  • Replies 131
2B3F5180-0EE6-4EE5-B65B-D4CB295934F3.jpeg.e730b2a176e3ce2c92d50cc7b51ea7e8.jpeg81FC9109-D839-44A8-8BEF-5124F612E815.jpeg.f6039a534dca6bab2f7e61150a76a19b.jpeg
Got the upper link burned in. Had to knot h the frame to more easily access the upper link. I am considering welding in the cross member since middle drops out so I can remove the trans. The idea of two bolts holding the control arms, trans and tcase doesn’t seem safe to me
26E0EF8D-156E-4A21-AC5D-A2268C7AD488.jpeg.ba04958a6d9ebe3767b5978f4a253dea.jpegThe opening for the control arm but was to small for a nylock nut. A carbide endmill makes quick work of that6E662EB3-6AF6-4759-943B-30E0820B1F53.jpeg.1c5c9a020569ce701f78a290ef8f3ba1.jpeg
Also used the stock superduty shock mounts for mine just cut and altered them to be welded on instead of u bolted81CCA32C-706A-457A-ADDC-EC5775F1AAED.jpeg.dbec1c1bbe6f59038cce3d1ee01b9136.jpeg1705AA92-06C5-4787-991D-F2785C4D4058.jpeg.bdb2502daec6884a2b9c305e8ec80fe6.jpeg
Well it’s sitting on its own weight, with 37” swampers (more like 36”)
i haven’t trimmed anything yet cause I wanna flex it out once I get driveshafts in.
it sits a little nose down but the body lines are also nose down and the frame is flat across the bottom
22” from ground to crossmember
(lowest point on frame)
25” from ground to frame
114” wheelbase
71” rotor face to rotor face
(I should have measured hub to hub but my arms are to short)
5ACF2FDB-FE75-41CD-9CA3-04ED28BCB13C.jpeg.8d4e4265efabb59af11f0c70b2b24cab.jpeg60E18DE9-FC9E-4C64-A943-8E06FA0EF43E.jpeg.bc859618745593dd1d4826c33ca2f08f.jpegA60111BE-3803-46B0-830A-3A5202878199.jpeg.9c92f64a5bebe5ff24cf0372bd6856be.jpeg
The stock box leaked fluid so as I was replacing the seals I went ahead and tapped it for hydro assist. Much easier to tap then expected. I did have to pull the box apart twice to make it work correctly
made a double sheer steering setup yesterday. All out of .25 and got the tie rod up above the bottom of the axle. I’ve gotta make real spacers now to space it up
06753756-A87C-4FC7-9532-6258A47B8D02.jpeg.921e75fca0b5dc5fffcf1aca1d43eb3f.jpeg8F8795BE-40E0-4B3A-A387-EB95CEC9B024.jpeg.75fd2832f6df64d8c428b501b3082104.jpeg
My driveshafts arrived! Adams gave me great service and a good price with two new yokes. Took a week to arrive after I ordered. Now I’m just waiting on brakes and the company I ordered them from is giving me the run around
Nice work. I’ve got to ask, how much lift did you get out of the back with your swap? I’ve some Super Duty axles that I’m trying to work on and wasn’t quite sure how much I’ll have to lift the front. Keep up the nice work. I’m looking forward to seeing your progress.
Expand
I am not sure on exact measurements. I can measure though. The truck sits nose down a little with a 6” Old Man Emu lift up front. And the Artec truss is supposed to add 2”. So 8” overall upfront.
In the rear the shackles are 1.5” longer then the stock ones. I’m also using a set of u bolt eliminators which also add 3/4” to a 1”.
With a stock shackle and a regular ubolt kit it would sit level with a 6” lift in the front if you did just a SOA
And thanks man! Hoping to paint it before I take it out of the garage
370C769B-534A-4606-9B7C-6C93263AC2A7.jpeg.b811741b6ba2891689c3aeaf32c4e5d9.jpegFDB36DA2-7A9A-4A86-8D10-D79CAB4A763B.jpeg.eeae441b04a6f2e392483e435577a71f.jpeg
mocked up the draglink with some conduit and then cut it in half and slipped a piece of a wind-chime to make a slip joint. So I can make small adjustments and dial in the fitment before making it out of 1.5”  .25 wall dom. I don’t have full lock to on the axle. I’m guessing the pitman arm is not making a big enough arc
Axles are fully welded now. Starting the re assemble and tying up loose ends. I didn’t like the way the crossmember was mounted and wanted to keep it removable.
so I drilled and sleeved the frame for a 3/4 bolt. I made cut some pieces of .125 wall tubing and welded it in7497FA9B-6FCF-4AD9-AA56-1BE340B60C46.jpeg.4d6d753d1c4116bb38eabdce08210fc3.jpegBE962862-C517-42FD-99CD-5678847EE794.jpeg.0942379352b71855430da7f6d9b41707.jpeg
looks really good. A coat of paint and it looks factory. Next was making the crossmember braces/skid
675A56BA-141B-485E-934A-077250003899.jpeg.5abcb5a1d97466af7ae6c799d35b6004.jpeg6250C5FF-A810-4C7E-9D51-828106A62935.jpeg.2d7d154f3396307e6502e6f703685f1a.jpegAF5B96ED-1D1C-4596-B8C8-4DC2CA69063A.jpeg.289a263a2576a9fa6b8c5d5dce7db0e3.jpeg
FB5FD7C6-6324-42BB-BA77-D53DDF0EB8C1.jpeg.d3dfb6b2363b3e7051c2d74913333f86.jpegB4B52CE2-E23A-4DE8-A369-7B9B51E3F239.jpeg.fc18208a287623ab3b70c6eebf92b263.jpeg
The crossmember/tcase skid is complete. All the bolt heads are recessed into the plate so it will be decently flat across the bottom with nothing to snag on.
also the tcase output housing is the same size as a 3/4ton outer axle shaft seal if you cut the ears offD71BEEBA-8391-4F7C-9CF5-24E00229C942.jpeg.ad6ee277d65bb6ace47e76c8c57f0766.jpeg
D84DD054-AB6E-4C4B-8F6D-D01AB1791B0F.jpeg.20da63a0f416d99b1871d00d975cb1ae.jpeg58D749F5-48B6-4216-8B8C-8C82764DF55C.jpeg.903c4457ff8d021c0c06dd9cedbeaadb.jpegI deleted the load valve by following Hornbrods post. Spent the better part of 20 minutes under the truck flaring lines that I kept cutting crooked and splitting the side out of. I finally got it right after  4 try’s :furious3: checked the time and it 9:40 pm. Then proceeded to pour in brake fluid to see if I had any leaks before calling it a night, pumped the brakes twice *splat* I walked to the back of the truck to see the mess I just made. Also to realize I had hooked up the wrong line...
First drive was a success!! Getting it out of the garage Was tedious because it was so tall. I had to switch the front two wheels for some with no tires to be able to pull it out.
after a few miles around the neighborhood, the suspension settle about an 1.5” or so and now I’m able to drive it and and out of the garage which is nice. I was wanting to try and keep my COG pretty low.
C95E23A3-321F-4B15-B18E-4B42B516C39E.jpeg.3fe467a9452a6c08fc56cdf2ebd966db.jpegAE5CF80F-349D-4CFF-ABD5-B53DE650ED68.jpeg.688a97f05a91ae8377160afada794feb.jpeg33D415E2-518B-4C98-AAE2-F409BB2D54FC.jpeg.20aae86115696a06dbf01ce93d2f996b.jpeg
I drilled and tapped my steering box while I had it apart to replace the seals. They are a lot simpler on the inside then I thought it would be. I had to take it apart twice because I didn’t get the balls back into it correctly the first time.1B79373E-C7B9-445D-A46E-551A61B0E702.jpeg.89f9d584a4ed2884e8d74ff0a0883645.jpegDFFCB53A-2675-46B7-8F4D-983C9AB671F1.jpeg.4692906d127f3a366c0294b74f728606.jpeg
i didnt wanna talk about redoing the box till I made sure it works properly. I have all the pics to do a complete write up. It works like it should with little play and no leaks. i was worried the holes for the hydro would leak with the plugs in them. I haven’t got a ram yet but hopefully will order one soon.
  On 8/9/2019 at 3:02 AM, DesertRat1991 said:
This is great.  I love how this build started with "my wife asked for dependable winter vehicle" and ended up long armed, on super duty axles and 37's.
OP -- has your old lady caught on yet...?? :roflmao:
Expand
I’ve got her fooled into thinking we need all this stuff :driving:
  On 8/8/2019 at 5:38 PM, 89 MJ said:
I feel like this should be over in Epic because of the axles.
Expand
I appreciate that man!
Expand
You do need all of that stuff for the winter! It makes it easier to driver throught the snow (maybe), but it also is theft protection. What thief would try to steal a Comanche on 37s?!?
Expand
Nobody will be able to find it, the whole back end is camo! :laugh2:
