auto-matik Posted October 14, 2007 Share Posted October 14, 2007 I've got an 89 Comanche Shortbed running 28 inch wheels. I'm looking to lift the front about 4 inches and the rear 3-5 inches. I was wondering if anyone has any advice on kits, or anything? Thanks! Link to comment Share on other sites More sharing options...
Geonovast Posted October 14, 2007 Share Posted October 14, 2007 Easiest way to do the rear is just do an SOA setup, which will give you(from what I understand) 4-4.5 inches. I'm sure someone will chime in for a front lift, I haven't done one... ...yet. Link to comment Share on other sites More sharing options...
MiNi Beast Posted October 14, 2007 Share Posted October 14, 2007 Well, first what do you want to do with the truck? What you want lift for? Just bigger tires? LOOks? Weekend wheeling? Hard wheeling? What give some idea of what your going for and people can help you out. :nuts: Link to comment Share on other sites More sharing options...
FxRacing282 Posted October 14, 2007 Share Posted October 14, 2007 I've got an 89 Comanche Shortbed running 28 inch wheels. 28 inch wheels eh?? soa is not the easiest but imo the best... it will give you about 4 1/2'' to 5'' lift and you could run 32's nicely. or you could buy a 4'' kit for around $450 front lift best idea would be to buy an AAL kit if you want to do a SOA and then bring your AAL to the junkyard and get what its worth Link to comment Share on other sites More sharing options...
Lenard Posted October 15, 2007 Share Posted October 15, 2007 since we are on the topic of lifts... i want to lift my manche to, i was just figuring on doing the SOA for the back, i've been told that i have torshin bars (sp?) on the front, can i just crank those up without having to replace shocks or the coil springs? Link to comment Share on other sites More sharing options...
Pete M Posted October 15, 2007 Share Posted October 15, 2007 No torsions on an MJ, you've got coils up front, leafs in back. Link to comment Share on other sites More sharing options...
jeepthing07 Posted October 15, 2007 Share Posted October 15, 2007 I thought about doing s SOA on mine but desided against it because i dident want to go long arms on the front. i have like 4.5" lift in the front and my short arms look about like this / lol. i just stuck a 3.5" add a leaf and lift shackles in the rear and 3" coil and a spacer up front. lifting coil sprung stuff is a pita jeep should have stuck to leaves. Link to comment Share on other sites More sharing options...
jtdesigns Posted October 15, 2007 Share Posted October 15, 2007 I've got an 89 Comanche Shortbed running 28 inch wheels. I'm looking to lift the front about 4 inches and the rear 3-5 inches. I was wondering if anyone has any advice on kits, or anything? Thanks! 28 " Wheels!!??!!??!! Your truck is going to look like a bis a$$ roller skate! You need to call pimp my ride and have them do it for free! BIG DADDY PIMPING!!! 8) Link to comment Share on other sites More sharing options...
87manche Posted October 15, 2007 Share Posted October 15, 2007 I thought about doing s SOA on mine but desided against it because i dident want to go long arms on the front. i have like 4.5" lift in the front and my short arms look about like this / lol. i just stuck a 3.5" add a leaf and lift shackles in the rear and 3" coil and a spacer up front. lifting coil sprung stuff is a pita jeep should have stuck to leaves. agreed, the primary reason I stayed SUA when I put the 8.8 in is because of the front. It's cheap and easy to SOA the rear, but at the 6" of lift you're gonna get the front becomes expensive. You're looking at drop brackets or long arms at that height to get the ride quality back. Your stock steering will hate life (mine does at 4") Link to comment Share on other sites More sharing options...
FxRacing282 Posted October 15, 2007 Share Posted October 15, 2007 well you can do an SOA and then you could put on XJ shackles. I'm sure most XJ owners would love to trade you Link to comment Share on other sites More sharing options...
Pete M Posted October 15, 2007 Share Posted October 15, 2007 well you can do an SOA and then you could put on XJ shackles. I'm sure most XJ owners would love to trade you That would limit flex and drop the rear all of 1/2". Using 2wd MJ leaf packs would net 1" less lift (depending on the condition of the leaf packs in question). Or you could make a bastard pack from the 4wd leafs and Explorer leafs to lessen the overall lift. Link to comment Share on other sites More sharing options...
FxRacing282 Posted October 15, 2007 Share Posted October 15, 2007 yep its true... I'm begining to think that a 3'' lift with a leaf pack would be enough Link to comment Share on other sites More sharing options...
clarence Posted October 15, 2007 Share Posted October 15, 2007 auto-matik Posted: Sun Oct 14, 2007 10:57 am Post subject: Stock Manche needs a lift! -------------------------------------------------------------------------------- I've got an 89 Comanche Shortbed running 28 inch wheels. I'm looking to lift the front about 4 inches and the rear 3-5 inches. I was wondering if anyone has any advice on kits, or anything? Thanks! If your going to be running 28 inch wheels your definately not going to be driving off road. That just wouldnt work out to well for you lol. You could just get a rc 3 in lift for just around $250 and thats a damn good lift and itll clear those rims just fine... However why are you putting rims like those on a jeep and not something else? don't see that very often lol. anyways here's the html for that lift and that site. http://roughcountry.com/Jeep_MJ_3in.htm Link to comment Share on other sites More sharing options...
Oizarod115 Posted October 15, 2007 Share Posted October 15, 2007 aiight, c'mon guys, just a guess... but considering a 235/75r15 is like a 28.5ish " tire, and that's stock-ish i'll take a wild stab that he meant tires not rims ;) :cheers: although 28's on one of these would be pretty funny... (as a prank.) Link to comment Share on other sites More sharing options...
auto-matik Posted October 21, 2007 Author Share Posted October 21, 2007 lol, yah I meant tires. For the moment I am considering 2" spacers in the front, and a shackle lift in the back. Right now, with a stock sway bar I get 40 degrees of flex, between the front and rear axles. By 2010, I hope to have a SOA, A proper front lift, new shocks all around, a rear locker, a disconecting sway bar (60 degrees of flex!?!?!?!) etc After the lift, I will be putting on 30" all terrain pro comps all around. However, for the weekend, I will be using 10x33" Mud Terrains for extra grab. She's just a trail blazin sonofagun, not a rock crawler! thanks for the advice!!! Link to comment Share on other sites More sharing options...
jtdesigns Posted October 21, 2007 Share Posted October 21, 2007 I figured you were talking about tires but I had to put my imagination goggles on and couldn't help it... 8) Link to comment Share on other sites More sharing options...
FxRacing282 Posted October 21, 2007 Share Posted October 21, 2007 well if its a trail rid then get the sawz-all out can start cutting! Link to comment Share on other sites More sharing options...
pingpong Posted October 21, 2007 Share Posted October 21, 2007 YOu can clear 30's with no lift, and with longer shocks and bump stopping it does all right :brows: :nuts: For a cheap lift.. I think 2" chevy drop shackles, and a 2" poly spacer upfront will be perfect. Just make sure you install longer brake lines and longer shocks :D Link to comment Share on other sites More sharing options...
Pete M Posted October 21, 2007 Share Posted October 21, 2007 And check your alignment. Any height adjustment will alter it. Link to comment Share on other sites More sharing options...
clarence Posted October 21, 2007 Share Posted October 21, 2007 if you want to run 28 in tires you can do that stock... And if you have a soa you can run 33ish Link to comment Share on other sites More sharing options...
