Comanche_Dee Posted July 6, 2018 Share Posted July 6, 2018 Hello I wanted to know if any one switch their manual Comanche to an automatic, I have 1987 Comanche, or would any body happened to know if I can change transmission from a XJ Link to comment Share on other sites More sharing options...
87MJTIM Posted July 6, 2018 Share Posted July 6, 2018 Yes. Lots of owners have done it. Is yours 4wd? If so, you will need a transmission with a 21 spline output shaft. Later models (90+?) have 23 splines. These won’t fit your t-case. If you get an XJ auto you could swap all the necessary parts Link to comment Share on other sites More sharing options...
Comanche_Dee Posted July 17, 2018 Author Share Posted July 17, 2018 Thanks for the reply but I have 2wd 2.5 L, also you think I will have the switch the TCM?. I was wondering if my wiring will change as well Link to comment Share on other sites More sharing options...
87MJTIM Posted July 17, 2018 Share Posted July 17, 2018 Since a manual did not have a TCM, you will need the one from the XJ. Forget about the tcase since you are 2wd. You will need the drive shaft length adjusted. I believe the manual and auto trans are diff lengths. Link to comment Share on other sites More sharing options...
Eagle Posted July 17, 2018 Share Posted July 17, 2018 A 2.5L XJ will probably have the Chrysler 904 automatic transmission. I don't think that used a TCU. It'll work in an MJ, but I don't think MJs used that transmission. Link to comment Share on other sites More sharing options...
Jeep Driver Posted July 17, 2018 Share Posted July 17, 2018 The 86 MJ did come with an auto trans in 2.5 yeah I suspect it was the 904 Very few MJ or XJ came with the 2.5 automatic they're out there but you're going to have a hard time finding one And after all that work you're going to regret it Link to comment Share on other sites More sharing options...
Jeep Driver Posted July 17, 2018 Share Posted July 17, 2018 The 86 XJ MJ did come with an automatic behind the 2.8 that automatic will bolt up to your 2.5 however there is no provision for a CPS the 86 2.8 that was carbureted and had no need for a CPS You will need the flexplate for a renix 2.5 they are not made anymore and I seriously doubt you're going to find one I recommend you seriously consider a repower Link to comment Share on other sites More sharing options...
omega_rugal Posted July 19, 2018 Share Posted July 19, 2018 if you have the 2.8 shouldn´t a GM auto tranny work? get a complete 4.0+aw4+tcase combo from an XJ, you current setup will be difficult to upgrade... Link to comment Share on other sites More sharing options...
kryptronic Posted July 19, 2018 Share Posted July 19, 2018 94 and 95 YJ 2.5L were available with the TF904. Jeep didn't produce many YJ optioned like this, though. Link to comment Share on other sites More sharing options...
omega_rugal Posted July 19, 2018 Share Posted July 19, 2018 get a 700R4 from a S-10 Link to comment Share on other sites More sharing options...
Eagle Posted July 19, 2018 Share Posted July 19, 2018 1 hour ago, omega_rugal said: if you have the 2.8 shouldn´t a GM auto tranny work? get a complete 4.0+aw4+tcase combo from an XJ, you current setup will be difficult to upgrade... Where did people get the idea he has a 2.8L? He has stated that he has a 1987 2.5L 2WD. That means whatever he uses has to have provision for a CPS, and the flex plate has to be Renix-compatible. Are we all on the same page now? Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 19, 2018 Share Posted July 19, 2018 10 minutes ago, Eagle said: Where did people get the idea he has a 2.8L? Perhaps from the person that stated it was an 86. Just a wild guess... Link to comment Share on other sites More sharing options...
Jeep Driver Posted July 19, 2018 Share Posted July 19, 2018 3 minutes ago, HOrnbrod said: Perhaps from the person that stated it was an 86. Just a wild guess... Who stated it was an '86? Link to comment Share on other sites More sharing options...
omega_rugal Posted July 19, 2018 Share Posted July 19, 2018 16 hours ago, Eagle said: Where did people get the idea he has a 2.8L? He has stated that he has a 1987 2.5L 2WD. That means whatever he uses has to have provision for a CPS, and the flex plate has to be Renix-compatible. Are we all on the same page now? the 2.5 has the same chevy pattern, shouldn´t apply too? Link to comment Share on other sites More sharing options...
Eagle Posted July 19, 2018 Share Posted July 19, 2018 1 hour ago, omega_rugal said: the 2.5 has the same chevy pattern, shouldn´t apply too? Yes, but the 2.8L V6 didn't use a crankshaft position sensor. The '87 2.5L used the Renix throttle body injection system and it uses the same CPS as the Renix 4.0Ls. Link to comment Share on other sites More sharing options...
Jeep Driver Posted July 19, 2018 Share Posted July 19, 2018 1 hour ago, HOrnbrod said: Perhaps from the person that stated it was an 86. Just a wild guess... Since you won't respond, let me clarify. Or for anyone who is equally confused. I'm the one that mentioned the 1986. I have seen ONE 1986 MJ with the 2.5 and the 904, ONE, not many, ONE. I have not seen, nor heard of, nor read about any other year in which an MJ was produced with a 2.5 and a 904. If one exists, it's that rare. Many XJ and MJs were produced in 1986 with the 2.8 and the 904. I brought this up in case the OP has a buddy who says "hey, I know where one is that will bolt up", only to come back here to ask why his engine won't run and what's this wire and plug for? In any case, he won't find the parts anyway..........wasted my time, I guess. Maybe I should post in crayon? Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted July 19, 2018 Share Posted July 19, 2018 Here's A list of 2.5 4x2 transmissions, couldn't see where you live ... http://www.car-part.com/cgi-bin/search.cgi Link to comment Share on other sites More sharing options...
Jeep Driver Posted July 19, 2018 Share Posted July 19, 2018 Year Part Model Description Miles Part Grade Stock# US Price Dealer Info Dist mile 1986 Transmission Assembly Jeep Comanche 2.5,AT 63,000 A 961005 $725 Mike's Wrecking, Inc. - KOLT USA-TX(Abilene) Request_Quote 1-888-592-4676 Request_Insurance_Quote 980 1986 Transmission Assembly Jeep Cherokee ENG434 $450 Rastro 74 Used Auto Parts USA-FL(Medley) Request_Quote 305-592-6478 Request_Insurance_Quote 721 1986 Transmission Assembly Jeep Cherokee AT,4CYL,4X2 MISC $400 Sheldon's Used Auto Parts USA-MN(Thief-River Falls) E-mail 1-800-336-4886 1068 1986 Transmission Assembly Jeep Cherokee GOOD TESTED TRANS - READY TO GO-81K 81,000 A 28B01 $399 Glenoaks Auto Wrecking, Inc. USA-CA(Sun-Valley) Request_Quote 818-767-1662 Request_Insurance_Quote 1990 1986 Transmission Assembly Jeep Comanche 2.8-255K 400,000 BM0944 $350 Giant Automotive Products, Inc. USA-OH(Akron) Request_Quote 1-800-686-9000 Request_Insurance_Quote 363 1986 Transmission Assembly Jeep Comanche 4X2- 92K;CLEAN BNO381 $300 Staunton Wrecking Yard USA-VA(Staunton) E-mail 1-800-476-5970 263 1986 Transmission Assembly Jeep Comanche 2.8,AT,RWD,NOTE 150010 $300 AC Auto Salvage USA-GA(Athens) Request_Quote 706-548-1644 / 888-541-1644 Request_Insurance_Quote 134 1986 Transmission Assembly Jeep Comanche 86 COMANCHE 2WD AUTO TRANS 29892 $250 Pearsons Auto Wrecking USA-CA(Ridgecrest) Request_Quote 1-800-446-5865 Request_Insurance_Quote 1918 1986 Transmission Assembly Jeep Comanche A904,2.8L,AUTO,4X2,122K 122,449 A 2514A $250 Sisco's R & R Inc USA-IL(Fairbury) E-mail 888-394-4700 / (815) 692-2407 441 1986 Transmission Assembly Jeep Cherokee not tested,2.8,AT,RWD,k,Floor 210,490 C J2814 $225 Wills Wrecker, LLC. USA-NY(LaFargeville) E-mail 1-800-713-1172 679 1986 Transmission Assembly Jeep Cherokee AT 4X2 2.5 BEEN SITTING-AS IS STOCK# 039611-999999 0396111B $150 Tyrone Auto Salvage USA-PA(Tyrone) Request_Quote 814-684-0310 / 800-770-0310 Request_Insurance_Quote 415 1986 Transmission Assembly Jeep Cherokee 1 86,2.8,FLR,AT,4X2 160,572 A L5A021 $Call Charlies Auto & Truck Salvage USA-TX(Tomball) Request_Quote 281-351-1314 Request_Insurance_Quote 836 1986 Transmission Assembly Jeep Comanche 2.8,2WD,AT TRANSMISSION 3J0065 $Call Dorris Auto Wreckers, Inc. USA-CA(Hayward) Request_Quote 1-510-782-4393/1-510-782-4394 Request_Insurance_Quote 2150 1986 Transmission Assembly Jeep Cherokee PIONEER,2.8L,AT,2WD,TLT,CR,DLY,F loor 238,649 C 130426 $Call Natchez Salvage USA-MS(Natchez) E-mail 1-800-759-0631 566 1986 Transmission Assembly Jeep Truck 904 AT 0 A 35956 $Call H & H Auto Salvage USA-OK(Weatherford) E-mail 1-800-375-7629 / 1-580-772-7754 879 1986 Transmission Assembly Jeep Cherokee CORE CORE SHELF.. 007691 $Call Allen's Used Auto Parts USA-FL(Tampa) Request_Quote 813-620-4242 Request_Insurance_Quote 559 1986 Transmission Assembly Jeep Cherokee PIONEER,2.5,AT,2WD,TCDNK,FLR 176,761 A 8B0080 $Call Ace Auto Salvage USA-SC(Jonesville) Request_Quote 1-864-674-6789 1-866-674-6789 Request_Insurance_Quote 111 1986 Transmission Assembly Jeep Comanche 2.5 AT 2WD 4X2 FH27251 $Call Hartlaub's Used Auto Parts USA-PA(Gettysburg) Request_Quote 717-637-1990 Request_Insurance_Quote 413 1986 Transmission Assembly Jeep Comanche AOD,2., 03-21-12 7-22-16 ASHBY 11K570 $Call B & S Auto Salvage USA-FL(Wildwood) Request_Quote 352-748-1150 Request_Insurance_Quote 498 1986 Transmission Assembly Jeep Cherokee NICE TRY BA0131 $Call Federal Way Auto Wrecking USA-WA(Auburn) Request_Quote 253-661-1291 Request_Insurance_Quote 2145 1986 Transmission Assembly Jeep Cherokee AUTO 2.8 245,000 C 010404 $Call Parts World USA-OK(Roosevelt) Request_Quote 580-639-2308 / 580-639-2242 Request_Insurance_Quote 898 1985 Transmission Assembly Jeep Cherokee TRA,AT DT7114 $425 3M United Auto Parts USA-CA(San-Jose) E-mail 1-408-998-8661 2140 1985 Transmission Assembly Jeep Cherokee UB56828 UB5682 $345 Truck Parts Company USA-CA(Baldwin-Park) Request_Quote 1-800-411-8718 (Cali only) 626-337-7264 Request_Insurance_Quote 1971 1985 Transmission Assembly Jeep Cherokee 2.5,2WD 0 A MAIN $200 Parts World USA-OK(Roosevelt) Request_Quote 580-639-2308 / 580-639-2242 Request_Insurance_Quote 898 1985 Transmission Assembly Jeep Cherokee 4X2- 050327 $Call Barlow Auto Wrecking USA-WA(Rainier) Request_Quote 1-360-446-7800 Request_Insurance_Quote 2159 1985 Transmission Assembly Jeep Cherokee 2WD 0 A MAIN $Call Parts World USA-OK(Roosevelt) Request_Quote 580-639-2308 / 580-639-2242 Request_Insurance_Quote 898 Transmission Assembly SHOP $Call B & S Auto Salvage USA-FL(Wildwood) Request_Quote 352-748-1150 Request_Insurance_Quote 498 Year Part Model Description Miles Part Grade Stock# US Price Dealer Info Dist mile OR Link to comment Share on other sites More sharing options...
Jeep Driver Posted July 19, 2018 Share Posted July 19, 2018 Same search, you can actually read this one. One looks promising, but he still needs the flex plate. $725 plus freight and then no guarantees, must factor a rebuild. Diminishing returns. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted July 19, 2018 Share Posted July 19, 2018 12 minutes ago, Jeep Driver said: Same search, you can actually read this one. One looks promising, but he still needs the flex plate. $725 plus freight and then no guarantees, must factor a rebuild. Diminishing returns. Why are you searching for an 86 ? He stated in his first post that he has an 87 . Anyhow , if they have the trans .... they had the truck .... and they have the flexplate etc And I can read mine just fine .... Link to comment Share on other sites More sharing options...
Jeep Driver Posted July 19, 2018 Share Posted July 19, 2018 13 minutes ago, Strokermjcomanche said: Why are you searching for an 86 ? He stated in his first post that he has an 87 . Anyhow , if they have the trans .... they had the truck .... and they have the flexplate etc And I can read mine just fine .... Of course you can, it's in your browser, I'm on a large screen and I can't read it. 904 in the 86, no TCM. Apparently some did come with the AW4 after 87, now you can include adding the TCM to the flexplate and the rest of his misfortune. Why am I speaking out against this move? Some of you are more than happy to cheerlead a man right down a rat's hole. It's a dumb move, waste of money and effort. Assuming he accumulated all the right parts the first time, and those are good parts. Mount, cooling lines, cooler, shifter, fluids, flex plate, TCM, wiring, drive shaft.........misc............etc, minimum $1600 or more. And then if a rebuild? out it comes and add $1000. And for what? behind a clapped out 2.5? Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted July 19, 2018 Share Posted July 19, 2018 I had an 87 2.5 aw4 2wd MJ (also had A/C ) , it ran great down the freeway / downtown/etc nothing wrong with that truck by any means . I fail to see where he posted that he was street racing on the weekends and wanted more power , why can't he do what he wants to his own truck ?????? To the OP , no reason you couldn't be into that swap for $500 , where do you live ? Link to comment Share on other sites More sharing options...
Jeep Driver Posted July 19, 2018 Share Posted July 19, 2018 https://knoxville.craigslist.org/search/sss?query=comanche&sort=rel This is what my CL has looked like for the last two years, you can search Cherokee also and it looks about the same, much of nothing in about a 200 mile radius. PnP and other JYs are even more barren. Link to comment Share on other sites More sharing options...
Jeep Driver Posted July 19, 2018 Share Posted July 19, 2018 This is the most XJ this yard has seen in more than 2 years. No 80s XJs or MJs at all. https://www.pullapart.com/inventory/search/?LocationID=10&MakeID=29&ModelID=239&LocationPage=true Link to comment Share on other sites More sharing options...
