knever3 Posted September 13, 2021 Share Posted September 13, 2021 I remember a thread about a tailgate lock years ago, but I don't remember the link to the part. I am tired of closing the tailgate and having the hinges bind up and then the tailgate tries to fall off. I want to install a lock for two reasons, theft and to prevent chipping the paint and you can imagine other things. Does anyone have any updated links to something like this? Link to comment Share on other sites More sharing options...
Muncher Posted September 13, 2021 Share Posted September 13, 2021 Mine binds up all the time. Two things you could do is get rid of the hinges and uses cables instead or put the bolts in that are supposed to be there that I still haven't done yet Link to comment Share on other sites More sharing options...
Muncher Posted September 13, 2021 Share Posted September 13, 2021 This little plate near where the tailgate mounts should be bolted in to prevent falling off Link to comment Share on other sites More sharing options...
Muncher Posted September 13, 2021 Share Posted September 13, 2021 My bad picture didn't go through at first Link to comment Share on other sites More sharing options...
Pete M Posted September 13, 2021 Share Posted September 13, 2021 is the bolt tight? Link to comment Share on other sites More sharing options...
eaglescout526 Posted September 13, 2021 Share Posted September 13, 2021 53 minutes ago, Muncher said: My bad picture didn't go through at first I fixed this issues actually. I just put a bolt through the other side to flatten that alignment hole and I haven’t had any issues. Also it helps if the tailgate is pushed toward the drivers side and everything is lubed as they should be. Then you’ll get quiet closing and latching results. Link to comment Share on other sites More sharing options...
fiatslug87 Posted September 14, 2021 Share Posted September 14, 2021 I remember @Gjeepmaking a tailgate handle lock, for the rest of us mere mortals a hose clamp may deter or at least slow down a thief. Link to comment Share on other sites More sharing options...
watchamakalit Posted September 14, 2021 Share Posted September 14, 2021 Your tailgate shouldn't just fall off. I can open mine and drop it, slam it shut as hard as I want and it won't fall off. I would say you have a bent hinge or something else at play. A tailgate lock of any kind will just be a bandaid over a gunshot so to speak. Link to comment Share on other sites More sharing options...
knever3 Posted September 15, 2021 Author Share Posted September 15, 2021 The cups seem very loose, especially on the right side. When you raise and lower the tailgate it moves around. I will shoot a video tomorrow. Sent from my SM-G960U1 using Tapatalk Link to comment Share on other sites More sharing options...
fiatslug87 Posted September 15, 2021 Share Posted September 15, 2021 They bolt down through the cups. Pull the cups off and make sure the alignment "tabs" are not bent. You can also bend the tabs out a little so when you bolt them down there is more force keeping them in place. Link to comment Share on other sites More sharing options...
knever3 Posted September 17, 2021 Author Share Posted September 17, 2021 Link to comment Share on other sites More sharing options...
