Manche757 Posted October 26, 2019 Posted October 26, 2019 Replaced the speedo cable on an 89MJ, 4.0 and the needle still jumps. Hopefully the speedometer does not need replacing. If so, are they available from a junker only and not new? Any other ideas?
jdog Posted October 26, 2019 Posted October 26, 2019 Oil the speedo, if it's got a spot for it. You will have to pull the cluster to seeStock 1988 swb 4.0 ax15 np 231.
Manche757 Posted October 26, 2019 Author Posted October 26, 2019 jdog, what do you recommend oiling it with?
jdog Posted October 26, 2019 Posted October 26, 2019 I usually use the three in one oil for motors. The one with the spout sold at hardware stores https://www.walmart.com/ip/3-IN-ONE-Multi-Purpose-Oil-with-Telescoping-Marksman-Spout/26394959?wmlspartner=wlpa&selectedSellerId=0&wl13=3824&adid=22222222228018092946&wl0=&wl1=g&wl2=m&wl3=40840090712&wl4=pla-78653262272&wl5=9028785&wl6=&wl7=&wl8=&wl9=pla&wl10=8175035&wl11=local&wl12=26394959&veh=sem&gclid=EAIaIQobChMIquOy2bG65QIVxkXVCh0wTwpVEAQYASABEgL8kvD_BwEStock 1988 swb 4.0 ax15 np 231.
Warren Mohler Posted October 26, 2019 Posted October 26, 2019 9 hours ago, Manche757 said: Replaced the speedo cable on an 89MJ, 4.0 and the needle still jumps. Hopefully the speedometer does not need replacing. If so, are they available from a junker only and not new? Any other ideas? take a piece of your old cable and chuck it in a drill so you can run it at different speeds to see if it still jumps, most MJ and XJ speedos jumped from new, was a big complaint in the 80s several TSBs. I replaced and rerouted many cables
Eagle Posted October 27, 2019 Posted October 27, 2019 Check the routing of the speedo cable for tight bends.
Warren Mohler Posted October 27, 2019 Posted October 27, 2019 1 minute ago, Eagle said: Check the routing of the speedo cable for tight bends. yup, especially if it has cruise, the small cable from tach generator was a big problem
Manche757 Posted October 27, 2019 Author Posted October 27, 2019 3 hours ago, Warren Mohler said: take a piece of your old cable and chuck it in a drill so you can run it at different speeds to see if it still jumps, most MJ and XJ speedos jumped from new, was a big complaint in the 80s several TSBs. I replaced and rerouted many cables Do you recall what the TSBs offered as fixes? Will check for tight bends
cruiser54 Posted October 27, 2019 Posted October 27, 2019 18 minutes ago, Manche757 said: Do you recall what the TSBs offered as fixes? Will check for tight bends Nothing that worked!!!!!! Did you grease the new cable? Is it one piece or two piece?
Manche757 Posted October 27, 2019 Author Posted October 27, 2019 20 minutes ago, cruiser54 said: Nothing that worked!!!!!! Did you grease the new cable? Is it one piece or two piece? It is one piece. I did not install it myself, mechanic did. I do not know if the new cable was greased or not but will find out. What grease do recommend. Are you lubing only the tranny end of the cable? I understand grease on the speedo end will get in the speedometer and create a mess. Your thoughts?
Eagle Posted October 27, 2019 Posted October 27, 2019 You don't grease the ends -- you pull the core out of the outer sleeve and lube the entire length of the core as you slide it back into the outer sleeve.
johnj92131 Posted October 27, 2019 Posted October 27, 2019 17 minutes ago, Eagle said: You don't grease the ends -- you pull the core out of the outer sleeve and lube the entire length of the core as you slide it back into the outer sleeve. Eagle, My TDI Comanche Speedo needle jumps at lower speeds, then smooths out at higher speeds. You say don't grease the ends, rather pull the cable out of the core and lube the entire length of the core as you slide it back into the outer sleeve. My question: What do you lube the cable with? Grease? if so what weight? Light oil? Or a graphite dry lube? Maybe something else? Thanks for any help.
Eagle Posted October 27, 2019 Posted October 27, 2019 6 hours ago, johnj92131 said: Eagle, My TDI Comanche Speedo needle jumps at lower speeds, then smooths out at higher speeds. You say don't grease the ends, rather pull the cable out of the core and lube the entire length of the core as you slide it back into the outer sleeve. My question: What do you lube the cable with? Grease? if so what weight? Light oil? Or a graphite dry lube? Maybe something else? Thanks for any help. I haven't done it for a long time, but my choice has been good old lithium-based chassis lube. You don't glop it on, just a thin coating wiped onto the length of the inner cable as tou slide it back into the outer sheath. There may be newer products now that might be better. Maybe Cruiser will chime in with what they used at his dealership.
Warren Mohler Posted October 27, 2019 Posted October 27, 2019 10 hours ago, cruiser54 said: Nothing that worked!!!!!! Did you grease the new cable? Is it one piece or two piece? Cruiser is correct, no matter what you did seemed to continue to jump, I replaced cables and speedos to still have the problem. I hate to say poor quality parts but I believe speedos were made by same company that made them for Renault Alliance and Encore, I had several of them actually explode in dash with the pieces left attached to cable whipping around inside dash making a mess of everything that got in the way
cruiser54 Posted October 28, 2019 Posted October 28, 2019 They were actually made in Japan during those years. I think the angle of the cable going into the speedo caused the issue.
cruiser54 Posted October 28, 2019 Posted October 28, 2019 14 hours ago, Eagle said: I haven't done it for a long time, but my choice has been good old lithium-based chassis lube. You don't glop it on, just a thin coating wiped onto the length of the inner cable as tou slide it back into the outer sheath. There may be newer products now that might be better. Maybe Cruiser will chime in with what they used at his dealership. Moly chassis grease.
cruiser54 Posted October 28, 2019 Posted October 28, 2019 13 hours ago, Warren Mohler said: Cruiser is correct, no matter what you did seemed to continue to jump, I replaced cables and speedos to still have the problem. I hate to say poor quality parts but I believe speedos were made by same company that made them for Renault Alliance and Encore, I had several of them actually explode in dash with the pieces left attached to cable whipping around inside dash making a mess of everything that got in the way Admit it. You loved those Renaults!!! Ever change the starter on an R5?
Warren Mohler Posted October 28, 2019 Posted October 28, 2019 11 hours ago, cruiser54 said: Admit it. You loved those Renaults!!! Ever change the starter on an R5? Yes I believe I have, I was the only tech that liked working on then, weren't flat rate then so I really didn't care, none of the other guys wanted to work on Renaults I was in the truck shop and we were really slow so they kept me busy. For some reason I sort of liked LeCar. If they were set up proper that little two stage carb gave them a little pep, Alliance and Encore were all right, Feugo not so much. My girl friend at the time bought an Alliance GTA it was a lot of fun. The good old days
Ωhm Posted October 28, 2019 Posted October 28, 2019 7 minutes ago, Warren Mohler said: The good old days Alliance: Motor Trend's "Car of the Year" 1983.
Warren Mohler Posted October 28, 2019 Posted October 28, 2019 Just now, Ωhm said: Alliance: Motor Trend's "Car of the Year" 1983. I wonder how much they had to pay for that title
VixJeep Posted October 28, 2019 Posted October 28, 2019 This isn't a fix, but an observation. My cable jumped for quite a while when I was having idle and vacuum issues. When I got the idle and vacuum issues straightened out, the speedometer stopped jumping. Could be a coincidence, since they shouldn't be related.
cruiser54 Posted October 29, 2019 Posted October 29, 2019 10 hours ago, Warren Mohler said: Yes I believe I have, I was the only tech that liked working on then, weren't flat rate then so I really didn't care, none of the other guys wanted to work on Renaults I was in the truck shop and we were really slow so they kept me busy. For some reason I sort of liked LeCar. If they were set up proper that little two stage carb gave them a little pep, Alliance and Encore were all right, Feugo not so much. My girl friend at the time bought an Alliance GTA it was a lot of fun. The good old days GTA was awesome!!
cruiser54 Posted October 29, 2019 Posted October 29, 2019 10 hours ago, Warren Mohler said: I wonder how much they had to pay for that title they didn't. It was a good car....for a year. Remember burping the cooling system!! We welded a funnel to a coolant cap just to avoid the aggravation repeatedly. 1.4 was a good engine. But they mounted the water pump up real high and when the level dropped in the cooling system, they cooked.
Warren Mohler Posted October 29, 2019 Posted October 29, 2019 6 minutes ago, cruiser54 said: GTA was awesome!! it was a leftover in 88 she got it basically at cost, black with black interior, we took it easy on it for a week before I decided to flog it, fell on its face big time ran great till you went WOT then crap after farting with it for several days, hooked up fuel pressure gauge to see it had 60 psi turned it down to spec then it became fun. good days
