Tex06 Posted October 21, 2020 Author Share Posted October 21, 2020 On 10/19/2020 at 6:34 PM, MiNi Beast said: screw in a tire? Nope, all 4 are good. Plus the engine loading wouldn't change things for a screw. Link to comment Share on other sites More sharing options...
Tex06 Posted October 21, 2020 Author Share Posted October 21, 2020 2 hours ago, ghetdjc320 said: Just put in the slip yoke at the very least. The tcase will pump oil out of the rear output of nothing is there Good to know. I'll have to see if I have a spare one laying around....my press is in storage in a different state. Link to comment Share on other sites More sharing options...
Tex06 Posted October 21, 2020 Author Share Posted October 21, 2020 4 hours ago, Wounded_Fighter said: It will still leak some because of the downward lean towards the back end. With driving it will spin the fluid also so you'll have the lovely "leak line" on the under carriage too. "Some" fluid. Very relatively. If its a lot. You may hear new noises from transmission. 😆 I think you mean transfer case Link to comment Share on other sites More sharing options...
Tex06 Posted October 21, 2020 Author Share Posted October 21, 2020 16 hours ago, Pete M said: it was super, duper obvious on the Libby just by grabbing the driveshaft and shaking. I've got a big of slop rotationally but not seeing anything in the ujoint itself. 13 hours ago, ghetdjc320 said: Double check your engine to tranny bolts and tranny to tcase bolts. I had tranny bolts be a little loose that caused this issue. Will do. Think I can get to most of those without any special tools (going off memory). Link to comment Share on other sites More sharing options...
ghetdjc320 Posted October 21, 2020 Share Posted October 21, 2020 7 hours ago, Tex06 said: Good to know. I'll have to see if I have a spare one laying around....my press is in storage in a different state. A 3.5lb hammer works just as well . That’s the “trail fix” I use. Link to comment Share on other sites More sharing options...
Wounded_Fighter Posted October 22, 2020 Share Posted October 22, 2020 23 hours ago, Tex06 said: I think you mean transfer case Well yes ... if its 4x4 Link to comment Share on other sites More sharing options...
BeatCJ Posted October 22, 2020 Share Posted October 22, 2020 On 10/21/2020 at 4:36 AM, ghetdjc320 said: Just put in the slip yoke at the very least. The tcase will pump oil out of the rear output of nothing is there I'm pretty sure it wouldn't stay in, only the driveline retains it. Of course, I bet if you pull the drive line, you will find a bad ujoint if you have one. Link to comment Share on other sites More sharing options...
Airborne Janitor Posted October 24, 2020 Share Posted October 24, 2020 I once cut a plastic bottle in half and taped it to the back end of the case to keep some of the fluid in. Link to comment Share on other sites More sharing options...
Tex06 Posted October 26, 2020 Author Share Posted October 26, 2020 On 10/23/2020 at 9:53 PM, Airborne Janitor said: I once cut a plastic bottle in half and taped it to the back end of the case to keep some of the fluid in. Not the first time I've seen this mentioned. Will be my solution, I'll have pics, etc. when I get around to it! Link to comment Share on other sites More sharing options...
Tex06 Posted October 27, 2020 Author Share Posted October 27, 2020 Well.... not the front driveshaft. Moving on to the rear tomorrow.... Link to comment Share on other sites More sharing options...
Tex06 Posted October 30, 2020 Author Share Posted October 30, 2020 Welp, turns out it was the slip yoke ujoint. $118 later the jeep runs smooth as butter again. Link to comment Share on other sites More sharing options...
Pete M Posted October 30, 2020 Share Posted October 30, 2020 hurray! Link to comment Share on other sites More sharing options...
MiNi Beast Posted October 30, 2020 Share Posted October 30, 2020 nice. 🤑 so who called it? Link to comment Share on other sites More sharing options...
rokinn Posted October 30, 2020 Share Posted October 30, 2020 8 hours ago, MiNi Beast said: nice. 🤑 so who called it? Link to comment Share on other sites More sharing options...
Tex06 Posted November 4, 2020 Author Share Posted November 4, 2020 On 10/16/2020 at 1:55 AM, MiNi Beast said: I'm thinking bent fingers on pressure plate. or pilot bearing. how in depth was your clutch repairs? On 10/19/2020 at 6:34 PM, MiNi Beast said: screw in a tire? On 10/30/2020 at 3:09 AM, MiNi Beast said: nice. 🤑 so who called it? Not this guy Link to comment Share on other sites More sharing options...
