Comanche Options By Year
I see what is advertised as a 1990 Comanche with power locks and windows. Owner got it in a trade and doesn't know entire history.
Is this definitely at 97+ Cherokee swap or just the bucket seats/interior?
I'm looking for a more traditional MJ so I was curious if these features (power locks/windows) were ever available in order to determine what's been done to the front end/doors.
Thanks!
1 hour ago, eaglescout526 said:
Bucket seats and power everything could be had from the factory. If there’s a VIN I can look up the build sheet and can see if it was ever a swap or factory.
He will be sending me the VIN later today, thank you for the help! I am new but there are 2 Comanches I am looking at. This one and a 1987 4x4 short bed I6 automatic that needs a complete RESTO, floor pans, rockers, etc...
Does the dash/odometer area look like Comanche or Cherokee or impossible to tell?
*Q7 Cloth Low-Back Bucket Seats
-SA Charcoal
135 Zone 35-Washington
1AA U.S. Dealer Retail
4HC Special Scheduling Condition III
4ZE Order Tracking V
5KR Midland Corporation
ADA Light Group
ALR GTS Interior Package
APA Monotone Paint
ARM Radio AM/FM Cassette
BA1 100 AMP ALTERNATOR
BCY 475 AMP BATTERY
BGA Power Front Disc/Rear Drum Brakes
CAC Low Back Bucket Seats
CDB Reclining Front Seats
CKA Carpets - Floor and Cargo Area
CSR Passenger Assist Handles
CUF Full Length Floor Console
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHS Floor Mount Automatic Shift Lever
DMD 3.55 Rear Axle Ratio
DRJ 175MM Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GFD Rear Sliding Window
GNA Rear View Day/Night Mirror
GNB Driver Side Illuminated Sun Visor
GNC Sun Visors w/Illum Vanity Mirrors
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HAA Air Conditioning
JAY DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JGB Digital Clock
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
K2B STRIPE/BADGE/MOLDING/COLOR
K3X STRIPE/BADGE/MOLDING/COLOR
KLH
LAJ Headlamps On Warning Chimes
LBB Courtesy Lamps
LBC Glove Box Lamp
LBD Ash Tray Lamp
LBE IP LED Ambient Light Pipe
LCJ DOME/READING LAMP B-PILLAR
LDH U/Hood, Removable/Rechargeable Lamp
LHD Headlamp Off Time Delay
LMA Halogen Headlamps
LNJ Front Fog Lamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MCA Rear Body Color Applique
MDA Front License Plate Bracket
MFK Body Color Grille
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
NHM Speed Control
PX8 Black Clear Coat
QX8 Black Clear Coat
RAA All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCG Leather Wrapped Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TRM P225/75R16 BSW On/Off Road Tires
WJH 15X7 Aluminum Wheels
WLZ All Aluminum Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z59 Left Front Spring Group Ix
Z78 Right Front Spring Group VIII
It had factory buckets it looks like
Agree with above, not a full 97+ swap.  From that picture it looks as though just the doors were swapped and some other seats as others have mentioned.
Do you have any pictures of the front end?  The front end can be swapped easily as well but as a whole this looks very much original still.
31 minutes ago, tugalo said:
the instrument panel that i have has blue kilometer markings on it face, versus the red on your speedometer.  Looks like someone swapped in a Cherokee dash panel.
The blue face was up to I believe '88 ('87???), the red was for anything past that. Cherokee and Comanche clusters were the same for respective production years.
The "blue" gauges have the needles that go from 7 O'clock to 5 O'clock; the "Red" gauges go from 9 to 5.
My 87 has the Blue.  I pulled an 86 full cluster that is also blue.  However, I have seen 87 and 88's that had Red clusters - both full and idiot lights.
I think the clusters were what ever Jeep had in the parts bin when you MJ/XJ rolled by on the assembly line.
The red gauge cluster was introduced for '88, or possibly late in the '87 model year.
The '87 blue cluster is unique to that model year but it is compatible with '87 through '90 vehicles. The '84 to '86 cluster looks similar but is very different otherwise.
