Lee21490 Posted April 23, 2018 Share Posted April 23, 2018 So tomorrow I'll be looking at a '75 J10 with a 360 in it, Honestly don't really know much about them... Any tips on what i should be looking for? What to watch out for? The listing says it runs, But needs some carb work, 160k miles, $1000, needs it gone asap as he's moving. My goal, Is to use it for a tow rig / Basic needs truck. Don't plan on lifting it or anything crazy, Probably 4 wheel disc upgrade, etc. Any pointers would be appreciated. Link to comment Share on other sites More sharing options...
Keyav8r Posted April 23, 2018 Share Posted April 23, 2018 I think the primary concern is the same as for MJs - RUST! Link to comment Share on other sites More sharing options...
whowey Posted April 23, 2018 Share Posted April 23, 2018 Rust...rust and more rust. I don't know which tranny is in a So tomorrow I'll be looking at a '75 J10 with a 360 in it, Honestly don't really know much about them... Any tips on what i should be looking for? What to watch out for? The listing says it runs, But needs some carb work, 160k miles, $1000, needs it gone asap as he's moving. My goal, Is to use it for a tow rig / Basic needs truck. Don't plan on lifting it or anything crazy, Probably 4 wheel disc upgrade, etc. Any pointers would be appreciated. Rust...rust and more rust. I don't know which tranny is in a 75...but if it is a 727, it's a good solid tranny, but with no OD, it's not a great one for a tow rig. Do a bit of research, as they used closed knuckle axles in some years. Also the QT transfer case can be problematic, but I don't know what years and the exact applications of it.Sent from my SM-S727VL using Tapatalk Link to comment Share on other sites More sharing options...
Lee21490 Posted April 23, 2018 Author Share Posted April 23, 2018 4 minutes ago, Keyav8r said: I think the primary concern is the same as for MJs - RUST! Thankfully rust isn't that big of an issue where I'm at. The pictures i've seen so far look pretty clean at least. 2 minutes ago, whowey said: Rust...rust and more rust. I don't know which tranny is in a Rust...rust and more rust. I don't know which tranny is in a 75...but if it is a 727, it's a good solid tranny, but with no OD, it's not a great one for a tow rig. Do a bit of research, as they used closed knuckle axles in some years. Also the QT transfer case can be problematic, but I don't know what years and the exact applications of it. Sent from my SM-S727VL using Tapatalk It's a manual tranny, Not sure which. Link to comment Share on other sites More sharing options...
Keyav8r Posted April 23, 2018 Share Posted April 23, 2018 If the body and frame are solid I’d go for it. The mechanical bits can be sorted out. Link to comment Share on other sites More sharing options...
DirtyComanche Posted April 23, 2018 Share Posted April 23, 2018 If you're going to drive it a bunch just order a FiTech or Holley Sniper right meow. The frames aren't that strong compared with modern trucks, it is a true half ton. Do not expect to go out and tow 10klbs with it. Otherwise they're pretty simple, make sure the bed seams aren't rusting, along with the cab corners, the fender flares, the bottom of the cab where the cowl drains, and pretty much everywhere else. Oh yeah, spring hangers, they like to rust off. If it has a steel gas tank it will probably be rusted... Link to comment Share on other sites More sharing options...
Smokeyyank Posted April 23, 2018 Share Posted April 23, 2018 If rust is limited for $1,000 that's a pretty good deal. If you want turn it into a tow rig I'd look at swapping out the driveline. The 360 is decent, have one in a CJ, good torque but it's still carbed and at elevation it's a pain. It probably has a T89 or t18 so either 3 or 4 speed manny. The 4 is just a granny gear for 1st. I'd drop in a 350 with TBI vs going with after market EFI's. TBI is tried and true and can be picked up cheaper than the EFI's systems. In any case you can still keep the 360 and swap on a TBI. Just need a manifold adapter plate. Link to comment Share on other sites More sharing options...
carnuck Posted April 23, 2018 Share Posted April 23, 2018 It's a manual tranny, Not sure which. If the oddball 3 speed std then it’s T15 or T86. 4 speed should be T18 (4:1 or 6:1 first gear if T18a) with Dana 20 tcase. D20 was used until ‘80 with std trans then NP208 and Other 23 spline shallow input NP tcases with 727 or 999 Mopar automatics. 6 lug wheels mean ‘74+ with disc front and power brakes. D44 open knuckle front and RH offset rear in J10 until ‘80. D60 rear in J20 with 8 lug and rare-ish rear duallies were available. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Incommando Posted April 24, 2018 Share Posted April 24, 2018 If you get it you will find the experts at www.ifsja.org Link to comment Share on other sites More sharing options...
DirtyComanche Posted April 24, 2018 Share Posted April 24, 2018 3 hours ago, Incommando said: If you get it you will find the experts at www.ifsja.org www.fsjnetwork.com is where more of them wound up after IFSJA was down for an extended period of time... Link to comment Share on other sites More sharing options...
Lee21490 Posted April 24, 2018 Author Share Posted April 24, 2018 Sweet, Thanks guys. So ended up picking it up tonight, Ran like a champ other than the carb is a bit screwy atm. Nothing a good rebuild won't solve. Has the 4 speed, With 2wd/4wd/4wdlow, Thankfully it wasnt the fulltime 4wd variant, and front disc brakes Already has a pretty good looking hitch installed Plan on doing a tuneup, Replacing the intake manifold gasket, Front shocks, belts & rebuild the carb for now Also plan on cleaning up the underbody of rust & painting it. Truck came from utah, So it has a bit more rust than typical around here, But still not bad at all. There's not a single rust spot on the entire bed, Just a couple small holes around a couple fenders Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 24, 2018 Share Posted April 24, 2018 6 hours ago, Lee21490 said: Sweet, Thanks guys. So ended up picking it up tonight, Ran like a champ other than the carb is a bit screwy atm. Nothing a good rebuild won't solve. Has the 4 speed, With 2wd/4wd/4wdlow, Thankfully it wasnt the fulltime 4wd variant, and front disc brakes Already has a pretty good looking hitch installed Plan on doing a tuneup, Replacing the intake manifold gasket, Front shocks, belts & rebuild the carb for now Also plan on cleaning up the underbody of rust & painting it. Truck came from utah, So it has a bit more rust than typical around here, But still not bad at all. There's not a single rust spot on the entire bed, Just a couple small holes around a couple fenders For a $1000? and you had to ask? :) What a deal. Nice. Link to comment Share on other sites More sharing options...
DirtyComanche Posted April 24, 2018 Share Posted April 24, 2018 Yeah, that's a steal. Link to comment Share on other sites More sharing options...
carnuck Posted April 29, 2018 Share Posted April 29, 2018 The full size didn’t come with full time 4x4 with stick transmissions from the factory. Dana 20 with 6 lug wheels and std trans until ‘80 Model year. They switched from RH drop front axle to LH in ‘80 and the NP219 was available for 2 years with std trans and 4.2L but rarely. The viscous coupler didn’t like the shock loads. Most standard trans after ‘79 came with NP208AM as a combo. The 727 and 999 Auto ones ‘80+ came with NP219 (80-early ‘82) and was called Quadratrac but was more like a Quasi trac and not to be confused with the Borg Warner 1339 used before ‘80 and only with TH400 automatic ‘73-‘79. Better than full time 4x4 NV249 but not by much other than being able to lock 4 hi when needed. NP208 was part time Commandtrac with no internal coupler or differential and often came with locking hubs. And there was NP229 Selectrac used in 90% of the ‘83+ FSJs till the end in Sept ‘91 except ‘86ish which got NP228 (same Selectrac as NP229 but no viscous coupler, like a non-posi axle) Link to comment Share on other sites More sharing options...
