44 minutes ago, Joe Dirt said:
Wonder why they swapped it out. 🤔 truck is a metric ton so it should've had a 44, right? Any pro's or cons with it?
May have just added the metric ton leaf pack when they swapped
It has the badges as well. Not that they couldn't have added them too...
If you add the VIN to the registry we can tell you if it’s a true Metric Ton.
If I had to guess someone sold the 44 from your rig years ago. Even if the 44 needed parts it would've been easier to fix it than to swap in a whole nother axle, unless the housing was toast or it needed new gears.
Assuming it is an actual Metric Ton and someone didn't just swap in the badges and leaf packs... yeah, it doesn't make sense to swap out the D44 for a 8.25.
