88mjsally Posted July 22 Author Posted July 22 Got my new Speedmaster LS6 intake in today. Looks really nice and hopefully will clear the hood
88mjsally Posted July 27 Author Posted July 27 Acquired a year old QuickDraw LS to AX15 adapter kit from one of my buddies. It uses a stock 6.0 clutch setup and flywheel which are on order as well as the pilot bearing
88mjsally Posted July 28 Author Posted July 28 23 hours ago, neohic said: Very rad! Whats the gear ratio in the new rear axle? Pretty sure it is 3.55 which matches the front but I need to pop it open and check as it doesn’t have a tag on it. Worst case I’ll just regear the front to match whatever the rear is
88mjsally Posted Saturday at 07:03 PM Author Posted Saturday at 07:03 PM Old 4.0 is out as of this morning and I got the engine bay cleaned up. Novak engine mounts are installed. Going to bolt the ax15 up to the engine tomorrow hopefully and get it set in its new home
88mjsally Posted Sunday at 07:32 PM Author Posted Sunday at 07:32 PM Had a few issues today. The QuickDraw kit is designed for the newer AX15 and won’t work with out of the box stuff with the older one from what I see. Luckily I had a backup plan which was the factory manual zj. After looking more it’s a rusty pos so I no longer feel bad about pulling the trans out of it. Going to clean it up tomorrow and hopefully get it bolted up to the engine. Clutch is on and one of the perks of this QuickDraw kit is it uses all off the shelf parts which will help down the road
88mjsally Posted Monday at 09:22 PM Author Posted Monday at 09:22 PM Mostly cleaned the transmission and transfer case up today. Didn’t do a great job but they are under the truck so it’ll be okay. Got it all bolted up to the engine and hopefully I’ll be able to set it in tomorrow
coheed Posted yesterday at 02:10 AM Posted yesterday at 02:10 AM 4 hours ago, 88mjsally said: Mostly cleaned the transmission and transfer case up today. Didn’t do a great job but they are under the truck so it’ll be okay. Got it all bolted up to the engine and hopefully I’ll be able to set it in tomorrow I'd venture a guess that this drive line is cleaner than most sitting in MJs across the country lol. When I get the AX15 in my truck I definitely need to make my way down to check this thing out. Absolutely loving this build.
88mjsally Posted yesterday at 10:51 AM Author Posted yesterday at 10:51 AM 8 hours ago, coheed said: I'd venture a guess that this drive line is cleaner than most sitting in MJs across the country lol. When I get the AX15 in my truck I definitely need to make my way down to check this thing out. Absolutely loving this build. I did a really good job cleaning the engine, the rest not so much but oh well you’re probably right lol. Come on down, I moved since last time I saw you so I’m about an hour closer
