  • 1 month later...
  • Replies 95
Got to take the MJ out for a quick run through some rocks.  I'll be putting some hockey puck bump stops up front to save the fenders.  I need to fix the rear sag, so I'll probably do some Chevy drop shackles and shocks in the rear.  I also have JCR sliders that I hope to install in the next couple of weeks.
  • 5 weeks later...
  • 5 months later...
It has been a long time since my last update! I recently put a ZJ steering box and new XJ pump in my MJ, and painted the topper to match the truck.  And I've been wheeling almost every weekend!  I also graduated from engineering school and landed a pretty badass job here in Denver, so I'm looking forward to sinking all my money into my Jeep!
35026769_10215620107831449_3392239722423123968_n.jpg.0e22846b4d336bda4686bac1a81cabec.jpg
36851113_10215828552442434_3047127147295539200_n.jpg.5cd5671df00a659dd736ac0fa138bc7a.jpg
36946242_10215828551402408_3380641734470926336_n.jpg.25fa31a03733cb5f95187b55df2892ce.jpg
36946636_10215828551922421_237803246733754368_n.jpg.ba13dfe76989f24a4cbbd4dcaef6114a.jpg
Looks awesome, congrats on graduation also. I'm due to graduate engineering school in the next year or so. In these latest photos did you install the drop shackles and bump stops?
Sent from my SM-G955U using Tapatalk
Thank you! Also congrats on almost making it! It's one hell of a feeling to be done!
The front has 4.5" coils, and one side has the factory bump stop.  It's missing on the other side.  I'm working on fixing the missing bump stop and installing some hockey pucks up front.
The back is a set of Chevy drop shackles from Advance Auto parts.  Factory bump stocks in the rear. It definitely sags a bit in the back.
  • 3 weeks later...
After rebuilding the Powertrax No-Slip last night in the rain, I took the MJ out to do Red Cone.  Nothing was broken in the locker, but putting new springs in it didn't fix it.  I've had so many problems with it, I think i'm going to pull it out and put something else in.
  • 3 weeks later...
On 8/26/2018 at 6:00 PM, 88whitemanche said:
Looking good bud, love that your enjoying the truck
look into the aussie I have one in mine with no issues by far....
I was definitely considering an Aussie.  I think that's the route I'm going to take.  I'm not sure why I'm having so many problems; most people really like the Powertrax.
I do appreciate the suggestion! Thank you!
  • 1 year later...
Man, it has been WAAAY too long since the last update. I have been constantly working on the MJ for the last 2 years, so I'll try to go through all of the updates.
Last summer I changed the rear axle to SOA, which was quite the experience.  I also switched to rear discs at the same time, which was a huge pain.  The original Powertrax No-Slip had somehow malfunctioned and prevented the C-Clip from coming out of the carrier.  I eventually had to take it to High Country 4X4 here in Denver, where they had to cut the carrier in half!
I also picked up some JK Rubi wheels (for free!) and some 315/70/17 KO2's.  I used some G2 1.5" adapters to bolt them up.
Here's SOA with the add-a-leaf (and the GF pointing at it and telling me how stupid it looks being that tall)
Here's the final config with the original 2WD leaf springs (much better)
It settled over the summer and looks much better now. More pictures to come.
At some point I installed an Iron Rock Offroad 3 link, but I don't have many pics of that.  The worst part, by far, was cutting the control arm brackets off.  I left the stock upper mount on the passenger side and carry the old short upper link for emergencies (I have no idea if this would work, but i'm sure I could limp off a trail with it).
The biggest Jeep thing of 2019 was attending the Moab MJ Takeover.  It was the coolest experience!
We all ran Hells Revenge together.  It was really cool to see all of these MJ's in the same place!
On the next day, the group split into two parties.  We decided to go on the milder run because I was having some mechanical issues.
First off, I was running a stock upper control arm bushing with the 3 link, which was a huge mistake.  I ended up blowing through 3 control arm bushings; we even changed one on the trail.  This caused the upper link to contact the driveshaft under any sort of flex.  By the time we left for home, the day-old bushing had blown out, which caused the axle to rotate and we drove it from Moab to Denver with 0 degrees of caster.  Not the worst, but pretty bad at highway speeds for a couple hundred miles.
The the transfer case was also puking fluid, and the water pump was going out.  So, no hard core wheeling for us.  But we had an awesome day anyways!
We ran up Gemini Bridges and came back to town via Long Canyon (which was an amazing trail for how easy it was).
On the last day, we ran Fins n Things with one of the other group members.  We took it nice and slow, and had a great time!
We also saw a bunch of the JCR guys out there, which was pretty cool (I didn't get any pictures).  That LSX LJ they have is absolutely beautiful in person!
And that brings us to the current projects.  I drove the MJ all winter and it performed flawlessly.  It handles really well in the snow with the rear locker and the full time 4x4.
I've been trying to figure out how to protect the bottom of it better.  My main concern is the gas tank that hangs below the frame rails.  I'm still working on the design for that.
A couple of days ago I decided to clock my NP242 to use the IRO belly skid (that technically only works on the smaller NP231).  I used the IRO jig that they sell, and it was super easy.
For reference: I clocked the transfer case ~10 degrees.  Everything fit together perfectly without extra modification (no floor hammering).  Of course the stock linkage didn't really work, so I ordered the Boostwerks kit for the 242.
Upon disassembly of the t-case shifter, I happened to peel the carpet back a little farther than I had planned.  Considering this truck came from Arizona, I was reasonably shocked at what I saw.
However, once I sanded down the rust and prepped for paint, I found that it was all surface rust.  Either way, the interior came out, everything got sanded, and I'm in the process of priming and painting currently.
  • 4 months later...
Ok, time for some more updates!
I decided to swap out my steering gear because it had gotten really sloppy in the last year.  However, I ended up replacing the gearbox twice, and the pump five times before I had functioning power steering.  Every time I bled the system, it would work just fine.  Every pump died after a day or so (you could see the fluid in the reservoir stop flowing under load).
I had a big rush to finish this because the gf and I were planning on taking a road trip from Denver to St. George, UT, then through Arizona, totalling ~1600 miles.  The truck was actually running really well, so we decided to take it.
The Jeep also kept blowing O2 sensor fuses.  I had found a couple of wires that had missing casing, which all got fixed.  About 60 miles into our trip, which I assumed was now being caused by a bad rear O2 sensor connector (it had gotten wrapped around the driveshaft at some point, and I failed to realize a part of the plug was missing, meaning it didn't make a secure connection).  We contemplated turning around, but I had fixed the questionable plug, which I once again assumed was the issue.  So we continued on...
Camp site for night one, just outside of Green River, UT.
We ended up making it to the east side of Zion on the second day.  The truck was running great and getting decent gas mileage, even with the A/C running non-stop.
After a day or two in the St. George area, we headed east on our way to the North Rim of the Grand Canyon.  Right as we crossed the AZ border, the truck started misfiring and lost a significant amount of power.  Assuming it was another O2 sensor fuse, I hopped out with a replacement, only to find that it hadn't blown.  After checking codes, I discovered a misfire on cylinder 3.  While freaking out about what to do, I checked the easy things (plug, wire, injector) which all seemed to be fine.
We made the decision to turn back to St. George and find a shop.  We found a really reputable shop about 60 miles away and limped it there (which involved some neutral to drive shifting in traffic to keep the truck from dying).  Super sketchy, but we made it.  Then we had to find a rental car and a hotel.  After spending a couple more days waiting for the diagnosis, it was determined that something was up with the exhaust valve.  At that point, we decided to scrap the rest of the trip, rent a Uhaul and trailer for the truck, and head home.  After getting the truck and trailer, and a crap ton of stressed contemplation, we decided that a transport would be a better idea.
We found a reputable transport (after a good amount of work), got another rental car, and headed for home.  That was last week.  The truck should be arriving some time on Friday.
seems to be a google account but I can't see them, even if I copy/paste the address. :(  you can host them here at the comancheclub.  just upload them from your computer. :L:
also, howdy friend!  good to see ya!  :waving:
  • 3 weeks later...
Pete, I have just been copy/pasting my photos into my text here.  I wonder why they suddenly stopped working?
