Rob1989 Posted January 4, 2018 Share Posted January 4, 2018 I need a new break light wire tab. Keep having the same issue ofbthe wire coming off the tab and them both falling off. Need help ASAP. I don't check this often so best way is a quick text. 609-470-0483. Thanks. Link to comment Share on other sites More sharing options...
carnuck Posted January 4, 2018 Share Posted January 4, 2018 I need a new break light wire tab. Keep having the same issue ofbthe wire coming off the tab and them both falling off. Need help ASAP. I don't check this often so best way is a quick text. 609-470-0483. Thanks. I put a rubber band on mine. Link to comment Share on other sites More sharing options...
Eagle Posted January 4, 2018 Share Posted January 4, 2018 I have no idea what the opening post is asking about. What tab? Where? Are we asking about broken wires, or wires somewhere in the "brake" light circuit? Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 4, 2018 Share Posted January 4, 2018 Me either. And when someone figures out what a break tab is, make sure you text the OP too. Link to comment Share on other sites More sharing options...
Skorpyo Posted January 4, 2018 Share Posted January 4, 2018 Yeah... if you're not going to "check back" then why ask for help??? I'm not gonna text some random person to help them, for all I know they might never leave me alone, or be a jerk, or a stalker... If I had a $1 for every time someone said they put new "breaks" on their jeep, or wanted to know what kind of "wench" to get i wouldn't need a day job... Link to comment Share on other sites More sharing options...
yxmj Posted January 4, 2018 Share Posted January 4, 2018 But on the bright side.....you can fix it with a rubber band...... Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 4, 2018 Share Posted January 4, 2018 2 minutes ago, yxmj said: But on the bright side.....you can fix it with a rubber band...... You can fix most anything with a rubber band, including your own broken wire.... Link to comment Share on other sites More sharing options...
Eagle Posted January 5, 2018 Share Posted January 5, 2018 21 hours ago, Skorpyo said: If I had a $1 for every time someone said they put new "breaks" on their jeep, or wanted to know what kind of "wench" to get i wouldn't need a day job... I've always been partial to tall, slender blondes, myself. Link to comment Share on other sites More sharing options...
yxmj Posted January 5, 2018 Share Posted January 5, 2018 I would like one as well please ****note.....I will supply any require rubber bands....***** Link to comment Share on other sites More sharing options...
cruiser54 Posted January 7, 2018 Share Posted January 7, 2018 Brakes: I've seen drum and disc brakes, drums and discs break, but never drum or disc breaks. BTW, only one person "understood" the OP's predicament and responded......... Link to comment Share on other sites More sharing options...
Eagle Posted January 7, 2018 Share Posted January 7, 2018 3 hours ago, cruiser54 said: Brakes: I've seen drum and disc brakes, drums and discs break, but never drum or disc breaks. BTW, only one person "understood" the OP's predicament and responded......... Several people responded, but I don't see any indication that anyone understood what the question is. Link to comment Share on other sites More sharing options...
COMJNUT Posted January 7, 2018 Share Posted January 7, 2018 I'm guessing it is the tab to the brake light switch, either get a friend to solder the wire to the tab on the switch or put a screw through the tab to hold the connection together. I had this issue with a thermostat connection on a freezer. The vibrations from the compressor motor would shake loose the connection and the freezer would shut off. Link to comment Share on other sites More sharing options...
sinkrun Posted January 7, 2018 Share Posted January 7, 2018 Tie wraps work well also... Link to comment Share on other sites More sharing options...
