AZJeff Posted February 15, 2022 Share Posted February 15, 2022 I bought a set of the reproduction tail light lenses from Key Parts. While doing the install, I did a write-up of what it took to get good results. Is anyone interested in me posting a PDF of the procedure I went through? Link to comment Share on other sites More sharing options...
Big Dan Posted February 15, 2022 Share Posted February 15, 2022 YesSent from my Pixel 4 XL using Tapatalk Link to comment Share on other sites More sharing options...
Pete M Posted February 15, 2022 Share Posted February 15, 2022 absolutely! drop your info in here: https://comancheclub.com/forum/10-mj-tech-diy-projects-and-write-ups/ Link to comment Share on other sites More sharing options...
Limeyjeeper Posted February 15, 2022 Share Posted February 15, 2022 Yes please. I am too old and cranky to know it all!! Link to comment Share on other sites More sharing options...
DesertRat1991 Posted February 15, 2022 Share Posted February 15, 2022 Yes Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 15, 2022 Share Posted February 15, 2022 Most certainly! Link to comment Share on other sites More sharing options...
AZJeff Posted February 15, 2022 Author Share Posted February 15, 2022 PDF is uploaded. There are tons of pictures, so downloading it is the best way to see the details. MODS-- I couln't get my document to copy/paste into the main message screen because I had photos with highlighing lines, etc. Thus, I just uploaded a PDF. If you can tell me how to fix this, I will repost directly into message screen for easier viewing. Link to comment Share on other sites More sharing options...
Pete M Posted February 15, 2022 Share Posted February 15, 2022 Quote Now that new taillight lenses are available from “Key Parts”, there has been some discussion on the Comanche Club on how to remove the old lenses and install the new ones. What follows is the approach I used. I cut the lens off the reflector portion of the taillight housing by using a Dremel tool with a small circular saw blade. I did a “plunge” cut into the gap between the lens and the reflector, and worked my way along, separating the two parts. The yellow dotted lines in the below picture shows the point where I applied the saw, and below that is a photo of the type of saw blade I used I'll have to look into it later today. might need to do a bunch of screenshots. Link to comment Share on other sites More sharing options...
AZJeff Posted February 16, 2022 Author Share Posted February 16, 2022 So I have tried to screen shot the pages of the PDF. They are pasted below. Link to comment Share on other sites More sharing options...
Minuit Posted February 17, 2022 Share Posted February 17, 2022 Now THAT is how you do a writeup. Link to comment Share on other sites More sharing options...
AZJeff Posted February 17, 2022 Author Share Posted February 17, 2022 I have also added a write-up on how to repair the hole in the reflector housing where the bulb socket does it's "twist lock" engagement. Mine were all trashed. That write up is in my thread about the taillight restoration in the DIY section. Link to comment Share on other sites More sharing options...
big66440 Posted February 19, 2022 Share Posted February 19, 2022 Thank you for the write up!! Do you feel confident these new lenses will endure and keep their “like new” look for years? Link to comment Share on other sites More sharing options...
AZJeff Posted February 19, 2022 Author Share Posted February 19, 2022 19 minutes ago, big66440 said: Thank you for the write up!! Do you feel confident these new lenses will endure and keep their “like new” look for years? More than anything else, this is dependent on the quality of the raw acrylic resin used in molding the replacement lenses. Keeping them out of the sunlight when practical will help. (You should see what AZ sun does to plastics out here, even those that are “UV stabilized”). The best thing to extend their life is probably limiting sunlight exposure, and that applies to ANY taillights, not just ones on an MJ. Link to comment Share on other sites More sharing options...
Minuit Posted February 19, 2022 Share Posted February 19, 2022 I'd be highly tempted to put some type of ceramic coating on them while they're new and undamaged by UV rays. Link to comment Share on other sites More sharing options...
Mjjeep91 Posted April 4, 2022 Share Posted April 4, 2022 On 2/14/2022 at 4:43 PM, AZJeff said: I bought a set of the reproduction tail light lenses from Key Parts. While doing the install, I did a write-up of what it took to get good results. Is anyone interested in me posting a PDF of the procedure I went through? Do you have a link of where you bought your lenses? Link to comment Share on other sites More sharing options...
AZJeff Posted April 4, 2022 Author Share Posted April 4, 2022 They were listed on eBay. Key Parts has a “store” on eBay. Link to comment Share on other sites More sharing options...
