How does an ax15 (or any manual trans) shift gears
Jesse J
there are no stupid questions.  a manual trans is actually a very complicated thing. :L:   I mean, the auto trans is powered by simple witchcraft, but a manual has to use regular ol' physics to get the job done. :D
Expand
yeah I am not even going to start thinking about how an auto works
  On 4/1/2021 at 5:58 PM, jdog said:
Expand
thank you very much.
A manual transmission you’re physically pushing the gears back and forth to engage and disengage them.
An automatic is also pretty simple, it just looks very different because planetary gears. You hold onto a couple different parts of the planetary assemblies to change the ratio. The valve body looks complicated, but it’s mostly just because there’s a lot of repetition of the same valves for every band.
  On 4/2/2021 at 3:15 AM, 87MJTIM said:
A guy on youtube has several videos on tearing apart and rebuilding an AX15.  I watched all these before I took apart one.
Expand
I have watched all three videos I need to again my focus isnt the greates
Expand
ok cool thanks
