Project “Tomahawk”
Time for some updates: new PSC box is in and it works perfectly. Old box was 100% to blame for the horrendous steering I was experiencing. Need to finish aligning the steering wheel, but that should be a quick fix. I’m thinking I may need to grab some general spring rear springs as my spring rate is just a bit too soft for my use. I frequently trailer or haul heavy loads and could really use a higher spring rate. My current leaf springs are a rebuilt oem pack with a BDS add a leaf. They flex excelenty and are about a 1” lift over stock. From experience, I know the general springs will provide a mild lift over stock even in their 4 leaf configuration. I’m thinking they should keep a nice ride height if I swap them for the current pack.
I would be negligent to not mention what an awesome steering box the PSC big bore unit is. They provide taps and caps for running hydro assist if I ever go that route. Truly a quality product. I’ve given up on ever finding a decent rebuilt box. Redhead should have been a quality unit but unfortunately it failed the test. Best thing redhead could do now is accept a return but I doubt they will :dunno:
Some pics of the Tomahawk getting some much needed attention.
  • Replies 801
This is about 300lbs of tongue weight. With this load I have about 1.5” of travel left in the suspension. Definitely needs and upgrade to the rear springs. I may go with general spring 5 leaf pack if I can’t get something done locally. Alternatively I’ll check with Allan and see what they can do. It will just take much longer as I’ll have to send them over on a ship.
On another note, I’d love to add a second axle to this trailer as I’d like to eventually run a gear/storage box near the front of the trailer frame just before the tongue which will only add more tongue weight
