Air tank relocation or delete
This ball that use to be on the front bumper where can I relocate it to or can I just get rid of it somehow? I need some room for my winch solenoid. I still have the overflow bottle so that's not avaliable
3 hours ago, fiatslug87 said:
It's required for your HVAC and cruise control to work. People relocate it near the blower motor. Or locate the solenoid box in the engine bay away from water.
Well I would move the solenoid to the engine bay buy there's no room for it really
There is plenty of room UNDER the cab back behind the seats.  It’s going to be a PITA to run vacuum lines back there, and then forward again, but it can be done.
you will also need to protect it in some manner if you ever do serious off-road stuff.  I would suggest locating it just inboard of the “frame” rail on the drivers side, and add a sort of skid plate attached to the “frame” to protect it.
He mentioned vacuum lines so I assume he is refering to the canister.  But either one could be relocated there.  I think vacuum hose is cheaper than wire.....
True. Where would j buy vacuum hose?
Any parts atore should have bulk spools. Just ask them for as many ft as you need.
mine literally just sits loose on top of the relays.  :laugh:   feel free to do better than I, but I wanted to point out that it barely matters where it goes. :L:  just as long as it's there and connected. :D
If your cruise doesnt work (or if you don't care if it does) you can get a smaller vacuum resevoir. Non cruise rigs had one half the size of yours. Rob one from any 60's-80's vehicle. All you need is vacuum in from the engine and vacuum out to the HVAC controls.
Thats sloppy. I put a zip tie through the mounting screw hole and zipped it to the coolant tank bracket.
