Another draw.
So I have a brand new battery and now I'm getting a draw with it. Things I have new in it are a new radio and map lights. I do know they turn off though when the trucks off. I also have led headlights with a h4 harness. What could be my problem ?
12 minutes ago, MiNi Beast said:
Check radio. Sometimes memory wire gets wired backwards. Did you and Jesse share same wiring schematics? :dunno:
I looked up the exact colors of are radios wiring and then pioneers and the wired it according to that.
4 minutes ago, JustEmptyEveryPocket said:
Start by watching THIS video all the way through. Twice. Then look up some more video explanations. Search for things like "parasitic draw" and "finding amperage draw". Then dive in with your multimeter and start having fun.
I did watch that video once I just don't have any electronic tools like that
You don't have a multimeter yet? Get one. They are almost required to work on these trucks. Otherwise, what do you think you are missing? Put the meter in amp mode between the truck and the battery, check the reading, then start pulling fuses. When the reading drops you have found the circuit. Report back at that point so we can help you figure out what runs on that circuit and which is the likely culprit.
I will try this. One weird thing I realized though not sure it's connected to this problem but a tad bit of a ring of green light appeared around my cigarette lighter that I have never noticed before
4 minutes ago, MiNi Beast said:
Simple solution....battery disconnect. :L: doesn't solve underlying problem but does give you an opportunity to find the source if still driving truck. Been there done that. :teehee:
True don't want to kill my brand new battery
I can't read the writing on your meter from the photo. The setting you are looking for is amps, usually a typed "A". You will need to select this on both the dial and where one of your wires plugs in. Then you need to put it in series with the negative post on your truck's battery. Remove the negative battery cable. Somehow attach one lead to the negative post on the battery and the other lead to the negative wire that you removed. That way your multimeter is in-between the battery and the wire that grounds on your truck. What reading do you get?
Read HERE for much more detail and better explanation.
Pull the cigarette lighter out, and see if your problem disappears. I had a battery drain on a Jeep YJ. The heating element was rusted up and pushed in (to heat up). The heating element would let a current through but there wasn't enough continuity to heat it, just enough to drain the battery.
I'll definitely try that. Then if not that I'll start doing fuses
13 hours ago, JMO413 said:
Start pulling fuses to you get zero. Then you know what circuit is the culprit.
I have seen multiple times it's the glove box light. Screw falls out of the latch or the latch didn't close good enough.
It wouldn't give me any reading when I had it setup at all. Turns out my battery was defective
XJs/MJs have a dash light that illuminates the green ring around the cigarette lighter.  Normal, if the dash lights are on.  If they are not on, something weird is going on.  Or as Oldmancomanche said, maybe your lighter is jammed in and heating up all the time, which sounds like a recipe for disaster- I'd check that asap.
  • 3 weeks later...
Picture 1 of 1
On 8/12/2021 at 4:10 PM, Muncher said:
I'm on these settings and it's just saying .1 when on the neagitve end to the neagitive cable
This DVOM will only read up to 400mA. Any current higher than this will blow the meter fuse. The DVOM here in the picture is set for µA (mirco amps) and the RED lead is NOT in the correct location for a current reading. RED should be connected to 400mA MAX FUSED terminal.
