voecks1 Posted April 5, 2018 Share Posted April 5, 2018 Does anyone have a picture of a stock OEM rear bumper of a 1989 Comanche (Base)? Or know where I could buy one? Thanks! Link to comment Share on other sites More sharing options...
Dando Posted April 5, 2018 Share Posted April 5, 2018 Link to comment Share on other sites More sharing options...
krustyballer16 Posted April 5, 2018 Share Posted April 5, 2018 Did base models come with bumpers?Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
Pete M Posted April 5, 2018 Share Posted April 5, 2018 yes. the bumper delete (or whatever it was called) was an option you needed to check. Link to comment Share on other sites More sharing options...
gogmorgo Posted April 6, 2018 Share Posted April 6, 2018 As to where you can buy them... Good luck. You might find one at a wrecker, although most are pretty beat up, rusted out, or both, by the time they make it to a yard. They do sometimes come up on Craigslist or eBay for a pretty good dime. Link to comment Share on other sites More sharing options...
krustyballer16 Posted April 6, 2018 Share Posted April 6, 2018 yes. the bumper delete (or whatever it was called) was an option you needed to check. O I thought you had to order the bumper. Makes sense. Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
54bobby Posted April 6, 2018 Share Posted April 6, 2018 i have the fey and it's pretty close. Link to comment Share on other sites More sharing options...
Eagle Posted April 6, 2018 Share Posted April 6, 2018 That Fey universal is probably as close as you're going to get, but IMHO it's not very close. I keep wondering if it might be possible to somehow attach MJ bumper end caps to the Fey bumper. That would make it look a lot better. 54bobby, were you able to use the Fey brackets as they came out of the box, or did they require grinding to eliminate body interference? Link to comment Share on other sites More sharing options...
krustyballer16 Posted April 6, 2018 Share Posted April 6, 2018 Build one. Or 2. Lol. Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
DirtyComanche Posted April 6, 2018 Share Posted April 6, 2018 There's a Dakota bumper on mine. Do not recommend. Link to comment Share on other sites More sharing options...
Eagle Posted April 7, 2018 Share Posted April 7, 2018 2 hours ago, DirtyComanche said: There's a Dakota bumper on mine. Do not recommend. Why not? Got a photo? Link to comment Share on other sites More sharing options...
WahooSteeler Posted April 7, 2018 Share Posted April 7, 2018 I have an early 2000s S10 bumper on mine. It's a tad narrow so if you wheel your lower bed corners could be exposed a little more than with a stock bumper. Some have commented they don't like the look that it's narrow, but IMO when looking at it from behind it follows the taper of the bed corners and looks pretty good. Link to comment Share on other sites More sharing options...
PCO6 Posted April 7, 2018 Share Posted April 7, 2018 13 hours ago, krustyballer16 said: Build one. Or 2. Lol. Sent from my SM-G892A using Tapatalk That looks great. I'm curious about the gauge of the original bumpers vs. the Fey/Westin ones. Are they the same? I'm thinking the originals might be a bit heavier. I guess you could go with what you want (within reason) if you fabricate a replica. Has anyone fabricated a rear bumper using a front bumper as a starting point? Link to comment Share on other sites More sharing options...
krustyballer16 Posted April 7, 2018 Share Posted April 7, 2018 That looks great. I'm curious about the gauge of the original bumpers vs. the Fey/Westin ones. Are they the same? I'm thinking the originals might be a bit heavier. I guess you could go with what you want (within reason) if you fabricate a replica. Has anyone fabricated a rear bumper using a front bumper as a starting point? I think original and Fey are about the same gauge material. Neither was very thick. 12 gauge maybe. And I think people have used a front bumper on the rear. Looks...ok..For a good looking bumper, I'd go with dirtbound. Might be an "offroad" bumper but it's the best looking option I think. Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 7, 2018 Share Posted April 7, 2018 XJ rear bumper on an MJ, dasbulliwagen's MJ. I like it. Link to comment Share on other sites More sharing options...
PCO6 Posted April 7, 2018 Share Posted April 7, 2018 4 hours ago, krustyballer16 said: I think original and Fey are about the same gauge material. Neither was very thick. 12 gauge maybe. And I think people have used a front bumper on the rear. Looks...ok .. For a good looking bumper, I'd go with dirtbound. Might be an "offroad" bumper but it's the best looking option I think. Sent from my SM-G892A using Tapatalk 12g would be good. I was thinking 14g. I have a Fey on mine and was wondering if an original is a bit thicker. Mine's "OK" but I'd like to pick up an original. I found one that could have been restored ... but I had to take the whole truck and that was the only good part on it! I have a set of JCR bumpers off of my old XJ that I was going to use (front is easy - rear can be modified) but I'm now leaning toward stock or stock slightly modified. I won't be off roading my MJ. Basic uses will be camping, fishing, kayaking, trips to Home Depot ... and the dump of course! Link to comment Share on other sites More sharing options...
PCO6 Posted April 7, 2018 Share Posted April 7, 2018 24 minutes ago, HOrnbrod said: XJ rear bumper on an MJ, dasbulliwagen's MJ. I like it. Thanks. That DOES look good and the end caps tie in nicely. Link to comment Share on other sites More sharing options...
gogmorgo Posted April 7, 2018 Share Posted April 7, 2018 Question though is where you put the license plate. Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 8, 2018 Share Posted April 8, 2018 13 minutes ago, gogmorgo said: Question though is where you put the license plate. 87-01 XJ front plate holder Link to comment Share on other sites More sharing options...
krustyballer16 Posted April 8, 2018 Share Posted April 8, 2018 87-01 XJ front plate holder So obvious. Makes sense! AhahaSent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
Eagle Posted April 8, 2018 Share Posted April 8, 2018 10 hours ago, HOrnbrod said: XJ rear bumper on an MJ, dasbulliwagen's MJ. I like it. I like it, too. But what do you do about a license plate and light? The cops are strict about license plate lights around here. Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 8, 2018 Share Posted April 8, 2018 I think it would be quite easy to find a couple of miniature LED fixtures to mount on each side on the plate holder... Link to comment Share on other sites More sharing options...
PCO6 Posted April 8, 2018 Share Posted April 8, 2018 An interesting fabrication project would be to convert an XJ front bumper in to an MJ rear step bumper. It wouldn't be that hard ... it's only metal! Link to comment Share on other sites More sharing options...
krustyballer16 Posted April 8, 2018 Share Posted April 8, 2018 An interesting fabrication project would be to convert an XJ front bumper in to an MJ rear step bumper. It wouldn't be that hard ... it's only metal! Now you got me thinking! Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
