Something odd about my bored throttle body
Renix engine, of course. With a bored out throttle body that I got from another member AGES ago (probably 5 years)
No idea who made it.
But I've been having a rough idle on my Jeep, and I had a rough idle with my last Jeep that I had this throttle body on. I've spent months and 100's of $'s trying to figure it out. Just did a smoke test and there was no vacuum leaks in my system, that was the final test since I finally built a smoke machine. But I looked at the throttle body and realized a difference it had compared to the stock TB.
There's a plastic plug squeezed into the passage way for the hidden star-bit air bleed (or whatever it's called). Does anyone else have a bored out TB like this? Or could this be the reason my Jeep always seems to be struggling for air?
Well. I ended up removing it because I was driving and the rough idle just frustrated me to the point of no return. Amazingly enough, the engine runs PHENOMENALLY now. My idle is a little high (900 or so) but I can resolve that with some toying around. I have more seat-of-the-pants power and the engine sounds much healthier. Plus it does not bog down now when I run my headlights and heat on high.
Good call on NOT listening to me. I learned something today.
So did I! Upon looking at the TB very closely, I noticed the reason why the creator of this bored out TB had put that plug in; they must have thinned the wall out too much on the side with the hole for the air bleed valve because the valve does not seat very tightly anymore. I'm going to reset my butterfly valve and TPS to see if this helps with the higher idle. But if it doesn't, I'm not worried about it. I'd rather this idle than it trying to stall out all the time.
1 hour ago, cruiser54 said:
That was a common practice years ago. Epoxy has sometimes been used to fill that hole also.
Watch carefully when turning that air screw in that it doesn't hit the butterfly.
That's what I noticed when I was adjusting it. Why was it a common practice? What did it solve?
not to threadjack but i will.
on the lower photo, what is the very small hole on the inside of the carb throat for? my 87 2.5 has been, what seems to be flooding out when trying to be restarted after it's warm and fuel squirts up out of this whole.
Oh man, I remember selling this TB to you years ago. So glad to see it's still being used. The TB was bored by Leigh Performance Machines, and when I ran it, I didn't have those issues, but that's not to say that little plug should be there. I figured he had put it there for some reason, and never really messed with it. Hopefully you figure out the issue, bud.
That's the way Jeff did them. I ended up pulling the plug from the top and using the screw on the side for idle air adjustment. There was something about the needle tip being too long and getting in the way of the butterfly. IIRC, I shortened it.
It's been running 10x better since I removed the plug. Still a lil rough of an idle but at least now it sits at a good number and doesn't bog down. Also has a lot more power and my cowl intake is louder due to the amount of air the engines getting. I had to use my winch to pull myself out of a ditch last weekend and the engine didn't bog at all. Usually using the winch it bogs down and tries to die.
2.5 is a throttle body injection motor and has a different TB. you should include a shot of yours so we can tell what you mean. :L:
Have you exposed the Torx headed screw on the side?
Not much of one anymore. Sorry if I seemed to hint that there was still an issue. Jeeps running better than it has in a long time now. Just still has a kind of rough idle and a slight miss when warmed up. Pretty sure it's the low compression I found in #3 and #6 cylinder. Only 95 psi.
In fact, the Renix 2.5L is so much different from the Renix 4.0L that you should start a separate thread to discuss your issue.
