I installed new rear window louvers on my 1987 Comanche.
Install wasn’t hard, but it took some time to prep and properly line everything up.
23AC1B5B-5EEC-4615-BE0E-6E4997DDCE66.jpeg.2a043aaab704c133488889baa671ec46.jpeg9FE93980-3210-4ECD-ABA0-6FD252211B64.jpeg.9d5dee11d4afc949f05630d3d0534420.jpeg
81381619-652B-41EC-9D06-8A67E482ADF1.jpeg.e1ab73559c6a60862e30df5108b8e6d6.jpegB46A6EDB-F748-48FC-9357-3493B7004A09.jpeg.6d1f8298ecca7c2c7c3f4f7492cad39a.jpeg
1 hour ago, eaglescout526 said:
Looks great.
I'm convinced to get one....but how does it get installed exactly?
There are 2 hinges at the top and 2 hard mounts at the bottom (3M tape placed directly on the outside rubber part of the window).  The louvers have 4 holes that allow it to be mounted to the brackets with nuts.
The hinges allow it to swing upward to allow access to the window (My sport bar only allows me to swing a little bit).
Altogether, the louvers can easily come off by removing the nuts.
Neat!
  • 1 month later...
it looks super awesome and I'd bet works fantastic to keep the Georgia sun off my neck.  :drool:  I love it!
6 hours ago, Knucklehead97 said:
Could I get a link to where to get these? These look GREAT.
I bought them from SFX Performance.  Make sure to check that the louvers will work with your style of window.
The simplest way is to call the manufacturer: http://www.willpak.com/
They willl give you the dimensions of the louvers so you can double check fitment before placing an order.
