Huntr Posted March 3, 2021 Posted March 3, 2021 1987 Jeep Comanche Renix 4.0 / BA10 currently being swapped to AX15/ NP231 / Dana 30 Front / Dana 44 Rear / Long bed Door sticker is long gone. Current Location: Northern Utah Status: Awaiting engine swap in the garage. Little to no rust or dents, she's just begging me to be built! Current owner: Me!
eaglescout526 Posted March 3, 2021 Posted March 3, 2021 *A6 Seats -YY 3LR APA MONOTONE PAINT PACKAGE BCQ Battery - 750 Amp Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DDQ Transmission - 5-Speed Manual DMR 4.10 Axle Ratio DSA LIMITED SLIP DIFFERENTIAL ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED MWB SPORT BAR NAA ESA W/CATALYST (EXC CALIF SYSTEM) NMB ENGINE COOLING - STANDARD DUTY PXH QXH SBA POWER STEERING SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE TBL TIRE CARRIER - INSIDE Build date 5/4/87 Body code JL62 Sold by STEVE CHRISTY CHRY-JEEP, TUCSON AZ
fiatslug87 Posted March 3, 2021 Posted March 3, 2021 Interesting, it should have a sport bar from the factory but that's not an OE bar.
Huntr Posted March 3, 2021 Author Posted March 3, 2021 1 hour ago, fiatslug87 said: Interesting, it should have a sport bar from the factory but that's not an OE bar. I thought the same thing after I got it home. It was clearly a full sized bar that has been cut down and welded to fit. I was also wondering about the factory paint color because it’s clearly been repainted at least once but they kept the sportruck decal.
Pete M Posted March 3, 2021 Posted March 3, 2021 if it had a bar from the factory, it would have the extra rollbar mounts found between the frame and the bed. a lot of info was lost before chrysler got it into the computers (something about a basement flood), so your full build sheet is actually much longer.
fiatslug87 Posted March 3, 2021 Posted March 3, 2021 What is the two digit code on the ID plate in the engine compartment in location (1)? That is the paint code on an 87. I think yours was champagne metallic, if you get the code I can confirm.
Huntr Posted March 3, 2021 Author Posted March 3, 2021 11 hours ago, Pete M said: if it had a bar from the factory, it would have the extra rollbar mounts found between the frame and the bed. a lot of info was lost before chrysler got it into the computers (something about a basement flood), so your full build sheet is actually much longer. When I pull the bed off I'll check around for signs of those mounts. Not sure why they would have swapped rollbars. 11 hours ago, fiatslug87 said: What is the two digit code on the ID plate in the engine compartment in location (1)? That is the paint code on an 87. I think yours was champagne metallic, if you get the code I can confirm. Looks like you are correct in it being Champagne Metallic. Where the paint is chipping on the bed it definitely looks like its been through at least 2 other colors though. Thanks for all the help guys!
Pete M Posted March 3, 2021 Posted March 3, 2021 you can just tip your head under the front of the bed. the stock mounts look like this. note that it looks like something should bolt to it? yours will have something there. specifically the second half that the rollbar then bolts to.
Jesse J Posted March 3, 2021 Posted March 3, 2021 3 minutes ago, 89 MJ said: @Jesse J, your MJ brother. Same state even. actually my truck was sold in washington. But YAY another "active" utah cc member theres 4 maybe 5 of us now
Jesse J Posted March 3, 2021 Posted March 3, 2021 but we are buddys in the sense of our trucks being awaiting to be built long beds!
Huntr Posted March 3, 2021 Author Posted March 3, 2021 1 hour ago, Jesse J said: but we are buddys in the sense of our trucks being awaiting to be built long beds! Awesome to see some other people with Comanches so close! Might have to meet up one day after I get my truck further along and driving again. Any plans on cutting down your bed at all? I am highly considering it before I paint mine.
Jesse J Posted March 3, 2021 Posted March 3, 2021 1 hour ago, Huntr said: Awesome to see some other people with Comanches so close! Might have to meet up one day after I get my truck further along and driving again. Any plans on cutting down your bed at all? I am highly considering it before I paint mine. nope keeping all 7' 22 minutes ago, Pete M said: just armor up that @$$ and let it drag EXACTLY
Jesse J Posted March 7, 2021 Posted March 7, 2021 On 3/3/2021 at 11:54 AM, Huntr said: Awesome to see some other people with Comanches so close! Might have to meet up one day after I get my truck further along and driving again. Any plans on cutting down your bed at all? I am highly considering it before I paint mine. now let me ask are you?
Huntr Posted March 7, 2021 Author Posted March 7, 2021 1 minute ago, Jesse J said: now let me ask are you? Planning on shortening it? Not right away, but eventually. I need to get it running and all my suspension moved over from the XJ first. I'm up against a time crunch because I might be moving in the next 6 months so realistically it'll be a year or two haha
Jesse J Posted March 7, 2021 Posted March 7, 2021 2 minutes ago, Huntr said: Planning on shortening it? Not right away, but eventually. I need to get it running and all my suspension moved over from the XJ first. I'm up against a time crunch because I might be moving in the next 6 months so realistically it'll be a year or two haha makes sense I am gonna be on a time crunch come summer
Jesse J Posted March 7, 2021 Posted March 7, 2021 2 minutes ago, Pete M said: I can't sleep in a 6ft bed. tailgate down? also what bed pete
Pete M Posted March 7, 2021 Posted March 7, 2021 I'm just pointing out that a 6" guy doesn't fit in a 6ft bed. that's why I have a 7ft trailer. armor it up and go! if I found myself getting stuck a lot, then I might consider a chop. but I'd for sure try it out first. by the way, this used to be an offroad trailer. the previous owner had it lifted 6" on 33s and dragged it all over the place. I wish he had armored it, but at least he never hacked anything. it wasn't hard to pound out the dents in the lower quarters. looked like this when I bought it (dropped down to regular height of course or I couldn't have pulled it home)
Jesse J Posted March 7, 2021 Posted March 7, 2021 3 minutes ago, Pete M said: but I'd for sure try it out first. yeah same if I ever get hung up on something it's gonna be big. can you build rear skid plates and sliders?
Pete M Posted March 8, 2021 Posted March 8, 2021 you can build anything you want, it just takes steel. can't remember who, but a couple guys on CC have done it kinda recently. years ago I carved up the bed on my wheeler for more clearance. soon after I regretted it because I found it completely unnecessary, but then I made peace with it because it's a rusty hunk of rust that drops rust every time you touch it. I could easily have fabbed a bumper that offered protection rather than thinking I needed to emulate the serious rock crawlers since I don't drive my truck like that.
Pete M Posted March 8, 2021 Posted March 8, 2021 as I like to say when ribbing my buddies with "minimalistic" MJs: anyone can drive a buggy, real men take their whole bed with them.
Jesse J Posted March 8, 2021 Posted March 8, 2021 lol sweet. makes me want to take cad lessons so I can draw something up
Pete M Posted March 8, 2021 Posted March 8, 2021 it's not too difficult either. build/buy a bumper and then build a mini rocker guard on the side. just don't hug the body too much. I've seen guys ruin the sheetmetal because the bumper didn't protrude out far enough to keep that tree at bay when the truck is at a slight angle.
