What is it ?
ok guys take a look at this pic
and hopefully you can tell me what it is
its under the bed on the driver side rear
i was wondering what does it do and if i need it or can i remove it
it has like a swinging bar that swings from left to right
That's the load sensing (or height sensing) proportioning valve for the rear brakes. The purpose is to reduce pressure to the rear brakes when the truck isn't loaded, so the rear brakes don't lock up too soon and cause you to spin out. As the bed is loaded, the bed drops relative to the axle, causing the arm to move and increase the amount of pressure to the rear brakes.
However, that swinging arm is supposed to be horizontal, and there should be a connector link to a ball stud on the differential housing. Yours appears to have been disconnected by some previous owner.
There are photos in other threads here that show how it's supposed to look. Do some poking around in this discussion area and the D.I.Y. area, or maybe someone who remembers where to find the photos will jump in with a link.
when you say horizontal do you mean its suppose to swing from front bumper to rear bumper ?
ok i will look around to see what its suppose to look like
hopefully some one will post a pic of how it should look
so basically you recommend that i keep in on there and don't remove it
No, it's swinging across the vehicle centerline, correct? You wrote that it swings left to right. The basic position for it should be swung to the right (passenger side) and up, so the arm is parallel to the ground.
oh ok so it swings from the top of the driver side rear tire down to the rear axle ok i get it
but where does the other end of that metal rope connect to ?
Did you click the link I provided?
That tire in the photo is not the driver's side tire, it's the spare.
ok i clicked on the link and i see what your saying it regulates the brakes so they will be stronger in the back if a heavy load is applied to the bed
so if i remove it then when my bed is carrying a heavy load i will not get as much breaking power as with it on
No.
Go to the D.I.Y. area of the forum and you'll find an article on how to remove it. It's not as simple as it seems, because it involves the total removal of one of the two brake lines from the front to the rear -- and many people remove the wrong one before they figure out the mistake.
If you remove it, you will always have FULL brake power to the rear wheels. That might sound like a good thing, but the back of a pickup is pretty light when there's no load, so on snow or ice, or in a panic stop, or even in the rain, the rear wheels will lock up before the fronts. That causes spin-outs. That's why the factory put that thing in there. You would be better advised to fix up a rod and connect it so it functions properly.
Another thing you can do if you can't get the rod or the bracket is gone from the diff is use a piece of wire or a zip tie to hang the swinging arm in the 2-3 oclock position from above. This will give you some use of your rear brakes back without going through the trouble of finding the parts you need to fix it properly.
No it helps minimize body roll when turning or driving across a slope. It also limits the flex of vehicles so most offroad rigs don't have them. Does nothing as far as strength to the axle.
Side note, Google is your friend as is the search box here.
