BizarroStormy Posted December 10, 2019 Share Posted December 10, 2019 So while I was working on all the other stuff that is wrong with my front end (steering everything), I decided to replace the universal joints in the front axle while they are out. I have never replace U-joints before and I bodged the job pretty badly on my passenger side. One of the needle bearings popped out while I was pressing it back in and it jammed the whole thing up. Then when I was pressing it out the cap cracked and I ended up pounding it out in pieces. This left a nice ridge in the end where the bearing cap sits, it also looks like the metal is cracked from my overzealous use of the press. Is this a total loss or can I just sand out the ridge? If so, where can I find a replacement? The casting is Spicer 41933 which I cannot find online. Link to comment Share on other sites More sharing options...
Pete M Posted December 10, 2019 Share Posted December 10, 2019 Is that the stock shaft? If so I would stop the presses and hit the junkyards for a complete set of later model XJ or TJ shafts that take the bigger Ujoints. and every time I change a ujoint I swear I'll never do it again. and then time passes... and I do it again... I despise doing ujoints. Link to comment Share on other sites More sharing options...
derf Posted December 10, 2019 Share Posted December 10, 2019 It's an opportunity to upgrade. You can buy aftermarket shafts with bigger u-joints. Stronger shafts with stronger joints are always a good upgrade. But they're a few hundred bucks for the set. Swapping out to later XJ/TJ shafts is a cheaper option but you still want to swap u-joints while they're out. Maybe have a shop do it for you. Link to comment Share on other sites More sharing options...
BizarroStormy Posted December 10, 2019 Author Share Posted December 10, 2019 Thanks for the advice, I guess upgrading is never a bad idea. How much of a liability is the old smaller U-joint? I don't plan on doing anything too crazy in it and I managed to replace the driver side U-joint successfully. Link to comment Share on other sites More sharing options...
Pete M Posted December 11, 2019 Share Posted December 11, 2019 what tires are you running? p.s. you should put some details in your signature Link to comment Share on other sites More sharing options...
AZJeff Posted December 11, 2019 Share Posted December 11, 2019 7 hours ago, Pete M said: Is that the stock shaft? If so I would stop the presses and hit the junkyards for a complete set of later model XJ or TJ shafts that take the bigger Ujoints. and every time I change a ujoint I swear I'll never do it again. and then time passes... and I do it again... I despise doing ujoints. I agree, and even with a ball joint/u-joint press, it’s a pain. I have gotten more careful over the years, after trashing a few yokes the one in the photo from the OP. I also always clean the bores of the yokes with sandpaper or emery cloth before a press in the new cups. Link to comment Share on other sites More sharing options...
BizarroStormy Posted December 11, 2019 Author Share Posted December 11, 2019 8 hours ago, Pete M said: what tires are you running? p.s. you should put some details in your signature I am running 31x10.50R15LT WILDPEAK A/T3W. I don't plan on lifting the truck or putting any larger tires on it. I will work on my signature, I was planning on creating a project post after I got the front back together. Link to comment Share on other sites More sharing options...
Warren Mohler Posted December 11, 2019 Share Posted December 11, 2019 16 hours ago, BizarroStormy said: the metal is cracked from my overzealous use of the press. quit using a press, 4 lb. hammer and 6 inch bench vise is all that is needed Link to comment Share on other sites More sharing options...
JustEmptyEveryPocket Posted December 11, 2019 Share Posted December 11, 2019 3 hours ago, Warren Mohler said: quit using a press, 4 lb. hammer and 6 inch bench vise is all that is needed This^. I use a BFH, couple of blocks of wood, and a few crappy sockets that have been demoted from actual socket duty. In and out in no time. Link to comment Share on other sites More sharing options...
yxmj Posted December 11, 2019 Share Posted December 11, 2019 To be honest I usually just use a c-clamp As above.....spend a couple of minutes with some emery cloth and a file (or if you have one a rotary tool with an appropriate disk) clean the yoke up good ....the trick is for the finishing sand you have to sand/file in the same direction as the cup will slide in (if that makes sense) not around and around. a bit of grease and they will pop right in.) Link to comment Share on other sites More sharing options...
schardein Posted December 12, 2019 Share Posted December 12, 2019 I don't want to beat a dead horse, but several commenting here are correct, it's a bad idea to use a press for driveshaft and axle shaft bearings. Vise or large c clamp will work, give you a better feel for what you are doing and much less likely to damage parts. I learned this the hard way myself. It's hard to make a good call from a picture, but I think I would replace that shaft with the damaged yoke. A complete set of aftermarket shafts are expensive, and may be overkill for your use. If you are on a tight budget, I would do a search for a used part on ebay. You may find different casting numbers, but as long as the part is from the same or a compatible application, you should be good. Link to comment Share on other sites More sharing options...
