Chunk, A 1984 XJ
  • Replies 434
2 hours ago, Eagle_SX4 said:
Cool no headrests. Heard that was an option.
It was actually. Looking at one of my accessory catalogs, there’s a section on headrests for the XJ, you can get a kit of headrests without material on them and then you could buy the material as a kit, which explains the one headrest kit I have.
How in the hell do y’all do transmission work with the t-case still attached!? Haha.
i had to replace the front bearing gasket on the transmission and that was a fun 5 1/2 hours of labor to just change a gasket. But bright side, no leaks and all systems normal on the system sentry! Hopefully I shouldn’t have gear oil leaking again.
  • 4 weeks later...
Discovered this gem today
Yeah! 6 month old clutch disc just broken. Not sure how or why but just broke. Not even from China either. Looks like it was made in Brazil. Guess I put the old one in and run it for a little while.
