feerocknok Posted July 29, 2007 Share Posted July 29, 2007 What would cause this? In case you can't see it well in the pics, it looks like a well used wire feed welding tip. I know the huge crack doesn't show at all on it. Lastly, the ground, instead of curving over, just kind of leans inward. The plug is my #2 cylinder plug and has bout 3000 miles on it. #1, 3 and 4 all show a lean condition. This is my brand new motor that started rod knocking in the third cylinder so I pulled it to have it re-rebuilt. Link to comment Share on other sites More sharing options...
bhorocks Posted July 29, 2007 Share Posted July 29, 2007 wow..... thats all i can really say about that... Link to comment Share on other sites More sharing options...
feerocknok Posted July 29, 2007 Author Share Posted July 29, 2007 wow..... thats all i can really say about that... Yeah, and the pictures make the plug look Good. Link to comment Share on other sites More sharing options...
Wildman Posted July 30, 2007 Share Posted July 30, 2007 Never seen a plug like that, and you say there are only 3k miles on them. I have No idea what caused that :hmm: Link to comment Share on other sites More sharing options...
whowey Posted July 30, 2007 Share Posted July 30, 2007 WOW!!!! That looks to be running RICH, really, really RICH. The only other time I saw a plug looking anywhere close to that was a race motor that overheated, and it was experiencing uncontrolled combustion. Link to comment Share on other sites More sharing options...
feerocknok Posted July 30, 2007 Author Share Posted July 30, 2007 But it's TBI and the other 3 plugs were lean, so I don't understand! Link to comment Share on other sites More sharing options...
rockhardzj Posted July 30, 2007 Share Posted July 30, 2007 my guess is its getting very hot in that cyl. only guess with TBI would be that the cyl isnt being lubricated completely, making extra heat, explosions are stronger, and melted the ground? I'm probably way wrong, but it's an idea, a possibility. Seems logical, but out there. Pull the head, and check what the cyl walls and the head looks like. also, maybe an ignition problem, for some reason getting stronger sparks, acting like a plasma cutter? Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 30, 2007 Share Posted July 30, 2007 I don't know much about spark plugs, but it looks like you had some nasty pre-ignition or perhaps FOD, which obliderated the plug and then it was followed by carbon fouling as that cylinder wouldn't run worth $#!& (probably didn't even fire half the time). The lean condition on the other plugs is possibly related because a cylinder not firing messes with the O2 sensor readings. While it doesn't matter as much on water cooled engines, any chance the plug was dropped/smacked before install? If you break the insulator they don't shed heat correctly and can cook themselves... It's more apparent in an air cooled engine. Link to comment Share on other sites More sharing options...
possum Posted July 30, 2007 Share Posted July 30, 2007 Bad timing also could cause pre-ignition which would lead to that cylinder overheating. :dunno: Link to comment Share on other sites More sharing options...
JeeperjohnfromPA Posted July 30, 2007 Share Posted July 30, 2007 You mention a Crack that didn't show in the photos. If the ceramic on the plug is cracked, then the plug won't cool properly, which might explain this. Try a new plug and see what happens. If a new plug gets fubard too, then you know it's something besides the plug! Link to comment Share on other sites More sharing options...
feerocknok Posted July 31, 2007 Author Share Posted July 31, 2007 K, what I think it might be is: Motor was running lean. Vacuum leak on the motor faulted the timing. Cracked plug couldn't cool. Cracked plug burnt up. Other cylinders stayed lean. Cylinder 2 couldn't fire many, if any, times. Extra fuel in cylinder makes plug show rich. That's kind of what I gathered from what everyone says and put together as pretty logical. I can't try another plug right now because the motor's out of the truck to be rebuilt, again, but I'll make sure that the new set of plugs don't get dropped. The old ones might've; it happens. Thank you, guys! Link to comment Share on other sites More sharing options...
Darren Posted July 31, 2007 Share Posted July 31, 2007 look good to me, if i were you i'd put it back in! 8) Link to comment Share on other sites More sharing options...
