The Gray Ghost
Productive day today. The Comanche's door was separating from the frame after 30+ years. Had to pull the door and fender to straighten out and weld the hinge with reinforcement of course. It's been 20 years since I picked up a welder and it shows. Plus I never used a flux core before. Not pretty but it should stick.
  • 2 months later...
  • Replies 74
Not sure how many people are still following this thread, of the slowest build EVER! Got some more work done in the last couple of months. So where the old mirror was got it fixed.
Also where I managed to cut the bed with a skill saw twenty years ago, I finally welded up.
  • 1 month later...
  • 1 month later...
So took last week off, had some ministry opportunities and got to do some work on the Gray Ghost.
Time to replace the ripped up carpet.
UGH!!!! I was afraid of that.
Well it could be worse. Guess I have some patching to do.
Looks like this is the worst of it.
After some cutting and welding, I think I got most of the ugly stuff.
Time to neutralize the remain rust. Has anyone used this? Seemed to do the job.
Time to take the clutch pedal out!
This isn't identical, but I think we can make it work.
A little cutting and a little drilling and presto! No more Clutch!!!
Went a little crazy on the Flex seal paint and putty. But I think it'll last me another ten to fifteen years. Got to do the bottom side before I'm done.
So trying to re-enforce the interior tab a little. Not pretty but you'll never see it.
So what the heck!!!???? It doesn't matter how many pictures I take pulling the thing apart, I always miss something critical. How the heck do you run the defroster hose through this solid metal? There isn't a hole underneath.
OH WELL! I'm sure I'll figure it out when I put the dash back in. But for now, I'm cutting me a hole.
A/C airbox installed! I'm so EXCITED!!!
Alright. So it looks like the airbox I have, doesn't quite match the wiring from the original. But we can fix that too.
A little sound deadening material, and I'm almost ready to reassemble the interior.
So three steps forward, one step back. Had to pull the air box back out to get the vinyl flooring in. Sigh. Something to note, I had to leave it out in the sun for awhile to make it pliable enough to work with. and you can see the wrinkle in the back above the hump. Haven't tried to straighten it out yet with a heat gun. Not sure if it was from me laying it out in the sun, or it's just malformed? It was purchased from Auto Custom Carpets.
Air box back in!
So in another portion of the garage.......
A little spray foam to fill in the clapped dash. I might have gotten a little carried away. LOL
A little Bondo to fill in the holes left by the foam.
Second coat afraid it might need a third.
Plan on recovering it in vinyl. We'll see how it turns out. This was the worst of the three dash's I have an happens to be the original in the truck.
The condenser fit well behind that massive radiator! No adjustments really needed to be made. Just gathering up the pieces to make custom hoses. Big THANK YOU for to Mike Rocklin and Don Brown Bus Parts! They had the fittings I needed for the expansion value. A little hick up in shipping, but they made it right. GREAT customer service.
Three steps forward, two steps back. I knew before I put in the air box the vacuum harness did not have the line for the recirculating air vent. I didn't think I'd find one, but low and behold I found one on ebay, so this makes the fourth time I remove this box.
no!!!  I just finally installed the airbox and don't have the flooring yet!  :(
Well the condenser fits well. Can't say the same for the adaptor ports from Amazon. I still have a leak somewhere and I'm guessing that's where.
Homemade custom hoses. This A/C better work as I've already poured a ton of money into getting this far.
Not sure I'm so thrilled with the service port location for the low side. It's awfully close to the exhaust and I'm afraid I'm going to get burned.
Ok so added another service port further up the line. So both are on top of the engine compartment where I can get too them.
Looking GOOD! It's holding a vacuum! Now to get the dash back in and wire up the A/C components.
So for those following these are the ports that worked for me.
https://a.co/d/4y4swQL
Also I used this compressor
https://a.co/d/eekVzPa
This piece fits the evaporator:
https://donbrownbusparts.com/products/fitting-str-5-8-mo-x-10-hose-beadlock-313217
  • 3 weeks later...
So a little UPDATE:
Decided to change up the door cards thanks to @Warren99. For those that are frustrated with cold air in the winter cause someone removed the vapor barrier at some point in time. I've done this more than once when I have to get into the door mechanics, an it's much cheaper than getting a new door vapor barrier.
Bought thick plastic drop cloth and double sided duct tape from hardware store
Put the tape where I want it.
place the plastic in place.
Take a utility knife and cut along the dotted line. :)
FYI I zip tie the rods so they don't fall down into the door.
And here we are.
The update on the A/C. Had to go with a different style compressor, since the so called aftermarket LS swap adaptors are crap. I was all excited that I had the A/C wired properly and the compressor was going. It was blowing cold air into the truck. Twenty minutes later the seals around the adaptor gave way. GRRRRRR.
Went to this style;
Then bought this adaptor. I had to do a little grinding on the adaptor to make room next to the engine mount, it fit, but may rattle a little.
The system is recharged and I still haven't taken it out on a test run yet. Seemed to be good in the garage. I was putting the dash back together and managed to pull three wires out of one of the connectors for the cluster. So I gave up for the night after that.
How I wired this one. Your mileage may vary. :)
FYI I also had to change the PCM settings to Analog here.
Someone on FB was asking how I plumbed up the radiator. I took a few pictures and thought I'd post them here too. I started with universal hoses and hated them because they seemed always kinked. These are basically cut and splice, looks better anyway, we'll see how reliable they are.
I'm also most likely goin to replace the top support and cut less out of it.
  • 4 months later...
Finally got the leather steering wheel installed.
This is the products I used to dye it black.
Pulled the old wheel and installed the new one.
Had issues finding any assembly photos that weren't very vague.
So I first placed the thin metal ring on first, concave side down, so it popped up in the middle.
Then placed the other assembly with the rubber spacer on.
I drilled a small hole in the rubber/metal assembly and changed the spade connector out for a ring connector.
then ran the wire through the gap in the hole, and secured it with a screw.
Painted the gray horn button with black primer and used silver model paint to make the jeep logo stand out.
BEEP BEEP it works!!!!
Feel free to comment if I assembled this wrong. :)
