your favorite youtube channels
Pete M
Comanches and an Eagle sported in David Freiburger’s new video. Around the 51-52 minute mark. Looks like the one that’s not in the picture has a factory Sportbar.
  • Replies 142
Good eye! That one needs to be saved. Dang.
Two of my automotive favorites:
Excellent Jeep cherokee / comanche content
https://www.youtube.com/@WAEMIDIV/videos
Incredibly detailed Landrover repairs from a very witty german family:
https://www.youtube.com/@Vera_and_Christian
Ha ha, I was surprised that he had seemed to ignore it at first.
I like that color combo..don't think I've noticed a white MJ with the gold stripe before
New to Comanche Club and just found this section. :D Better plug myself in here. My channel is called Montana Offroad.
Previously I have done Jeep TJ videos but I acquired a ‘Manche (my dream rig) last year and will be restoring it. Should be interesting content for Comanche enthusiasts! :beerchug:
Looks great!
The rear window is not original. Jeep used a 3 panel window.
The door mirrors are after market. Try getting XJ mirrors to replace the others.
18 minutes ago, 87MJTIM said:
Looks great!
Wow, you are right on the rear glass. I never noticed that. Good eye.
I think the aftermarket sliding rear windows are superior to the OEM ones. The opening is larger, so you can enter through it if needed and it moves so much more air when going down the road with it open.
It is certainly handy. I don’t have AC in mine so it see it’s fair share of use!
On 1/27/2025 at 6:53 AM, Eagle_SX4 said:
I don't think they are after market just the base model mirrors that are not very common. Check out this diagram from moparpartsgiant. https://www.moparpartsgiant.com/parts-list/1988-jeep-comanche/body_doors_and_related_parts/mirror_exterior.html?filter=(E=ERB;T=DGS)&diagram=000019D8
Okay so they are original? Just the base mirrors? I would like to make sure whatever is on there is original to the Comanche.
I am pretty sure they are original. The YJ used the same mirrors for the base model as well.
https://www.moparpartsgiant.com/parts-list/1992-jeep-wrangler/body_doors_and_related_parts/mirror_exterior.html
Ruged ridge makes brand new ones. https://www.extremeterrain.com/rugged-ridge-left-mirror-yj-1100217.html
Awesome! Thank you. I may replace them for some higher trim level oem Comanche mirrors at some point (for better vision) but good to know!
Best mirrors for visibility are the 97+ XJ mirrors. Although you will need all of the window trim from the 97+ for them to seal properly against the door.
I think I’d prefer to stay within ‘86 to ‘92 if I go with anything new.
