What is this?
For the record you can delete it.  But it's part of the emissions system so it may be illegal to do so, and you need to go to a vented cap or run the vent from the tank elsewhere.  On my XJ it is run into a small filter along with a bunch of the other vents.  I retained the restrictor/poppet valve, and it will probably smell like fuel if you don't.
