Pete M Posted February 26, 2021 Share Posted February 26, 2021 pull out partially and it turns on the side/tail markers. all the way turns on the headlights. Link to comment Share on other sites More sharing options...
Muncher Posted February 26, 2021 Author Share Posted February 26, 2021 Oh ok thanks Link to comment Share on other sites More sharing options...
Muncher Posted March 2, 2021 Author Share Posted March 2, 2021 So I'm messing around with my lights again today and when I push on the high low beam switch it turns the high beams off but doesn't turn the low beams off. And also pulling the stalk back does not turn them off completely only pushing the button it self works. Do I jusy need to replace that high low beam switch ? Link to comment Share on other sites More sharing options...
Pete M Posted March 2, 2021 Share Posted March 2, 2021 have you tried pushing directly on the switch with your finger? Link to comment Share on other sites More sharing options...
Muncher Posted March 2, 2021 Author Share Posted March 2, 2021 Yes that's what I did and that's the only way high beams would turn off but low beams wouldn't go on still Link to comment Share on other sites More sharing options...
Pete M Posted March 2, 2021 Share Posted March 2, 2021 does it make an audible click each time? and do you have 12volts at the headlight sockets when the headlight switch is pulled out, but the hi beams are off? Link to comment Share on other sites More sharing options...
Muncher Posted March 3, 2021 Author Share Posted March 3, 2021 3 hours ago, Pete M said: does it make an audible click each time? and do you have 12volts at the headlight sockets when the headlight switch is pulled out, but the hi beams are off? Yes I do belive remembering a click sound when pushing it with my finger or even with using the stalk. I'm not sure about the 12 volts In the socket ill have to find a multimeter and test that out tommrow. Link to comment Share on other sites More sharing options...
Rad_Comanche Posted March 3, 2021 Share Posted March 3, 2021 Following, I have a similar problem. My new high beam switch gets here tomorrow. I had high beams that would not turn off, but when I finally figured out where the switch was, neither lows or highs were working. Probably something to do with me tearing into the column. Hopefully we can find a solution for both our trucks. Link to comment Share on other sites More sharing options...
Muncher Posted March 3, 2021 Author Share Posted March 3, 2021 2 hours ago, Rad_Comanche said: Following, I have a similar problem. My new high beam switch gets here tomorrow. I had high beams that would not turn off, but when I finally figured out where the switch was, neither lows or highs were working. Probably something to do with me tearing into the column. Hopefully we can find a solution for both our trucks. yeah for me its just been low beams don't work. even before i converted to led lights my halogens didn't have low beam either Link to comment Share on other sites More sharing options...
Muncher Posted March 4, 2021 Author Share Posted March 4, 2021 Alright update on this problem is that I think I had low beams the whole time but not high beams. I jusy went to hook up the onboard running lights and blinker in my head lights and for some reason I magically have high beams now but my blinker also constantly stays on when thr light turn on and they won't blink all the way around the truck. What should I do now? Link to comment Share on other sites More sharing options...
Muncher Posted March 4, 2021 Author Share Posted March 4, 2021 Definitely need some help with this one Link to comment Share on other sites More sharing options...
jdog Posted March 4, 2021 Share Posted March 4, 2021 What wires are you using? Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 4, 2021 Share Posted March 4, 2021 Have you replaced the turn signal sockets? Link to comment Share on other sites More sharing options...
Muncher Posted March 4, 2021 Author Share Posted March 4, 2021 14 minutes ago, eaglescout526 said: Have you replaced the turn signal sockets? No I haven't done that. Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 4, 2021 Share Posted March 4, 2021 6 minutes ago, Muncher said: No I haven't done that. Renix era front sockets are notorious for ground failure. There’s the later/earlier style front sockets that are better and made out of metal. Link to comment Share on other sites More sharing options...
Muncher Posted March 4, 2021 Author Share Posted March 4, 2021 17 minutes ago, jdog said: What wires are you using? Do you mean what gauge? Link to comment Share on other sites More sharing options...
Muncher Posted March 4, 2021 Author Share Posted March 4, 2021 4 minutes ago, eaglescout526 said: Renix era front sockets are notorious for ground failure. There’s the later/earlier style front sockets that are better and made out of metal. I'll have to get some. Is this something I can jusy get at a parts store or online Link to comment Share on other sites More sharing options...
Muncher Posted March 4, 2021 Author Share Posted March 4, 2021 I'm guessing it might be socket failure because when the running light is attached to the marker lights but not the blinker it's on but as soon as I hook up the blinker to the light it jjsy over powers the running light with a solid orange Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 4, 2021 Share Posted March 4, 2021 Yes. The sockets are readily available. Just search Cherokee XJ turn signal socket. Link to comment Share on other sites More sharing options...
Jesse J Posted March 4, 2021 Share Posted March 4, 2021 got mine at quadretec Link to comment Share on other sites More sharing options...
Muncher Posted March 4, 2021 Author Share Posted March 4, 2021 I might do that anyways but I let my truck run and now there all blinking again. Except one of the front ones that I kinda broke trying to take the bulb out Link to comment Share on other sites More sharing options...
Muncher Posted March 4, 2021 Author Share Posted March 4, 2021 I think I might of basically solved my problem but I don't even know how I did it. I won't complain tho Link to comment Share on other sites More sharing options...
Pete M Posted March 4, 2021 Share Posted March 4, 2021 problems that fix themselves are problems that can come back whenever they feel like it Link to comment Share on other sites More sharing options...
Muncher Posted March 4, 2021 Author Share Posted March 4, 2021 3 minutes ago, Pete M said: problems that fix themselves are problems that can come back whenever they feel like it Yeah thats true. I'm still not even really sure what could of been causing it because all I did today was splice wires into the headlight from the blinkers and markers and then I decided to pull the stalk back randomly and they were jusy working Link to comment Share on other sites More sharing options...
