I had defrost for a long while until I discovered a broken vac line going to the reservoir in the bumper. Have you checked that line? Usually that is a culprit to having defrost only.
I will look into that! Thank you!
This is most likely, as eagle said, a leaking vacuum line (on my XJ, it was a line along the passenger side that broke).  The HVAC blender is mostly vacuum operated and will default to defrost when there's a vacuum leak.
OK! Thanks!
  • 1 month later...
Mine had rubbed through the bottom of the hard vacuum line near the firewall. Was hard to find. But A few inches of new line now the a/c works correctly and the air blows out where it is supposed to.
I had a similar issue.
