ratty Posted March 9, 2020 Posted March 9, 2020 Hello. I have been having an issue with my 88 Comanche. 1 out of 5 times (more or less) when I start my engine, the rpms rise to 4000 and stay there until I unplug the 3 prong part of the TPS sensor. My truck is an automatic so it has the 3 and 4 prong clips. After I unplug it, the rpms go back down to normal. I plug it back in and everything is fine. I thought my sensor was bad so I just replaced it with a new one. But lo and behold the same thing happened when I went to start my truck, testing out the new sensor. I'm not sure what to check now. Any help would be appreciated. Thanks.
BeaterComanche86 Posted March 9, 2020 Posted March 9, 2020 http://cruiser54.com/?p=54 From @cruiser54 website
ratty Posted March 9, 2020 Author Posted March 9, 2020 36 minutes ago, BeaterComanche86 said: http://cruiser54.com/?p=54 From @cruiser54 website Thanks. Just tried this but am still having the issue
BeaterComanche86 Posted March 9, 2020 Posted March 9, 2020 I personally haven’t had this issue yet but I’m sure more knowledgeable folks will chime in.
ratty Posted March 10, 2020 Author Posted March 10, 2020 2 hours ago, BeaterComanche86 said: I personally haven’t had this issue yet but I’m sure more knowledgeable folks will chime in. Hope so. It's pretty annoying..
54bobby Posted March 10, 2020 Posted March 10, 2020 not sure if this would apply but did you disconnect the battery so the ecu can relearn and recognize the new tps?
jdog Posted March 10, 2020 Posted March 10, 2020 http://cruiser54.com/?p=94Have you verified this yet?Will it do it if you unplug the idle solenoid?
ratty Posted March 10, 2020 Author Posted March 10, 2020 10 hours ago, 54bobby said: not sure if this would apply but did you disconnect the battery so the ecu can relearn and recognize the new tps? Haven't done this but I'll give it a shot
ratty Posted March 10, 2020 Author Posted March 10, 2020 10 hours ago, jdog said: http://cruiser54.com/?p=94 Have you verified this yet? Will it do it if you unplug the idle solenoid? I'l have to try this too. Thanks
87MJTIM Posted March 11, 2020 Posted March 11, 2020 11 minutes ago, cruiser54 said: REnix ECU is dumb. Do Tip 5. That’s not PC. Instead, call it “technologically challenged “
ratty Posted March 11, 2020 Author Posted March 11, 2020 8 hours ago, cruiser54 said: REnix ECU is dumb. Do Tip 5. seems to be working pretty good now 🤞
JMO413 Posted March 11, 2020 Posted March 11, 2020 9 hours ago, cruiser54 said: Pelosificated. 9 hours ago, 87MJTIM said: That’s not PC. Instead, call it “technologically challenged “ "Intellectually challenged" is my PC version.
87MJTIM Posted March 11, 2020 Posted March 11, 2020 In today's world of the internet and smart phones, these trucks are using DOS. They were smart...for their time.
eaglescout526 Posted March 11, 2020 Posted March 11, 2020 Just now, 87MJTIM said: DOS Lol more like ROS. HO would be like Windows 3.
cruiser54 Posted March 11, 2020 Posted March 11, 2020 2 hours ago, ratty said: seems to be working pretty good now 🤞 Meaning?
ratty Posted March 11, 2020 Author Posted March 11, 2020 15 minutes ago, cruiser54 said: Meaning? Haven't had the same problem before posting. Every start up so far has been as it should be. We'll see.
