1989 Jeep Comanche Pioneer
Hello all,
Haven’t used a forum in a good 10 years but figured I would give it a go again. Here’s a short list of what’s been done to my MJ and a few pictures. I’m positive I’m forgetting a lot but this is a good start
Updated 4/3/2022
5.5” Metal Cloak dual rate springs
Fox 2.0 front shocks
RC Adjustable track bar
Rusty’s Off-road Comp 4 link
SOA rear with OEM leaf perches
NP242 T case/AW4 swap
Azzy design works shifter linkage
Dana 30 - 4.88 gears Powertrax Grip Pro
Chrysler 8.25 -4.88 gears Detroit Locker
Motive Gear Ten Factory 29 spline shafts
Barnes Dana 30 Truss and C gussets
Dirtbound Off-Road rear bumper
Dirtbound Off-Road rear bed protection
Dirtbound Off-Road rock sliders
DIrtbound Off-Road heim joint steering
Can Fab OTA track bar
JKS sway bar quick disconnects
Cooper SST Pro 35X12.50x15 MT
15x10 steel wheels
Tuff Stuff 4x4 front bumper
Badlands 12k winch
97+ mirrors power mirrors
EDM/JDM fender repeater lights
XJ power windows/locks
MJ bucket seats
XJ center console
XJ floor shifter and cable
Open cooling system swap
3 core aluminum radiator
HO thermostat housing
160 degree thermostat
Complete R-134A AC system
New heater core/evap core
Correct length speedo cable
OEM Comanche fender emblems
OEM Comanche flares
REM+ Renix monitor
XJ kick panel interior lights
Amazon B Pilar lights
Amazon LED plate lights
LED headlamps
Current State
Photo's while on 33s
  On 11/12/2019 at 5:39 PM, Pete M said:
that is one sexy truck.  no doubt about that. :D
:bowdown:
Expand
Pete, It looks great from anything more then 5 feet away. Goal is to keep it clean and respectable while still wheeling it
  On 11/12/2019 at 8:32 PM, thecodemonk said:
Looks awesome!  Just needs more pictures!
Expand
I’ve got pictures for days! I wouldn’t know where to start with posting them
  • 3 months later...
Little updated:
Installed some DirtBound rock sliders. Bolt on? Meh, That's for people with commitment issues. Had to remove the front mount since I have the Rustys Comp 4 link brackets welded to the "Frame" and it kept the sliders from aligning up properly. Went ahead and burned the other mounts all directly to the MJ.
Also installed the rear bed side armor. If I didn't smash the right rear in the install would have been pretty easy. All in all, I'm happy.
91960365_148380673365908_385944204547434633_n.thumb.jpg.85b00f50a62959178fbb48764f265f73.jpg
91398164_2596941640631866_2169422188509165944_n.thumb.jpg.d10fb75826daad0e52fcefa5341b688d.jpg
Now I won't end up with anymore cab dents
  • 1 year later...
Its been awhile, A very long time actually. Now that I have sold the project Comanche I had I'm spending more time on my other MJ. Plus with buying myself a laptop (I haven't owned a computer in 12 years) I will be posting a bit more often. Rather keep this forum a bit active than use Facebook.
Few quick photos, I recently got 35s installed and repaired a laundry list of electrical wiring.
Finally welded in the barnes dana 30 truss kit and C gussets. While I had the welder out I filled in the holes I drilled in the bumpers and added some E track tabs to the bed. Using a Y type strap to secure the spare tire. I didn't want something large to remove every time I wanted to make use of the bed.IMG_0099.jpeg.a10b0f50fdda6a2da14a353688e64f13.jpeg
Now I need to lift the Comanche trailer in order to fit 35s.
  On 1/20/2022 at 10:34 PM, JordanTMiller said:
Definitely do a bumper and hitch so you can pull another MJ trailer behind this one.
Expand
I would have to get crafty with that. The bed is the only thing MJ about the trailer. I used a older flat bed trailer I had and added to the frame and welded the beat up bed to it. Was just looking at it, Maybe use a XJ/M front bumper on the rear. Then work around that for a hitch set up on it.
It's been a little while, Have been spending time on the other Comanche and not so much on this one. Ended up hurting the rear axle this weekend while going to pick up a new transmission. Slipped horribly and banged into gear, That resulted in the axle spinning or the tubes spinning. I got it home and haven't looked much into it. Thats for another day
I did manage to get the doner transmission and T case from a 96 XJ
  • 2 months later...
Few months have passed and I have this thing 95% wrapped up. Took it for a drive this evening and am pleased that everything is working again.
Replaced the transmission with a 96 23 spline
Went from a 21 spline 242 to a 23 spline 231 transfer case
Straightened out the rear end, Welded the tubes back to the differential housing
Had my drive shaft shortened, Ended up being 1 3/4" too long.
Only need to replace the interior transferase shifter gate and bezel.
Oh, I also have a trailer now so thats a huge plus! Been a long over due.image.jpeg.90377031a7adc2bbd067c047d067327f.jpeg
