fiatslug87 Posted December 22, 2020 Share Posted December 22, 2020 Pick-n-Pull - Salt Lake City Link to comment Share on other sites More sharing options...
Jesse J Posted December 22, 2020 Share Posted December 22, 2020 bruh I have to go there right now Link to comment Share on other sites More sharing options...
89 MJ Posted December 22, 2020 Share Posted December 22, 2020 Just now, Jesse J said: bruh I have to go there right now Run, run fast! Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 22, 2020 Share Posted December 22, 2020 1 minute ago, Jesse J said: bruh I have to go there right now Run Luke, run! Link to comment Share on other sites More sharing options...
Jesse J Posted December 22, 2020 Share Posted December 22, 2020 Just now, 89 MJ said: Run, run fast! I just texted my friend to see If he can gimme a ride. bro my heart is pumping Link to comment Share on other sites More sharing options...
Jesse J Posted December 22, 2020 Share Posted December 22, 2020 should I see If I can pull the ax 15 out of it because I want one really bad for mine? Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 22, 2020 Share Posted December 22, 2020 Easy. 18mm bolts all around for the bellhouse to engine. Link to comment Share on other sites More sharing options...
Jesse J Posted December 22, 2020 Share Posted December 22, 2020 5 minutes ago, eaglescout526 said: Easy. 18mm bolts all around for the bellhouse to engine. anything else I need oh manual swap wizard? Link to comment Share on other sites More sharing options...
89 MJ Posted December 22, 2020 Share Posted December 22, 2020 12 minutes ago, Jesse J said: I just texted my friend to see If he can gimme a ride. bro my heart is pumping 11 minutes ago, Jesse J said: should I see If I can pull the ax 15 out of it because I want one really bad for mine? Hell yeah you should! Be sure to grab the pedals and driveshafts (only grab the front if its a shortbed) too. You will need them for your swap. 5 speed for the win! Link to comment Share on other sites More sharing options...
Pete M Posted December 22, 2020 Share Posted December 22, 2020 12 minutes ago, Jesse J said: should I see If I can pull the ax 15 out of it because I want one really bad for mine? it's an 88 which got the peugeot from the factory Link to comment Share on other sites More sharing options...
Jesse J Posted December 22, 2020 Share Posted December 22, 2020 Just now, Pete M said: it's an 88 which got the peugeot from the factory dangit aww well. lIkely I'll go tomorrow I need to cash a paycheck first and just everything so Idk might grab the steering column though Link to comment Share on other sites More sharing options...
Pete M Posted December 22, 2020 Share Posted December 22, 2020 1 minute ago, Jesse J said: dangit aww well. lIkely I'll go tomorrow I need to cash a paycheck first and just everything so Idk might grab the steering column though it's possible it's been swapped. can't know for sure without crawling underneath. Link to comment Share on other sites More sharing options...
Jesse J Posted December 22, 2020 Share Posted December 22, 2020 3 minutes ago, 89 MJ said: Hell yeah you should! Be sure to grab the pedals and driveshafts (only grab the front if its a shortbed) too. You will need them for your swap. 5 speed for the win! yeah Hopefully it has a tan interior but unlikely. Link to comment Share on other sites More sharing options...
89 MJ Posted December 22, 2020 Share Posted December 22, 2020 Just now, Jesse J said: dangit aww well. lIkely I'll go tomorrow I need to cash a paycheck first and just everything so Idk might grab the steering column though It wouldn't hurt to check the trans though. Here is a pic of the Ax-15 and BA10. The BA10 is on the right. The difference is circled. Link to comment Share on other sites More sharing options...
Jesse J Posted December 22, 2020 Share Posted December 22, 2020 Just now, Pete M said: it's possible it's been swapped. can't know for sure without crawling underneath. hopefully Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 22, 2020 Share Posted December 22, 2020 18mm for the bell house 16 or 17 for the trans to cross member mount 15mm for the cross member to frame. Link to comment Share on other sites More sharing options...
89 MJ Posted December 22, 2020 Share Posted December 22, 2020 Holy cow, we all were commenting on this at the same time. That was wild. I just read through all of this and Pete and I are pretty much saying the same thing. Link to comment Share on other sites More sharing options...
89 MJ Posted December 22, 2020 Share Posted December 22, 2020 Grab the crossmember too if it is an AX-15, they are different from the other transmissions! Link to comment Share on other sites More sharing options...
89 MJ Posted December 22, 2020 Share Posted December 22, 2020 Bring plenty of extensions to get the trans out too, if you get it. Link to comment Share on other sites More sharing options...
Jesse J Posted December 22, 2020 Share Posted December 22, 2020 Just now, 89 MJ said: Bring plenty of extensions to get the trans out too, if you get it. oh yeah Me and my dad just bought a bunch of mac sockets and extensions and a milwaulkee 1/2 impact and 3/8 ratchet and some mat co combo wrenches Link to comment Share on other sites More sharing options...
Jesse J Posted December 22, 2020 Share Posted December 22, 2020 how much wil they charge me for the trans if if it where an ax 15 Link to comment Share on other sites More sharing options...
Pete M Posted December 22, 2020 Share Posted December 22, 2020 be sure to undo all the interior and then remove the stickshift tower before dropping the trans/crossmember. you'll only forget to do that once. Link to comment Share on other sites More sharing options...
89 MJ Posted December 22, 2020 Share Posted December 22, 2020 Just now, Jesse J said: oh yeah Me and my dad just bought a bunch of mac sockets and extensions and a milwaulkee 1/2 impact and 3/8 ratchet and some mat co combo wrenches Good. Bring as much as you can to the JY. These Jeeps don't like giving up their parts easily. Link to comment Share on other sites More sharing options...
Pete M Posted December 22, 2020 Share Posted December 22, 2020 Just now, Jesse J said: how much wil they charge me for the trans if if it where an ax 15 at a self serve? 75-150. Link to comment Share on other sites More sharing options...
89 MJ Posted December 22, 2020 Share Posted December 22, 2020 Just now, Jesse J said: how much wil they charge me for the trans if if it where an ax 15 Maybe $200 on the high end. Anything less than $300 would probably be a good deal though. Link to comment Share on other sites More sharing options...
