MJ_Corrry Posted October 22, 2019 Posted October 22, 2019 Hello all, Haven’t used a forum in a good 10 years but figured I would give it a go again. Here’s a short list of what’s been done to my MJ and a few pictures. I’m positive I’m forgetting a lot but this is a good start Updated 4/3/2022 5.5” Metal Cloak dual rate springs Fox 2.0 front shocks RC Adjustable track bar Rusty’s Off-road Comp 4 link SOA rear with OEM leaf perches NP242 T case/AW4 swap Azzy design works shifter linkage Dana 30 - 4.88 gears Powertrax Grip Pro Chrysler 8.25 -4.88 gears Detroit Locker Motive Gear Ten Factory 29 spline shafts Barnes Dana 30 Truss and C gussets Dirtbound Off-Road rear bumper Dirtbound Off-Road rear bed protection Dirtbound Off-Road rock sliders DIrtbound Off-Road heim joint steering Can Fab OTA track bar JKS sway bar quick disconnects Cooper SST Pro 35X12.50x15 MT 15x10 steel wheels Tuff Stuff 4x4 front bumper Badlands 12k winch 97+ mirrors power mirrors EDM/JDM fender repeater lights XJ power windows/locks MJ bucket seats XJ center console XJ floor shifter and cable Open cooling system swap 3 core aluminum radiator HO thermostat housing 160 degree thermostat Complete R-134A AC system New heater core/evap core Correct length speedo cable OEM Comanche fender emblems OEM Comanche flares REM+ Renix monitor XJ kick panel interior lights Amazon B Pilar lights Amazon LED plate lights LED headlamps Current State Photo's while on 33s
JordanTMiller Posted October 22, 2019 Posted October 22, 2019 You didn’t even list “fall air” for what you run in your tires. You lied to me.
MJ_Corrry Posted October 22, 2019 Author Posted October 22, 2019 25 minutes ago, JordanTMiller said: You didn’t even list “fall air” for what you run in your tires. You lied to me. I’m still working on the correct way to write it up. It’s not as simple as adding nitrogen to tires
Pete M Posted November 12, 2019 Posted November 12, 2019 that is one sexy truck. no doubt about that.
thecodemonk Posted November 12, 2019 Posted November 12, 2019 Looks awesome! Just needs more pictures!
MJ_Corrry Posted November 15, 2019 Author Posted November 15, 2019 On 11/12/2019 at 12:39 PM, Pete M said: that is one sexy truck. no doubt about that. Pete, It looks great from anything more then 5 feet away. Goal is to keep it clean and respectable while still wheeling it On 11/12/2019 at 3:32 PM, thecodemonk said: Looks awesome! Just needs more pictures! I’ve got pictures for days! I wouldn’t know where to start with posting them
derf Posted November 15, 2019 Posted November 15, 2019 Start with the first one. Then keep posting more.
Pete M Posted November 15, 2019 Posted November 15, 2019 yeah, you don't need to organize them or anything. MJ addicts don't care about that.
MJ_Corrry Posted November 16, 2019 Author Posted November 16, 2019 Here’s what it looked like the day I picked it up 3 years ago. Just a 2wd short bed MJ that was clean and spray painted white. Will continue with more pictures later on. I have a lot!
MJ_Corrry Posted March 10, 2020 Author Posted March 10, 2020 It’s been awhile but nothing has changed recently. Just that I upgraded the steering to DirtBound’s set up
MJ_Corrry Posted April 10, 2020 Author Posted April 10, 2020 Little updated: Installed some DirtBound rock sliders. Bolt on? Meh, That's for people with commitment issues. Had to remove the front mount since I have the Rustys Comp 4 link brackets welded to the "Frame" and it kept the sliders from aligning up properly. Went ahead and burned the other mounts all directly to the MJ. Also installed the rear bed side armor. If I didn't smash the right rear in the install would have been pretty easy. All in all, I'm happy. Now I won't end up with anymore cab dents
MJ_Corrry Posted December 27, 2021 Author Posted December 27, 2021 Its been awhile, A very long time actually. Now that I have sold the project Comanche I had I'm spending more time on my other MJ. Plus with buying myself a laptop (I haven't owned a computer in 12 years) I will be posting a bit more often. Rather keep this forum a bit active than use Facebook. Few quick photos, I recently got 35s installed and repaired a laundry list of electrical wiring.
MJ_Corrry Posted January 16, 2022 Author Posted January 16, 2022 Finally welded in the barnes dana 30 truss kit and C gussets. While I had the welder out I filled in the holes I drilled in the bumpers and added some E track tabs to the bed. Using a Y type strap to secure the spare tire. I didn't want something large to remove every time I wanted to make use of the bed. Now I need to lift the Comanche trailer in order to fit 35s.
JWheeler331 Posted January 16, 2022 Posted January 16, 2022 Very nice. I hope to get my Comanche looking about like yours looks. Very well done.
MJ_Corrry Posted January 20, 2022 Author Posted January 20, 2022 Lifted the MJ trailer a bit, Need to paint match it at some point. Also need to figure out what to do on the rear. Find a bumper or make a roll pan
JordanTMiller Posted January 20, 2022 Posted January 20, 2022 Definitely do a bumper and hitch so you can pull another MJ trailer behind this one.
MJ_Corrry Posted January 21, 2022 Author Posted January 21, 2022 18 hours ago, JordanTMiller said: Definitely do a bumper and hitch so you can pull another MJ trailer behind this one. I would have to get crafty with that. The bed is the only thing MJ about the trailer. I used a older flat bed trailer I had and added to the frame and welded the beat up bed to it. Was just looking at it, Maybe use a XJ/M front bumper on the rear. Then work around that for a hitch set up on it.
MJ_Corrry Posted April 4, 2022 Author Posted April 4, 2022 It's been a little while, Have been spending time on the other Comanche and not so much on this one. Ended up hurting the rear axle this weekend while going to pick up a new transmission. Slipped horribly and banged into gear, That resulted in the axle spinning or the tubes spinning. I got it home and haven't looked much into it. Thats for another day I did manage to get the doner transmission and T case from a 96 XJ
MJ_Corrry Posted April 9, 2022 Author Posted April 9, 2022 14 hours ago, Pete M said: that's sucks. As they say, S!@& happens! Once I get the other MJ running and a few house projects finished I will get back to it. Joys of owning a fleet of vehicles, When one is broken I can fix it on my time with out rushing
Pete M Posted April 9, 2022 Posted April 9, 2022 28 minutes ago, MJ_Corrry said: When one is broken I can fix it on my time with out rushing Amen to that.
MJ_Corrry Posted May 15, 2022 Author Posted May 15, 2022 It's about time I start to get this thing fixed. Time to pick away at the to-do list!
MJ_Corrry Posted July 18, 2022 Author Posted July 18, 2022 Few months have passed and I have this thing 95% wrapped up. Took it for a drive this evening and am pleased that everything is working again. Replaced the transmission with a 96 23 spline Went from a 21 spline 242 to a 23 spline 231 transfer case Straightened out the rear end, Welded the tubes back to the differential housing Had my drive shaft shortened, Ended up being 1 3/4" too long. Only need to replace the interior transferase shifter gate and bezel. Oh, I also have a trailer now so thats a huge plus! Been a long over due.
