Fuel tank lock ring
My fuel tank leaks after filling more than 3/4 , gasket has been replaced twice and it still leaks and it's getting annoying. I have a new mopar seal this time waiting to be installed What tips/advice do you Guys have for replacing the seal .
Here's how the lock ring is sitting as of now , it looks a little odd to me but i can't tell what's wrong
Swb,4.0,d44,BA-10/5
And yeah, it is a TOTAL PITA to deal with that thing under the truck.
The three times I've messed with the tanks/pumps/sending units I've ended up dropping the tank
instead of the continued fight.  For me I think I saved time and did a better job in the end.
Good Luck!
Hi Scott,
Thanks for the comment. About 10 years ago I changed the gas tank, no problem dealing with the lock ring with the tank out.
Last year I changed the fuel pump...Didn't remove the tank....I don't think I got the the lock ring very tight...so I have not filled the tank over 3/4 full.
Much much easier with the tank out of the vehicle. But I had a full tank of gas when I changed the fuel pump...
Thanks
Gene
You can't over tighten the lock ring. They have 3 little tabs that press against the 3 hold downs on the tank itself. Tap it with a hammer till these touch and 99% of the time you will be perfect.
If these aren't touching them (or really close) its not on all the way. It may still work, but its not right.
