jeepin4on4 Posted January 7, 2021 Posted January 7, 2021 I dug this one out of the back today and put it in the shop. I forgot about what the interior looked like then i saw the hocky stick arm rest, after wiping off the 5 years of dirt i found this embedded label. Anyone have them? If so info would be helpful (can't find it on the web) Thanks and I'll add more pictures as I clean her up. Unknown what build this one will end up as, the bed is very rough and damaged.
Pete M Posted January 7, 2021 Posted January 7, 2021 nice! you should probably post that Q in the Tech forum where more eyes will see it
eaglescout526 Posted January 7, 2021 Posted January 7, 2021 *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ ADA LIGHT PACKAGE ADL SKID PLATE GROUP AGY Seating Group AHL HEAVY DUTY INSUL PACKAGE AJZ AWE BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DGY Transmission - 3-Spd. Automatic DSA LIMITED SLIP DIFFERENTIAL EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I MWB SPORT BAR NAE EMISS CONTROL TESTING &&&&&&&& LABEL NFA TANK - 23 GAL FUEL NHB AUX./H.DTY TRANS OIL COOLER NHM AUTO SPEED CONTROL NMC MAX ENGINE COOLING RAF RADIO - AM/FM/MTR SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE SUA TILT STEERING COLUMN WJM Wheels - 15 x 7.0 Chrome Build date 1/14/86 Body code JP62
jeepin4on4 Posted January 7, 2021 Author Posted January 7, 2021 Great, Thanks MJ team! @Rylee144, From the vague info i got when i picked it up your right, it was at a garage sale ($100.00) and they had a lot of dirt bike stuff. Found this one in Riverside California, closer to Palm Springs i think. They probably cut/fused the logo into the arm rest. It also has custom seat belts similar to harness type with the quick release.
Pete M Posted January 7, 2021 Posted January 7, 2021 7 minutes ago, jeepin4on4 said: Great, Thanks MJ team! @Rylee144, From the vague info i got when i picked it up your right, it was at a garage sale ($100.00) and they had a lot of dirt bike stuff. Found this one in Riverside California, closer to Palm Springs i think. They probably cut/fused the logo into the arm rest. It also has custom seat belts similar to harness type with the quick release. I've tweaked the results to better reflect the known mistakes in Jeep's computers. of course your full build sheet is even bigger than what pops up. we lost a lot of info before it ever got into chrysler's computer system.
Pete M Posted January 13, 2021 Posted January 13, 2021 no way! On 1/6/2021 at 11:50 PM, jeepin4on4 said: I dug this one out of the back today and put it in the shop. I forgot about what the interior looked like then i saw the hocky stick arm rest, after wiping off the 5 years of dirt i found this embedded label. Anyone have them? If so info would be helpful (can't find it on the web) Thanks and I'll add more pictures as I clean her up. Unknown what build this one will end up as, the bed is very rough and damaged. can you snap a photo of the t-case lever area?
Rusty Posted January 17, 2021 Posted January 17, 2021 I have a 1986 AMC Jeep Comanche x 4 wheel drive pickup,in very good shape how rare is that?
BeatCJ Posted January 18, 2021 Posted January 18, 2021 Well, there were less than 200,000 built. How many are left is hard to tell. Most of them were built in the first 4 model years, so, about 40,000 '86s. A lot of the 2.8 liter trucks have had engine problems. Rare? Probably not. Common? Not Even. Post up your own VIN in the registry, you will get your build sheet. Even if it's not rare, it's worth preserving. The Comanche was easily the best small truck available at that time. Personally, I think the concept still holds up well. There isn't anything comparable available today, which I'm(NS)HO, is a shame.
