURO side repeater lights if anyone is interested. :cheers:
MiNi Beast Posted March 28, 2008 Posted March 28, 2008 You talking about this piece? It's gorgeous I tell you. What you got planned next for her?
jtdesigns Posted March 28, 2008 Author Posted March 28, 2008 You talking about this piece? It's gorgeous I tell you. What you got planned next for her? Hey man... It's called a project for a reason,,, Waiting to mill a piece for the xj double booster,, need to get/ find a clutch mc.. then bleed everything.. Have some newer xj doors to put on,,, have a lot of sanding off flaking clear then paint,,, thats about it for now,,, summer should be fun!!
MiNi Beast Posted March 28, 2008 Posted March 28, 2008 You talking about this piece? It's gorgeous I tell you. What you got planned next for her? Hey man... It's called a project for a reason,,, Waiting to mill a piece for the xj double booster,, need to get/ find a clutch mc.. then bleed everything.. Have some newer xj doors to put on,,, have a lot of sanding off flaking clear then paint,,, thats about it for now,,, summer should be fun!! Good deal look forward towards your build, you know I have to live through you MJ now that mine is gone. :cry:
