Kilogram2012
1463 profile views
Kilogram2012's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. I did same thing but I legit just swapped a 95 high output 4.0 in my 89 and kept the renix system had to swap my sensors over and flywheel and new throttle cable also made a custom adapter for the renix tps to work with h.o. Throttle body, also made a adaptor for the throw out bearing on my 89ax15 to fit the high out put motor.. 🤦🏻‍♂️🤷🏻‍♂️ And it’s insane! Woke my truck right up!
  2. This is it few days after I got it and washed it up and the blue mj build is a buddy’s 86 mj he built for Baja and i know I wouldn’t be able to make mine quite as sweet as his but it’s an idea for what I’d possibly like to do,, we own a built 95 two door and a built 99 two door xjs and then my 89 mj I’m building and dd, 🙂👍
  3. Just did my first clip swap 1989 to a 2000 front end. Swear it looks like I’ve done it before lol
  4. You guys rock! Thanks tons i traded my 87 2 door xj for this gem and it sat for last 22 years! And i got it from the original owner and here's the kicker it has heavy duty 3 in trailmaster lift with lca drop brackets adjutable upper and lower control arms and i just hit 84,800 miles! My emissions matience timer lit up too 🤟🏻😁
  5. So this is my build sheet?
  6. Thanks guys!!!! Here it is my 1989 AMC jeep Comanche 4x4 ax15 five speed long bed
  7. Hey there been going crazy looking for a build sheet or the paint color code for my comanche any info really helps thanks!! Charles 1989 jeep comanche pioneer 4x4 vin 1J7FJ36L0KL616578
