el_betillo Posted July 1, 2015 Posted July 1, 2015 I bought this mj not to long ago and need help with identifying the engine . It came with this swap and I have no clue what's original on the engine and what was swapped . The oil filter is visible threw the top ... If you guys need any pics of another angle let me know
HOrnbrod Posted July 1, 2015 Posted July 1, 2015 4.0 HO with an aftermarket valve cover and a relocated windshield washer bottle. Can you take a shot of the right side of the engine? I don't see the PDC (Power Distribution Center).
Jeep Driver Posted July 1, 2015 Posted July 1, 2015 4.0 HO with an aftermarket valve cover and a relocated windshield washer bottle. Can you take a shot of the right side of the engine? I don't see the PDC (Power Distribution Center).
HOrnbrod Posted July 1, 2015 Posted July 1, 2015 ^^ That pic wasn't there the first time around for me. :hmm:
el_betillo Posted July 1, 2015 Author Posted July 1, 2015 Anyone know of what range year it came from .. And what model
Strokermjcomanche Posted July 1, 2015 Posted July 1, 2015 91-95 cherokee or 91-92 Comanche Hook up the vacuum hose on the fuel pressure regulator .
el_betillo Posted July 2, 2015 Author Posted July 2, 2015 Thank you guys .. I ordered the wrong vacuum hose that I received today and did not fit .. Ima try the 91-92 Comanche vacuum hose ..
Eagle Posted July 2, 2015 Posted July 2, 2015 What year is the truck? On the passenger side of the engine block, near the distributor, there should be a flat, oblong boss with a series of characters stamped in it. Post what those numbers are -- those are the engine build codes.
el_betillo Posted July 3, 2015 Author Posted July 3, 2015 Size tires are 255/75r17 mud terrain bf Goodrich @fiatslug87 For @eagle the year of the Comanche is a 89 thanks for the info I will check the block # after my trip to pismo for 4th of july
cruiser54 Posted July 4, 2015 Posted July 4, 2015 Pismo, that brings back a lot of memories. To me also. Late 60s and early 70s.
