scaleless Posted April 1, 2021 Share Posted April 1, 2021 I recommend removing it - I managed to smash mine up pretty awful getting my BA10 out because I left it there. Link to comment Share on other sites More sharing options...
james-mc Posted April 1, 2021 Author Share Posted April 1, 2021 10 minutes ago, OldManComanche said: Remove CPS before you unbolt the transmission. Do Crusiers tip on the sensor before you put it back in. (it makes a noticeable difference) Ill have to look into that. CPS is only thing I have left to unhook. Then I'm going to break the bolts loose so theyre ready to go tomorrow for the swap. Link to comment Share on other sites More sharing options...
james-mc Posted April 1, 2021 Author Share Posted April 1, 2021 6 minutes ago, scaleless said: I recommend removing it - I managed to smash mine up pretty awful getting my BA10 out because I left it there. Will do thanks for the advise. Link to comment Share on other sites More sharing options...
james-mc Posted April 1, 2021 Author Share Posted April 1, 2021 Also how much does the ba10 and ax15 weigh individually? I only ask because I will have to haul them in my hatchback unfortunately. Ive read about 100lbs a piece but idk how reliable that is. Link to comment Share on other sites More sharing options...
scaleless Posted April 1, 2021 Share Posted April 1, 2021 4x4 AX15 is about 90lbs, and the BA10 feels slightly lighter than that. 2WD is probably a little heavier, so I bet your 100lb estimate is right on the money. Link to comment Share on other sites More sharing options...
james-mc Posted April 1, 2021 Author Share Posted April 1, 2021 Ok great. Theyre 2WD so id expect them to be a little lighter. Thanks I'm glad I don't have to go rent a truck lol. Link to comment Share on other sites More sharing options...
OldManComanche Posted April 1, 2021 Share Posted April 1, 2021 The 2 bolts on the top of the bell housing are a "PITA" and they have the star head to boot! Link to comment Share on other sites More sharing options...
Jesse J Posted April 1, 2021 Share Posted April 1, 2021 Just now, OldManComanche said: The 2 bolts on the top of the bell housing are a "PITA" and they have the star head to boot! inverse torx I think Link to comment Share on other sites More sharing options...
87MJTIM Posted April 1, 2021 Share Posted April 1, 2021 33 minutes ago, Jesse J said: inverse torx I think E20 is the type and size (or E12) I don’t remember Link to comment Share on other sites More sharing options...
Jesse J Posted April 1, 2021 Share Posted April 1, 2021 1 minute ago, 87MJTIM said: E20 is the type and size (or E12) I don’t remember I heard a 12 point some size socket works in a pinch Link to comment Share on other sites More sharing options...
87MJTIM Posted April 1, 2021 Share Posted April 1, 2021 I have not tried a 12 point. Previously when I removed those bolts I throw them away and get hex head bolts Link to comment Share on other sites More sharing options...
Jesse J Posted April 1, 2021 Share Posted April 1, 2021 well yeah instead of buying an inverse torx use a 12 point get it off and then replace Link to comment Share on other sites More sharing options...
scaleless Posted April 1, 2021 Share Posted April 1, 2021 It's E12, and I don't recommend a 12-point - that sounds like a good way to start rounding the head! Inverse torx sockets are available from Home Depot, Lowes, and most auto parts stores. Also Amazon, of course, if you can wait 2 days. Link to comment Share on other sites More sharing options...
james-mc Posted April 1, 2021 Author Share Posted April 1, 2021 I seen that. I went and bought a set of torx (and inverse torx) sockets for it. I also sprayed some penetrating lubricant on the bolts again last night. I'm hoping that they arent too much of a pain. The guy i got the truck from replaced clutch roughly 3 years ago. I also went and bought a transmission jack just to be safe. Tomorrow I'm going to get this thing dropped and in the evening a friend of mine is gonna come help get the new one in. Link to comment Share on other sites More sharing options...
james-mc Posted April 1, 2021 Author Share Posted April 1, 2021 5 minutes ago, scaleless said: It's E12, and I don't recommend a 12-point - that sounds like a good way to start rounding the head! Inverse torx sockets are available from Home Depot, Lowes, and most auto parts stores. Also Amazon, of course, if you can wait 2 days. I went to harbor freight. So hopefully they survive this job haha. If not my dad has a set of good ones i can pickup. Link to comment Share on other sites More sharing options...
james-mc Posted April 1, 2021 Author Share Posted April 1, 2021 1 hour ago, 87MJTIM said: I have not tried a 12 point. Previously when I removed those bolts I throw them away and get hex head bolts Thats a good idea. Might do that as well. Link to comment Share on other sites More sharing options...
Jesse J Posted April 1, 2021 Share Posted April 1, 2021 19 minutes ago, scaleless said: It's E12, and I don't recommend a 12-point - that sounds like a good way to start rounding the head! Inverse torx sockets are available from Home Depot, Lowes, and most auto parts stores. Also Amazon, of course, if you can wait 2 days. yeah I agree I just heard that somewhere probably won't try that Link to comment Share on other sites More sharing options...
OldManComanche Posted April 1, 2021 Share Posted April 1, 2021 If you strip the head of those, you are going to be in a "fix for sure" trying to get it out. I tried the socket trick with no success. Went to Harbor Freight and bought the socket set and have used 6 or 7 times now. Link to comment Share on other sites More sharing options...
Jesse J Posted April 1, 2021 Share Posted April 1, 2021 inverse torx is so gross like why on earth. Does it stop thieves from stealing your trans Link to comment Share on other sites More sharing options...
james-mc Posted April 1, 2021 Author Share Posted April 1, 2021 5 minutes ago, Jesse J said: inverse torx is so gross like why on earth. Does it stop thieves from stealing your trans I invite any and all thieves to come steal the transmission that's in it. Save me some work. 😂 Link to comment Share on other sites More sharing options...
derf Posted April 1, 2021 Share Posted April 1, 2021 41 minutes ago, Jesse J said: inverse torx is so gross like why on earth. Does it stop thieves from stealing your trans It makes manufacturing easier. Link to comment Share on other sites More sharing options...
Jesse J Posted April 1, 2021 Share Posted April 1, 2021 Just now, derf said: It makes manufacturing easier. how? Link to comment Share on other sites More sharing options...
james-mc Posted April 2, 2021 Author Share Posted April 2, 2021 Just my luck. Last owner swapped the torx for allen head. Off to harbor freight lol Link to comment Share on other sites More sharing options...
james-mc Posted April 2, 2021 Author Share Posted April 2, 2021 Any advise for the CAT mount in the cross member? Looks like it could slide out. Also I leave the straps on the new slave cylinder when installing right? Link to comment Share on other sites More sharing options...
AZJeff Posted April 2, 2021 Share Posted April 2, 2021 On 4/1/2021 at 11:20 AM, Jesse J said: how? The Torx bit was developed by The Camcar division of Textron. It’s design is similar to that of a gear tooth (technically it’s an “involute spline”) and it spreads the fastener driving force over a larger area. The MAIN advantage is that the tools used to drive Torx fasteners last MUCH longer in a production line environment. So now you know....😉 Link to comment Share on other sites More sharing options...
