Hey there been going crazy looking for a build sheet or the paint color code for my comanche any info really helps thanks!! Charles
1989 jeep comanche pioneer 4x4
vin 1J7FJ36L0KL616578
welcome to the club!  :waving:  I split off your post and hopefully one of the guys that's running the VINs will see it soon. :L:
I’ve got a reminder set to do some VINs this afternoon. I’ve been slacking a bit on these. You’ll get a full build sheet and build date and body code. Build sheet will have paint code
*X1 TRIM STYLE X1 - CLOTH BENCH
-SA Charcoal
172 Zone 72-Portland
1AA U.S. Dealer Retail
5AM Largo Tracking
5KN Metro Cars of Detroit
ADL Skid Plate Group
ALN Body Color Bumper Group
APA Monotone Paint
BAQ 61 AMP ALTERNATOR
BCX Nickel Metal Hydride Battery
BGA Power Front Disc/Rear Drum Brakes
BJA STD DUTY FRT DISC BRAKES
BKP 10x2.5 Rear Drum Brakes
CBA Straight Back Bench Seat
CKA Carpets - Floor and Cargo Area
CSR Passenger Assist Handles
CUM Mini Floor Console
DBB All Manual Transmissions
DDQ 5-Speed Manual Transmission
DHN Command-Trac Part Time 4WD System
DJH 230MM Front Axle
DMM 3.07 Rear Axle Ratio
DRJ 175MM Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GFD Rear Sliding Window
GNA Rear View Day/Night Mirror
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HCD Do Not Use - See HCA
JAA Instrument Panel
JAY DO NOT USE - See JP, KA classes
JBD BEZEL-I/PANEL CLUSTER - BRIGHT
JCA 85 MPH Primary Speedometer
JGB Digital Clock
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
JKB MOPAR Hood Lock
K2X STRIPE/BADGE/MOLDING/COLOR
K3D STRIPE/BADGE/MOLDING/COLOR
KKE
LAF Seat Belt Alert-Driver Seat only
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFG Body Color Headlamp Bezels
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
NAA Federal Emissions
NBA LIGHT DUTY CYCLE
NBK EVAP Control System
NDA Catalytic Converter
NF5 Fuel Tank - 23 Gallon
PS3 DOVER GREY MET CL CT PRIMARY PAINT - HS3
QS3 DOVER GREY MET C C SECONDARY PAINT - HS3
RAA All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCE Alcantara Wrap Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TAA All Tires
TAE MUD && SNOW TREAD
TBB Full Size Spare Tire
TBM Tire Carrier Winch
TRN P225/75R15 OWL Wrangler AT Tires
WJM 15X7.0 Chrome Wheels
XBS Pickup Box
XEE Fuel Tank Skid Plate Shield
XEF Transfer Case Skid Plate Shield
XEU Front Suspension Skid Plate
XFA -35F Protection Anti-Freeze
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z66 Left Front Group XV
Z85
Right Front Spring Group XIV
Body Model JM62
Build Date 5/22/89
37 minutes ago, Kilogram2012 said:
So this is my build sheet?
Yes. Some of the descriptions may be wrong if Chrysler is using them now aka updated them.
2 hours ago, eaglescout526 said:
Never mind. I’ve been beat to it. Thanks JMO!
No problem I saw the post this morning and did it while I was at work.
You guys rock! Thanks tons i traded my 87 2 door xj for this gem and it sat for last 22 years! And i got it from the original owner and here's the kicker it has heavy duty 3 in trailmaster lift with lca drop brackets adjutable upper and lower control arms and i just hit 84,800 miles! My emissions matience timer lit up too 🤟🏻😁
84k miles!?!? U score big time for sure! Nice truck!
On 7/8/2019 at 9:03 PM, Kilogram2012 said:
You guys rock! Thanks tons i traded my 87 2 door xj for this gem and it sat for last 22 years! And i got it from the original owner and here's the kicker it has heavy duty 3 in trailmaster lift with lca drop brackets adjustable upper and lower control arms and i just hit 84,800 miles! My emissions maintenance timer lit up too 🤟🏻😁
be sure to start yourself a build thread. :L:
  • 1 year later...
