More starter problems...
Anyone ever had to replace the starter relay?
I suspect mine to be faulty, right now I'm getting two alternating scenarios.
A. - turn key, nothing no dash. Battery tests at 95% with 12.5v. No broken fuses. No loose wires.
B. - turn key everything comes up as it should, turn to starter, small humming no crank, everything goes off like someone disconnected the battery.
New items, optima red top battery, alternator, starter...
(just ordered a set of cables from meanlemons too)
Suspect culprit.
  • Replies 51
So, side question to go with this, should RockAuto run out of these eventually, or just to make ease of finding/purchasing by making more selection...
I found this one that has the diagram on the side of it... I was wondering if it was possible to eliminate the F pin by connecting it to the threaded post?
anyone with electrical knowledge have some advice?
I've notice that both old and new relays have Pin F. I believe that pin feeds (BAL circuit) the fuel pump during CRANK, bypassing the ballast resistor. Connecting Pin F to BATT (threaded stud) would cause fuel pump to run constantly.
What about connected to the sol pin?
20 minutes ago, Wounded_Fighter said:
Actually turned out to be the suspected relay.
Going to still run more tests to make sure it doesn't happen again for any reason at all...
Replaced and runs again.
Where'd you get the relay? Part number?
14 minutes ago, Wounded_Fighter said:
Got my fingers crossed that it doesn't... thanks for the mopar link!
I'll revive this when it dies just for the laughs.
Hopefully it won't take out anything else when it smokes.   :L:
On 8/22/2018 at 9:37 PM, HOrnbrod said:
Only raggin' on ya a bit. It'll be fine.   :smile:
It died again.....
Same symptoms as before.
Got one from napa to test if it's that part... oddly enough it looks like the exact one I put in...
Napa part number AR578
Gonna have to trace wires and start replacing stuff....
Maybe eliminate some of them from the relays battery post... LOL... not a clue what most of them go to.
