Painting Black on Taillight Bezels?
I did it as follows:
- Rough sided sponge (kinda like a Scotchbrite pad) to clean the lens really good.  This also acts like a fine sandpaper.
- Rinse and dry, then tape the insides.
- Rust-Oleum Bedliner because it's what I had but I'd recommend Rust-Oleum X2 paint+primer unless you want a slightly textured surface.  Wouldn't hurt to use a separate plastic primer first.
- Once dry, remove tape and do a couple coats of Rust-Oleum clear coat on the entire lens.
Turned out looking really good and I will be doing it again on my red truck.  Makes the lenses look brand new.
Thanks, I’ll have to do this soon. I’ll post pics once it’s finished.
Must be a tough life you have when you go looking for projects. :smile:
Most of us are neck-deep in so much S--- we'll never get done.
