Wood90 Posted January 7, 2017 Share Posted January 7, 2017 Came across a great deal on some rubicon hard rock wheels and was wondering if anyone has pictures of a 245/70 r17 tire on their truck. I'm running 30x9.50's right now with no rub at stock height, but would also like to level out the front of the truck if I go with the 245's, any suggestions? Thanks! Link to comment Share on other sites More sharing options...
Eagle Posted January 7, 2017 Share Posted January 7, 2017 Came across a great deal on some rubicon hard rock wheels and was wondering if anyone has pictures of a 245/70 r17 tire on their truck. I'm running 30x9.50's right now with no rub at stock height, but would also like to level out the front of the truck if I go with the 245's, any suggestions? Thanks! On 17" rims those are 30-1/2" tires, which makes the diameter about the same as most 31s. The width will be a bit narrower, though.They should work okay if you like the wheels. Link to comment Share on other sites More sharing options...
Pete M Posted January 7, 2017 Share Posted January 7, 2017 those are newer Jeep rims with the 5on5 bolt pattern, yes? spacers will push it out and less backspacing could put it right up to the fenders when turning. going to be close but it might work. 1.75 or 2" coil spacers are easy to come by for leveling the front. you'll want to check the alignment after any lifting. Link to comment Share on other sites More sharing options...
Eagle Posted January 7, 2017 Share Posted January 7, 2017 those are newer Jeep rims with the 5on5 bolt pattern, yes? I forgot about the bolt pattern difference. My bad. Link to comment Share on other sites More sharing options...
Rockfrog Posted January 14, 2017 Share Posted January 14, 2017 The newer wheels have a 6.5" backspace, most pattern adapters are 1.25" thick, meaning ... They reduce the wheels backspacing to 5.25" or pretty much stock backspacing. I ran a set for a while before I switched to Charger wheels. No pictures of 245/70r17's but I do of 255/75r17's Sent from my SM-G930W8 using Tapatalk Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 14, 2017 Share Posted January 14, 2017 I've got 265/75R17s on mine right now, or I think that's what they are. 17" JK Moab wheels and 1.25"? G2 adapter spacers. Definitely wouldn't fit at stock height with those. Link to comment Share on other sites More sharing options...
Crash Posted January 17, 2017 Share Posted January 17, 2017 Synergy/poly performance sell a 1.5 wide adapter. Link to comment Share on other sites More sharing options...
Incommando Posted January 18, 2017 Share Posted January 18, 2017 I've got 265/75R17s on mine right now, or I think that's what they are. 17" JK Moab wheels and 1.25"? G2 adapter spacers. Definitely wouldn't fit at stock height with those. 255/75/17. Roughly a 32x10 tire Link to comment Share on other sites More sharing options...
cruiser54 Posted January 18, 2017 Share Posted January 18, 2017 Link to comment Share on other sites More sharing options...
early comanche owner Posted July 30, 2020 Share Posted July 30, 2020 On 1/18/2017 at 6:09 AM, Incommando said: 255/75/17. Roughly a 32x10 tire is that with standard springs? I am looking at some with the spacers on wrangler wheels but don't want to raise or rub. thanks Link to comment Share on other sites More sharing options...
early comanche owner Posted July 30, 2020 Share Posted July 30, 2020 On 1/13/2017 at 11:51 PM, Rockfrog said: The newer wheels have a 6.5" backspace, most pattern adapters are 1.25" thick, meaning ... They reduce the wheels backspacing to 5.25" or pretty much stock backspacing. I ran a set for a while before I switched to Charger wheels. No pictures of 245/70r17's but I do of 255/75r17's Sent from my SM-G930W8 using Tapatalk did your 255/75/17 fit stock without rubbing? i am looking as some wrangler wheels with adapters Link to comment Share on other sites More sharing options...
JustEmptyEveryPocket Posted July 31, 2020 Share Posted July 31, 2020 3 year old thread. Not likely to get a fast answer. Link to comment Share on other sites More sharing options...
Pete M Posted July 31, 2020 Share Posted July 31, 2020 Rockfrog is still active. he might see it. if not, I would send a private message to get his attention. Link to comment Share on other sites More sharing options...
