Project “Tomahawk”
Time for some updates: new PSC box is in and it works perfectly. Old box was 100% to blame for the horrendous steering I was experiencing. Need to finish aligning the steering wheel, but that should be a quick fix. I’m thinking I may need to grab some general spring rear springs as my spring rate is just a bit too soft for my use. I frequently trailer or haul heavy loads and could really use a higher spring rate. My current leaf springs are a rebuilt oem pack with a BDS add a leaf. They flex excelenty and are about a 1” lift over stock. From experience, I know the general springs will provide a mild lift over stock even in their 4 leaf configuration. I’m thinking they should keep a nice ride height if I swap them for the current pack.
I would be negligent to not mention what an awesome steering box the PSC big bore unit is. They provide taps and caps for running hydro assist if I ever go that route. Truly a quality product. I’ve given up on ever finding a decent rebuilt box. Redhead should have been a quality unit but unfortunately it failed the test. Best thing redhead could do now is accept a return but I doubt they will :dunno:
Some pics of the Tomahawk getting some much needed attention.
  • Replies 848
This is about 300lbs of tongue weight. With this load I have about 1.5” of travel left in the suspension. Definitely needs an upgrade to the rear springs. On another note, I’d love to add a second axle to this trailer as I’d like to eventually run a gear/storage box near the front of the trailer frame just before the tongue which will only add more tongue weight
Going on today. Will report back on results. Also been looking at possibly running an E force supercharger. Can’t help but noticing that I think I could clear my hood :idea:
I know there are other options out there but very few seem like a good fit.
I'm curious as to how this will work out, especially if it helps prevent axle wrap too. I need to do something with the rear of my truck because it doesn't take much to get it to squat and it wheel hops like nobody's business. I know my truck probably needs shocks, but if that doesn't cure it, I might have to look into something like this. It should help a lot with load capacity too.
Install went fairly smoothly given that this was a custom setup. I’ve only driven it a few block so far but it feel “planted” it’s almost like a have a sway bar and some additional weight in the bed. Very impressed with ride quality so far. Will report back once I get some use and see how they work out. Here are some of my install pics:
After further driving, definitely feels solid and well planted. No harshness, no noise. Curious to see how it handles a load and will probably try within a week or so. I could actually see this being a neat setup for running 31’s on a very capable, stock rig.
Start with shocks…on my rig, no wheel hop at all with all stock leaf’s, and shackles, just nice shocks. Thats with 35’s and plenty of power to make it hop if it was going to.
Definitely do a supercharger…and a cam lol
That's what I fully expect it to be. I have noticed that it has been feeling like it needs shocks, which is irritating because they're only 6 years old and Monroes, but that's new parts for you.
Having some audio ideas. First off, the sound quality in the cab is exceptional. But yes, I am a bass head :rolleyes:. Anyways, the current system is completely hidden. 8” kicker sub under passenger seat and all components in factory locations. Kicker class A/B amp under drivers seat for the component speakers. It’s a clean overall system but lack the depth I’m after. Frequency response fall flat under 50ish hz and it’s just obvious the shallow 8” sub doesn’t have enough airspace to perform in that little under seat enclosure. I’ve thought about several behind the seat options but don’t like the idea of them covering the cab corner speakers which, when tuned, provide a nice mid range boost and even help staging. So a behind the seat sub is out of the question. That leaves a blow through style design.
The existing roll top canister leaves about 10” of available space under it. It’s a bit of a dead zone that I can’t use for much else. My thoughts are a 4th order band pass system. (2) JL 8” W3’s in force canceling, back to back sealed band pass design. I would then use (2) 3” ports on each side tuned to 40hz. The vents would go straight into the cab with some nice trim out and would be behind the driver and passenger seats. The box itself would fill the empty space below the roll top canister and be finished in a waterproof coating and raptor lined. It would be serviceable from the bed.
I’m thinking this would be a stealthy high performance system that should provide what I’m looking for. Any thoughts?
17 minutes ago, watchamakalit said:
I'm not an audiophile. Would a bigger sub in that configuration have a benefit over 2 smaller ones?
I did look into that but the space I have under the canister is minimal. Larger subs can struggle in sound quality. I’d even consider multiple 6.5’s with the right specs and box design.
Since you are already thinking about cutting hole in sheetmetal.... have you thought about cutting hole underneath passenger seat for a regular 7" mounting depth sub ?
Build a metal box and weld it underneath.   Probably only need extra 4 or 5"
I did that years ago on my Ford single cab flareside.  I did long throw 8" sub under drivers & passenger.  Was totally satisfied with the thump.
A box behind the center console wouldn’t work? Don’t have it reach all the way to the pillars, maybe only make it wide enough so that it halfway overlaps each seat? That would leave over a foot between the pillar speakers and the box.
I’m running dual exhaust and the dual cats are under the passenger seat. Not a bad idea though. I was planning on just drilling out 4 3” holes with a hole saw so cutting would be pretty minimal.
I’d probably have to run a thin sub if I did and it would take out some precious behind the seat cargo space. I’d like to keep that area open and keep the system 100% stealth mode :cool:
Probably late to the party, but I am running the Kicker 48TCWRT122, I really wanted to build a big ported box for my Alpine Type R shallow sub, but I went the cheap and easy route.  I am powering it from an Alpine PDX-V9's sub channel with 500 watts, it is perfect.  The truck is fully covered with dynamat extreme, but that rear window slider rattles like mad when pushed.  I figured a sub with a passive radiator was a good compromise instead of a port.  I am an audiophile, but I prefer a lot more bass than the traditional, a sub or two IS a requirement, not a option.
I was looking at those then they came out. They seem like a nice option. How is the frequency response on them?
It plays well with my Diamond Audio 5-1/4" components, I always wanted to put in my 6.5's, but it's not worth the effort anymore.  I was going to do a DSP, go Active, have a Biketronics amp and an ARC amp for my sub, went with a simple Alpine 5 channel and can't be more happy.  It fits behind the seat with a ton of room to spare, and it was 5 minutes to throw it back there, looks good carpeted and finished.  It would have cost me $300 in material to make my own custom box for my Alpine shallow 12, sometimes when life catches up you make compromises that in the end turn out just right.
Thought I’d check in for a progress report. I’m pleased to say I am getting a ton of use out of the truck and have a few thousand trouble free miles on this build. Few small items that need to be addressed:
1. My speedometer and gas gauge both quit (I fill the tank very frequently now to be on the safe side lol)
2. I have some small paint peel near the third brake light to address. I do plan on doing a full repaint of the exterior at some point to eliminate any final imperfections.
3. I have a tiny bit of death wobble but only in specific circumstances.
The bottom drivers side corner of my windshield came loose on me a couple of months ago. Started noticing some water on the floor mat after a heavy rain. Fortunately have a budy here who owns an auto glass shop and they reset the whole glass and made it perfect. Other than those items, I have great steering, brakes, AC, audio, and overall a smooth daily driver. The engine is perfectly matched for this truck. I do really like this swap.
I've been disappointed with the OE gauge cluster for some time. Seen a few options out there including digital dashes but nothing really looked too clean imo. So I found I nice condition gauge cluster and sent it off to Dakota Digital for a custom HDX series build. The build takes about 4 months but looking forward to a clean, updated, and most importantly, accurate set of gauges.
What don't you like about the one cluster?  Not accurate enough or just not visually pleasing?
Are you referring to the single digital dash setups? I prefer analog gauges, the HDX is analog gauges with digital displays that are expandable to read a great variety of things. My stock gauges are just dying on me one by one.
Typo on my part, I meant to ask about the OE cluster.
