So in the process of replacing my driver front wheel bearing. Noticed the u joint was bad. Run to parts store get bearing and I joint. Come home to install parts and notice this. Its the outter stub shaft. Any suggestins on best place to source one quickly?3d2a4358309f9da43d4ec9a6ff12d360.jpg
My build: https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/8033-finally-found-onenow-it-has-a-new-floor/&share_tid=8033&share_fid=53169&share_type=t
From you signature and build thread....you converted to 4x4?
What front axle did you use?
Is there a junk yard in you area that would have XJ's of that era?
Otherwise you would have to start canvassing the parts stores or on line.....
Sweet. That beats the prices I was finding. I think I found a local buddy that has one. Hoping to hook up with him today. Realy trying to get it back on the road by tomorrow if I can.
Hope so if he is looking for a front axle shaft.....cuz if it is a 2wd.....it is going to be a FUBAR time fitting it in......
I just saw his description says 2wd.
You could have walked into Autozone and walked out with two new CV shafts and had been on the road in 3 hours.
If you are not a hard core rock bouncer type.......CVs are just fine.
This option has been discussed here many times.
2 hours ago, watchamakalit said:
Crap. I didnt even think of CV shaft. It shouldnt hurt anything to run one CV and the other u joint shaft should it? What model do I need to source from?
'94 ZJ IIRC.
No, don't mix, and once you get used to turning on CVs...............you'll not go back.
'94 ZJ IIRC.
I have a disconnect front. What other steps need to be taken? Sorry for all the questions. Just trying to figure the simplest way to get my truck back on the road.
Shouldn't be an issue running a CV on only the one side, especially since you're looking for the driver's side. The ujoint doesn't know what's going on with the shaft on the other side. That said I would do (and have done) both myself, but you should know that if you put a single-piece shaft into the CAD housing, it won't seal properly on that side. There is a seal you can get that will do the job. There should be a DIY thread on here about prepping the CAD axle housing for a one-piece shaft.
