cherokee Posted June 29, 2007 Posted June 29, 2007 I'm currently 'restoring' an 88 MJ that I intend to put a stroker in. Still haven't made up my mind on which 'era' of engine controls I want to use though. I have most of the parts to use the original Renix controls (I lack some auto specific parts) but have a non vacuum era transfer case that I want to use. I have the electronics and wiring harnesses from an OBDII era XJ, but am not in favor of dealing with potential airbag issues. I don't have any OBD1 electronics, but realize that may be a good middle ground (non vacuum front axle/tcase, no potential airbag problem). So now that the situation's been explained... I'm looking for opinions and advice on which system would make for a good daily driver stroked 4.0. As well as which head, intake, and exhaust would be best (again, I have a Renix and OBDII setup, but not an OBD1). Here's a link to a fairly recent page in the buildup (teardown?) thread of the local forum. http://www.wnyoffroad.com/forum/viewtopic.php?t=723&start=75
LEAD_NOT_FOLLOW Posted June 29, 2007 Posted June 29, 2007 The biggest determing factor is going to be what head you put on it...
DirtyComanche Posted June 29, 2007 Posted June 29, 2007 The vac axle doesn't change anything. Renix era MJ/XJs had either. The 4wd indicator has to be swapped possibly. Unless you're talking an electronic drive speedometer on the tcase.... In which case the cable setup is a direct swap (the parts are interchangable, I finially went out and checked). OBD anything sucks, IMHO. I don't care for it.
Pete M Posted June 29, 2007 Posted June 29, 2007 I vote Renix. :D Nice and simple and it has a knock sensor. :D
ejndssn Posted June 29, 2007 Posted June 29, 2007 2nd vote here for the Renix and maybe i bias caused my 89 MJ has been stroked and i m enjoying it to the max :brows:
rockhardzj Posted June 29, 2007 Posted June 29, 2007 I have the entire electrical harness, and ECU out of my old 93 XJ, it was a 5spd, but should be easy to adapt (I think there is a tranny add-in harness???), but I'm not sure if the ecu would need to be reprogrammed, or swapped completely. You know how to get a hold of me.
MrShoeBoy Posted June 29, 2007 Posted June 29, 2007 Are you good with wiring and know how to solder? Get a Megasquirt. Fully adjustable home made ECU and its $250. I plan on getting one eventually, just a matter of time and money. AARON
cherokee Posted June 30, 2007 Author Posted June 30, 2007 I have a 98 head, but I'm not sure I want to use it due to the possible higher compression. The cable speedometer is a minus. I have a 97 242 case that will go in. So I would have to switch to another system. I forgot about the Renix era 242 still being non-vac. I don't mind OBD too much, but do not want to deal with any possible airbag issues from either era. The Renix knock sensor is a really big plus. Then it becomes a matter of whether or not I'm willing to retrofit Renix sensors and such onto a newer head and intake. Megasquirt? Interesting... Easily tuned?
tjbliley Posted June 30, 2007 Posted June 30, 2007 Won't the 242 use the speedo gear from the case you have now. I thought it would. You can also make the axle disco happen by electric switches on the vac line and all you ahve to do is add a lunchbox locke in the front and its like a selectable.
LEAD_NOT_FOLLOW Posted June 30, 2007 Posted June 30, 2007 Are you good with wiring and know how to solder? Get a Megasquirt. Fully adjustable home made ECU and its $250. I plan on getting one eventually, just a matter of time and money. AARON Spend the few extra bucks and get Electromotive Tec3. It's a TON better setup, and does quite a bit more. Yes I'm saying Megasquirt is junk.. 8)
DirtyComanche Posted June 30, 2007 Posted June 30, 2007 Won't the 242 use the speedo gear from the case you have now. I thought it would. It will.
Oizarod115 Posted June 30, 2007 Posted June 30, 2007 keep the RENIX system man, knock sensor. and it won't throw any codes lke that
MrShoeBoy Posted July 1, 2007 Posted July 1, 2007 Spend the few extra bucks and get Electromotive Tec3. It's a TON better setup, and does quite a bit more. Yes I'm saying Megasquirt is junk.. 8) So how much more are we talking over a Megasquirt? Are you comparing this to the older mega unit or the newer 3x version? Cause I see nothing wrong with the newer version and its super cheap compared to the Accel DFI unit that Hesco sells for $1600. AARON
rockhardzj Posted July 1, 2007 Posted July 1, 2007 Maybe a Link ECU. it hooks to a laptop and you can run real time dynos just doing your daily routine, and record the info onto the laptop live, or download it later. Its a kick @$$ setup, and they are always improving it. I think it runs kinda pricey though, but can be adapted to just about any engine out there thats fuel injected, even some diesels!
cherokee Posted July 5, 2007 Author Posted July 5, 2007 Probably a very stupid question, but I haven't owned or dealt with any Renix era 242 equipped Jeeps. I know all 242s are non-disconnect axles, and it's been said that the cable assembly swaps over. Are there any differences in the speedo assembly (cable drive, long gear, etc.) between a Renix era 231 and 242? What about a Renix era 242 and external slip yoke era 242? Just the tailhousing of the case gets swapped and that covers those differences?
