  • Replies 588
  • 3 weeks later...
Let the engine swap commence!
My brother and I brought this to an auction today to buy his J10 when either a radiator hose or the water pump decided to let go. The rod knock also got worse. Stay tuned!
37 minutes ago, Pete M said:
sometimes the truck just lets you know it's time for an upgrade :D
I suppose. But I’m about a week it’s going to have an engine upgrade.
Time me to look on the bright side, my Stroker will have a new water pump already!
9 hours ago, Pete M said:
have you decided on the OBD2 swap?  Swampy is in the middle on one:
I have seen his. I decided against it for now because I don’t have the time to go that far into tearing it back apart.
It is a process. It well be good once its done, I'm about a week from completion just waiting for flywheel bolts because I thought I had the right ones. Oh well
  • 4 weeks later...
7 hours ago, eaglescout526 said:
Which blue? The blue commonly seen in the 60's-70's or the color from the logo and the blocks used to be until Chrysler bought AMC?
We got as close as we could to the 79 J10 engine blue.
10 hours ago, eaglescout526 said:
When you get a chance, could you PM me a pic of that? I’ve been trying to hunt down something close enough and all I seem to have found(on the cheap side) is GM blue.
I’ll try to send you a pic in the next day or two.
Here are the paint details. It was a single stage acrylic enamel. I shot the engine myself.
Don’t worry-that Fram is going away.
Damn. So close. I had a feeling it was gonna be the metallic color.(don't mean it in a bad way). Ive seen a few others who have this blue on their block:
I can't seem to find that blue anywhere.
But nonetheless it still looks good! I am just anal about the details and originality on my truck.
54 minutes ago, Pete M said:
what am I looking at?  did it re-crack along a welded joint?
I do not think it has been repaired before. I’d assume it was a manufacturing defect or the donor was in a crash. If it’s a manufacturing defect, I’d recommend checking your external slabs bellhousing to make sure it isn’t cracked.
  • 89 MJ changed the title to 89 Sportruck
