dustyinthedirt Posted August 9, 2016 Posted August 9, 2016 Would a Xj rocker fit a Mj? i know some alterations will have to be done but will they look the same? I will probably go to the pick a part or a JY and cut one out of a Xj. Any suggestions ideas on how to make this easier? Its rusted out along the full length on one of my Mjs and i have a rust hole on the other as well!! :fs1: I don't wanna take a pic my DD Mjs rust spot. I'm still in denial even though its now a fifty cent piece sized hole!!! :wall:
dustyinthedirt Posted August 9, 2016 Author Posted August 9, 2016 http://www.rockauto.com/en/catalog/jeep,1989,comanche,2.5l+150cid+l4,1181663,body,rocker+panel,1092 i found these but are they worth getting? not a bad price
87MJTIM Posted August 9, 2016 Posted August 9, 2016 Z&M out of Toledo OH has MJ rockers. I picked up a driver's side for $40 at the York PA Jeep show last July. He had both driver's and passenger's side for $40 ea.
mikekaz1 Posted August 10, 2016 Posted August 10, 2016 http://www.rockauto.com/en/catalog/jeep,1989,comanche,2.5l+150cid+l4,1181663,body,rocker+panel,1092 i found these but are they worth getting? not a bad price are those "backing plates" the inner rockers? that's what it looks like to me atleast.... didn't know those were available
dustyinthedirt Posted August 11, 2016 Author Posted August 11, 2016 supossedly and i look at the site for Z&M they have some as well. Z&M carries the Sherman brand as well but they are a little cheaper on rockauto.
krustyballer16 Posted August 11, 2016 Posted August 11, 2016 None of the rockers that anybody makes are anywhere close to fitting or looking right! Mj rockers have a unique shape and companies that make replacement rockers don't follow this unique shape. If you want a nice factory look, you'll have to make your own. That's my experience with them. I've tried Sherman's and C&C. Neither are close. Hard to tell but these are made from scratch... End result. Can't even tell. Perfect
Jeepman Posted August 11, 2016 Posted August 11, 2016 None of the rockers that anybody makes are anywhere close to fitting or looking right! Mj rockers have a unique shape and companies that make replacement rockers don't follow this unique shape. If you want a nice factory look, you'll have to make your own. That's my experience with them. I've tried Sherman's and C&C. Neither are close. Nice Job but No necessarily so true... I have stamped steel 2door/4door XJ Rocker on my MJ and they fit and look like MJ rockers, its all in the product so buy the Good stamped steel panels and trim to fit... Love how mine turned out and you can get them at any LKQ Keystone Distributor... Image Not Found Image Not Found
dustyinthedirt Posted August 17, 2016 Author Posted August 17, 2016 Those look awesome! thanks for the advice from all you guys. will keep this updated as i go
